Question about HP Compaq Presario M2010US Notebook
How do i repair my compaq laptop it those no turn on
The power dose not turn on
  • HP Master
  • 32,281 Answers
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Posted on Dec 31, 2012
My evo would not start
Remove the cables and battery on the laptop. Press and hold the power button for 8 secs. Reinsert the cables and battery on the laptop. Turn on the laptop. If it still won't turn on, check if there are lights on the keyboard. If there are no lights, the symptom is that power supply or the motherboard itself is not working. Consult Hp Compaq for possible repair
Aug 18, 2010 | Compaq Evo N610C Notebook
Compaq presario c700 laptop- unable to turn on laptop
U may have a dead board. They average $285 plus labor. A shop should be able to test it on a volt meter see if the power grid is burnt for around $35. then u will know what ur in for. If its a bad board just replace the laptop I wouldnt repair that problem on an older laptop.
Jun 24, 2010 | Compaq Presario 700 470024-192 Notebook
Compaq presario 700 monitor off
Hi
Maybe, depending on the problem. Laptop monitor problems fall into three categories. 1. Screen electronics or lamp. 2. Inverter. 3. Laptop video chip. I've been repairing latops ever since they arrived on the market. First connect an external monitor to the laptop - this will show you whether or not the laptop motherboard is working correctly. If it is then you'll need to replace either the screen or the inverter. So as not to waste alot of money, at this point I would suugest going to a reputable repair person or check my website www.micromendllc.com
Jun 05, 2010 | Compaq Presario 700 470024-192 Notebook
Compaq 1500c won't power on.
first thing you should check is the ac adapter, most are made cheaper today,
next is the ac jack in the back, you can take a toothpic or anything to see if the pin moves at all
if it moves just a little , the ac jack could be bad
Mar 13, 2009 | Compaq Armada 1500C Notebook
Dose not turn on
Try to remove the battery some laptops will not power up if the battery is dead.
Another thing is check to make sure that your adapter is working and you see a green light.
Dec 24, 2008 | HP Compaq 6720s Notebook
Compaq doesnt power up at all
try removing the memory and clean it, if you have more that 1 put hem back 1 at a time turning the laptop on each time
keep us informed
regards
Nov 24, 2008 | Compaq Presario 700 470024-192 Notebook
Gateway laptop mx6448
Try booting from dvd drive with rescue disk
Jul 10, 2008 | Compaq Presario M2000 Notebook
HP Compaq Presario M2010US Notebook Logo
50 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
