Question about Garden
Right tire is flat icant get it to inflate and cant get it off to bring it somewhere
    Sergeant:
  • 322 Answers
Try putting some fix a flat in it. Be careful not to over inflate it
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Posted on Jan 17, 2013
Not inflating and i can hear the tires air escaping through it from somewhere
Go to a tire store, where they can remove and test for leaks. If it is in the whitewall area, it cannot be repaired.
Jan 13, 2015 | Motorcycles
Craftmans Snow Thrower 247887001 Tire Flat. How to Refill.
The tires are probably tubeless type. If the bead is broken ( not sealed to the rim) the tire will not inflate. Taking the weight off the tire will some times allow the bead to seal against the rim and allow tire to be inflated. You can also put a small ratchet strap around the tread of the tire and tighten it up. This will squash the tire and make the bead seal up. MAKE SURE to loosen strap as soon as bead seals and tire begins to inflate. Hope this helps.
Jan 01, 2014 | Garden
I am trying to inflate flat tire and can't get it to inflate with air master air compressor 59008. what am I doing wrong?
Jack the car up on the side you want to inflate to get the weight off of it. No compressor that i know of that plugs into a cigarette lighter is strong enough to inflate a flat tire under that much weight.
Nov 01, 2012 | Mini Tools & Hardware - Others
My ( ! ) light stays on
Hi there:
Is your TPMS Warning Light On? The Tire Pressure Monitor System monitors the inflation pressure of the tires on your vehicle. If the pressure inside any tire drops 25 percent or more below its recommended inflation pressure, the warning light comes on to alert you.
Should you stop driving and check your tires immediately? It would probably be wise to find a safe place to stop or pull over so you can check the tires. You may just have a low tire that has been slowly seeping air over a period of time. Or, you may have a tire that is going flat. The TPMS Warning Light only tells you the pressure is low in one of the tires, not how fast the tire is losing pressure.
Important: Check the pressure in ALL of your tires, not just the one that triggered the TPMS Warning Light. Why? Because you may have other tires that are also low, but not low enough to trigger the warning light.
If you discover that one or more tires are low, add air to bring them back up to the recommended inflation pressure for your vehicle. You can find this information on a decal which may be mounted in a door pillar, the glovebox, or in your owners manual (which you should carry in your glove box).
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
May 26, 2012 | Holden Vectra Cars & Trucks
DOES THE 750 LI 2006 HAVE TIRE PRESSURE MONITORS
It either has Tire Pressure Monitor (TPM), or Flat Tire Monitor (FTM)
TPM:Checks the tire inflation pressure in the four mounted tires. The system indicates if the tire inflation pressure has dropped considerably in one or several tires.
FTM:Keeps track of the inflation pressures in the four mounted tires as you drive. The system triggers an alert whenever the inflation pressure drops significantly in relation to the pressure in another tire.
Aug 18, 2010 | 2006 BMW 750Li
Right front tire has gone flat 3 times in the last
You can remove the tire from the vehicle, make sure it is properly inflated, and spray with a soap and water solution. Carefully look around the bead, check the tread for bubbles, could be a puncture, and don't forget to look at the valve stem. Any bubbles indicates a leak. Good luck.
Steve
Jan 02, 2010 | 2007 Pontiac Solstice Convertible
Air preassure in victory scooter
Most electric mobility scooters with inflatable tires require a tire pressure of 30-35 psi (be sure to check the manual of your scooter for the correct tire pressure). Do not allow the tires to become under-inflated or over-inflated. Under-inflated tires could make the scooter unstable and over-inflated tires can burst under pressure. Also, you should manually inspect the tires periodically to make sure they haven't taken any serious damage that could lead to a flat.
Jun 15, 2009 | Pride Mobility Victory 3 Wheel Electric...
Craftsman 30'' mower front tire off rim can't put back on
hello...is the tire loose but still on the rim...the sidewalls no longer engage the rim tight to hold air but still aroung the rim loose....If that's the case, get a jack, can of fix a flat, and a small ratcheting hold down strap.....jact the tire off the ground.....wrap the strap around the tire and ratchet it tight to get the beads of the tire to touch the rim....then commect the fix a flat or, if you have ,,,air from compressor to inflate the tire,,,,might have to work it a little to get the tire to reseat on the rim....this should work for you....once the tire is seated on the rim....stop inflating the tire until you remove the strap or you migh have a problem getting it to release from the tire if fully inflated....
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
