Question about Refrigerators
Needs to know the correct end I need to ask for in the hardware to connect the water line on a GSHS6KGZSS GE refrigerator.
    Genius:
  • Refrigerators Master
  • 1,669 Answers
Please try these sites:
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=GSHS6KGZSS
http://kitchen.manualsonline.com/manuals/mfg/ge_appliances/gshs6kgzss_1.html
Posted on Jan 24, 2013
SOURCE: No water from dispenser ice works fine
My water outlet was frozen and wouldn't let the water through. Turn the fridge off and let it thaw out if this is the case. Regards, Phil, Brisbane Australia
Posted on Jan 14, 2009
Sea Breeze
  • 4654 Answers
SOURCE: KitchenAid Refrigerator water tube needs replacing
Visit my site, I offer free help and model and parts number search feature. Movies and instruction manuals for most brands. seanreezehvac@yahoo.com click on link below, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Please send me your model number so I can give you better instructions. Clorox in the water supply and waiting until the Clorox is cleared from water dispenser and Ice will also do the job!
Posted on Apr 04, 2009
mreid542
  • 166 Answers
SOURCE: water leaking from bottom front of refrigerator
you don't say whether this is a top mount freezer side by side or what but the most common problem is a blocked defrost drain. you'll have to locate this drain and clean it out. this drain is located underneath evaporator coils in the freezer. every day the refrigerator defrosts and water runs out the drain into a pan in the bottom of the refrigerator where is evaporates.
also make sure you don't have a pin hole or other leak in an ice maker line .
Posted on May 27, 2010
BarrettDenCo
  • 1772 Answers
SOURCE: How do I know if my GE refrigerator is dead or
Sorry to read about your problem. you can have many different problems.
Your unit should at lest run if low on freon. since you have a complete failure, you could have the following
1. Bad temp control
2. Failing compressor
3. Defective start cap
4. Defective overload protector
5. Defective control board
I suggest you call a service company.
I have tried to help you. Please help me, by Vote/Rate my response. Thanks.
If you live in the Denver area, I can help you.
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Posted on Jan 02, 2011
Testimonial: "Thanks!!!!!!"
SOURCE: I have a GE Profile Performace Refrigerator and the water dispenser and Ice maker are not getting any water. No water is coming into the refrigerator. Water line to refigerator is working. What may
Check the water solonoid on the lower right side facing the rear of the unit. the water line connects to it. sounds like it might be defective.
Posted on Apr 07, 2012
Water will not dispence in ge refrigerator model number gsl25jfpa bs
Your line is frozen. Frozen water dispenser line is a problem with this model. There are number of solutions.
1. Contact GE 800 386-1215, option 5 and ask for WR49X10173 heater kit. There is a video http://www.youtube.com/watch?v=BdNX3LteJTw to help you install it. Try to get GE to send you the fix free.
2. Get a hair dryer and heat the dispensing box until the water dispenser works. This is not a permanent solution, though, and it takes 15 to 30 minutes. Hang a long beach towel or blanket over the open freezer to save the cold air.
3. Place a long, clean fishing line or weed wacker line up the water dispenser line. When it freezes, pull carefully to dislodge the frozen water.
4. Buy another brand of refrigerator and let GE know they make inferior products.
Jan 10, 2013 | GE GSL25JFPBS Side by Side Refrigerator
GE Profile Icemaker freezing up; water freezes down inside wall of freezer; icemaker making ice, very slowly, but will not dispense. Water is still dispensing
This sounds like your water valve is not completely closing allowing water to drip and freeze. First check to make sure that the water tube going into the cup of the ice maker is lined up correctly and not causing this problem - if it is lined up correctly then replace the water valve on the back of the refrigerator that your main line is connected to.
Jul 01, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker line poped out of back and water line going to ice maker frozen
Sometimes over the winter months the tube going to the ice maker can become blocked with ice and cause this tube to pop out.
1. With the water supply going to your refrigerator on take a look at the end that popped out and see if you can see it drip at all. If it does not drip just clear the ice out of the ice maker fill tube, then replace the line that popped out and you will be good to go.
2. If you do see a drip come out of the end that popped out you will need to trace that line back to the valve its connected to and replace that valve.
Thanks for asking.
Jun 02, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I HAVE A GE PROFILE TPH21PRS - ABOUT 10 YEARS OLD. THE WATER TK DIS IS CRACKED ALONG THE SEAM. IF I BUY A NEW PART, WHERE DOES THE WATER LINE CONNECT IN- I ASSUME THAT THE LINE WHICH ENTERS AND EXITS THE...
Yes and the replacement will be simple to replace and install. The part comes with new tubing and feed through the openings in floor and back of refrigerator. I will also be available to assist your installation per email or phone. Just let me know, Thanks, sea Breeze
Nov 27, 2009 | GE Profile PSW26P Stainless Steel Side by...
Don't know how to connect the water line to the unit there are two separate line for the water and the ice maker
The ice maker is intended to tolerate the same water pressure as the cooled water supply so you only need to 'tee' them together can be had at any hardware store) and you should also buy a sink-type valve to put in the line so it can be conveniently shut off if need be. The sink-type valve will have similar dimensions but you should check the inlet line size before buying your parts. Safest would be to cut a 1/4" length from one of the lines to take with you.
Jul 17, 2009 | GE GSS20IEP Side by Side Refrigerator
Water Supply Line for Ice maker and Water dispenser is leaking.
Hi, The fitting either needs tightened or changed. Is this a brass or plastic fitting?
If the supply line is still ok and not brittle, you can go to your local hardware store and get the new fitting parts. If it is brass, be sure and get the brass insert that goes inside the tubing as well as the compression ring.
Please let me know if I can assist you further.
Vic
May 28, 2009 | GE Profile PSS26NGS Side by Side...
Water line leaking
unscrew the back panel and look if the plastic hose for the water (on the left side, goes to the blue/red valve block) is broken. If it is then you can buy a silicon tube or hose in a hardware store which fits on both ends (measure the diameter) you also need to buy two metal rings with a screw (don't know the name of these) which you can put over the connection to tighten it. The old hose has become very brittle in my case and this solved the issue
Feb 09, 2009 | GE GSS25LGM Side by Side Refrigerator
Water line burnt into causing water to run on floor when water is dispensed.
Replace the line. Splicing a line can lead to leaks down the line. You can get the material you need from a local hardware store.
Jun 20, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water hose too short
there are retail kits for these at home depot , builders square or such to extend and connect these correctly.you might want to get a filter while you are shopping for kit.
Apr 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
