Question about Reebok Vista Treadmill - RBTL13305
I have a Reebox RBTL13305.2 and my console lights up but when I press the buttons they dont work nor does the fan turn on. How can i fix that problem? I have tried to unplug as well.
  • Terry Richardon Aug 17, 2013
    I have same exact problem
My ps3 wheni go to turn it on n press the button the lite goesfrm green rite back to red n wont turn on
This fix works for some models, so if it does not work for you please tell me your model number
Look at the bottom. This is what it looks like:
SONY
PLAYSTATION 3
CECH-*** = Your model number
SONY COMPUTER ENTERTAINMENT INC.
MADE IN XXXXX
You can do this fan test.
Turn the main switch off, hold the eject button.
While holding the eject button, turn the main switch on, when the power light is green, release it, it will beep
The fan will operate at the highest speed possible and will eject any disc that is inside.
After about 15 seconds the fan will stop spinning and the ps3 will beep 3 times and blink a red light.
When this happens, turn the main switch off and on then turn it on normally.
Let me know how this goes!!
P.S. It will not harm your ps3, It's testing the cooling fan.
Nov 28, 2011 | Sony Playstation 3 (PS3) Console
I have turned my wii on so the console is fine just when i go to use the remote in wont work usually i press a button and all lights flash then i get one light on and yep it starts working but now when i...
The local remote sensor panel may probably death or damaged, or the brain box component of the console has damaged. it can be fixed up by taking this to a well specialized personnel on it. Hope this will help
May 31, 2010 | Nintendo Wii Console
Console is turning its self off after roughly 1hour
Over Heat proplem, first dont place your PS3 over a carpet second dont place near a wall leave a space third and this one ROCKS turn off your PS3 totally OFF no lights ok now keep pressing on the EJECT toutch button and turn it ON from behind it will make a very loud fan noise this will clean and some kind repair the fan an cooling system from the inside. and one more last thing but im not 100% sure but i've been told to place the PS3 over something like a cube find a 4 cubes and place the PS3 over them each one in a corner. have fun
Mar 08, 2010 | Sony Playstation 3 (PS3) Console
No picture just sound
ur xbox 360 is in high def turn ur xox 360 with ur controller and hold r trigger and y button together till it turns on. if it dont work than u got the rings of death try this there are fans in the back of ur xbox 360 put a straw on each to stop the fans from spinning wait till it has two red lights than disconected from the back and wait 20 minutes and try it see if it work. if it work this is just a temperary fix.
Jul 02, 2009 | Microsoft Xbox 360 Elite Console
Wii remotes lights just flash at the very first screen and will not turn on
turn the wii on, and open the slot next to the disk drive.
then on the wii remote take the battery cover off, but dont touch the battery.
press the red button on the wii, then do it on the remote. (the buttons should be labeled "sync".)
when they connect, your problem should be fixed.
PLEASE RATE THIS.
PLEASE LEAVE A COMMENT IF IT WORKS, OR DOESN'T WORK.
Mar 01, 2009 | Nintendo Wii Console
Power button failure
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    Nintendo Wii console gets a black screen when switched on
    not to be mean but buying a modded anything usually voids the warranty.
    Not having anything to go off of regarding the mod means that we don't know if it's a faulty weld on the board or anything like that.
    Try doing a system reset (if there is a reset button) and see if that works
    Jun 08, 2008 | Nintendo Wii Console
    No Power with 3 red light
    hmmm.. The Ring of Death.
    The 4 rings mean power faliure.
    The 3 rings mean the CPU has been melted.
    The 2 rings mean there is a CPU overheat error.
    The 1 ring means there is an internal error.
    Hope this could of helped you.
    Jun 05, 2008 | Microsoft Xbox 360 Console
    Reebok Vista Treadmill - RBTL13305 Logo
    59 people viewed this question
    Top Reebok Exercise & Fitness Experts
    Matt Olenzek
    Matt Olenzek
    Ross Metcalfe
    Ross Metcalfe
    Howard
    Howard
    Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
