Question about Bose LifeStyle 5 Series-III CD Shelf System
Bose Lifestyle 5 music-center 1994
Hi, and thanks for your help...
I brought my Bose lifestyle 5 system with me to Germany and used a Transformer 230 to 110 Volt to operate the system, it does not power up.
I used a Powerpack from a European Lifestyle 5 from 1996 system, 230 input, 12 volt output.......again nothing.......
Do you have an idea what else I could do ?
The system only says 12 v-av output
Could you help me somehow ?
Thanks so much
Evelyn Reres
  • qsplit Mar 29, 2009
    Same thing here. It worked when I was in the states, now I tried it with a transformer no-go. I was thinking about buying a 230V tranformer but it looks like I may be out of luck.
    Have you figured it out?
5 Suggested Answers
SOURCE: Bose lifestyle model 5 /Acoustimass 25 sub power problem
Open or leaking components will look OK but, may not function as designed. Rather than create more problems, please consider whether the unit is worth repairing by a pro/tech, if so, do so.
Posted on May 10, 2008
SOURCE: remote control program codes
want to know the code for bose lifestyle5.
Posted on Jul 23, 2008
  • 12 Answers
SOURCE: bose lifestyle 5 music system
Alan, The resistor is on the underside of the CD 5 main pcb near the jack socket it is a small chip resistor, but this can be replaced with a small 1/4 watt or smaller resistor. If you provide me with your e mail address I will send you a copy of the PCB layout drawing, the image size is to large to attach
Regards
Dave
Posted on Nov 26, 2008
althoffk
  • 4 Answers
SOURCE: Everything works with my bose
According to other threads this is due to a bad capacitor (either C19 or C16). It is a 33uF capacitor rated at 25V. Needs to be replaced by a 33uF higher voltage (like 63V). Have the same issue but have not yet completed the fix. Please perform a search on the forum and you will find it. It says is on the lower left side of the console pcb.
Posted on Dec 24, 2008
  • 51 Answers
SOURCE: No output from Bose Lifestyle 12 system
Sounds like you have a problem in the circuits, which of course would take an experience technician to find and repair. But a 1994 electronic item has pretty much reached the end of its expected life cycle (sadly, compared to older equipment which is still working great). Basically, it sounds like the power amp circuit is shutting down a few seconds after startup. Might check to make sure no speakers or cables have shorts, which could activate a protection shutdown circuit. If any of the cubes don't hiss when you turn it on, that would be the first place to look for a problem.
Posted on Dec 29, 2008
The remote does not communicate with the amplifier
[PDF]The Bose® Lifestyle® SA-2 and SA-3 Stereo Amplifier
https://worldwide.bose.com/.../en/owg_en_sa2_sa3.PDF Bose CorporationWARNING: To reduce the risk of fire or electrical shock, do not expose the product to.... ence to radio communications. ... Note: Unauthorized modification of the receiver or radio remote control .... Thank you for purchasing a Lifestyle® SA-2 or SA-3 stereoamplifier. ... Left and right channel line inputs for a local audio device.
[PDF]Owner's guide - Bose
worldwide.bose.com/axa/assets/pdf/owner.../og_sa1.pdf
Bose CorporationJan 4, 2002 - WARNING: To reduce the risk of fire or electric shock, do not expose the.... may cause harmful interference to radio communications. ... Connecting theLifestyle® stereo amplifier to a Model 5 music center . ..... Lifestyle® SA-1 stereoamplifier rear panel ... Setting up the RC-20 remote control for Zone 2.
[PDF]BOSE® Link AL8
Dec 29, 2015 | Bose Lifestyle SA-2 2-Channel Amplifier
We have a Bose Lifestyle model 5 music center and it won't go into surround sound mode. It will play a CD and all 5 speakers work. Any suggestions??
Are you sure the red and white wires plugged into the audio output on your TV because I had the same problem and learned thats where you plug them into
Nov 06, 2012 | Bose Lifestyle Model 5 Music Center
Can't power up my BOSE 1995 Lifestyle Model 5 Music Center
you might want to google the service manual for the system as i did. this will show you how to take it apart. after doing so check the solder points along the dc power jack( power adapter plug on the unit). i was having the same issue and carefully inspected all the components... i resoldered the dc power jack and viola! powers up. btw, my system is bose acoustimass 5 music center model 5 (1995). good luck!
Aug 07, 2012 | Bose LifeStyle 5 Series-III CD Shelf...
Remove cover on bose lifestyle 5 music center
It is a difficult job. There are no screws. It is lock fit type. contach any experienced service technician rather than ttry to open and brake it. Or download the service manual to it by internet.
Jun 12, 2012 | Bose LifeStyle 5 Series-III CD Shelf...
My base module doesn't work anymore , can i replace it with another brand or amplifier
There's a base unit on eBay for bid, currently around $90, expiring tonight at 15:45 PST
http://cgi.ebay.com/Bose-Lifestyle-12-control-system-new-box-w-o-cord-/170595656943?pt=LH_DefaultDomain_0&hash=item27b84b24ef
another $210 Buy-It-Now
http://cgi.ebay.com/BOSE-LIFESTYLE-5-8-12-EXCELLENT-EXTRAS-AND-REMOTE-/260731188231?pt=LH_DefaultDomain_0&hash=item3cb4ca3407
$204 BIN...
http://cgi.ebay.com/Bose-Lifestyle-5-8-12-Music-Center-Near-Mint-/180620466103?pt=Receivers_Tuners&hash=item2a0dd197b7
Bose products are highly proprietary. If they have non-standard connectors from the amp or in the speakers I'd take that as a clue they're NOT compatible with other manufacturers' products.
Feb 02, 2011 | Bose Lifestyle 12 System
Need a power cord for a Bose Lifestyle Model 5 Music Center. Seriel #U288342.
that is a ac adaptor for the ls5 think it's a 12ac not dc output ,be careful. get one from bose.
Oct 09, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
No LED Display On The Bose Lifestyle Model 5 Music Center
Hi, you have to replace the 100uf capacitors c14 c15 c16 c17 and c19 on the digital board, that will cure your LED fad problem.
Chris.
Jun 25, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Bose lifestyle 28 no power
There's no easy way to put this. This media center will need a repair. If you know the outlet works, and the power supply works. It couldn't be anything that's easily fixable. Make sure you don't have a dual-voltage power supply (red switch for 120v/230-240v). If so, change to 120v for us power. Otherwise this is pretty straight forward. You can call bose for a repair- 800-367-4008. $165 + tax flat rate. New 1 year warranty.
Jun 20, 2009 | Bose Lifestyle 28 System
Can i use my lifestyle 5 to other cd player?
Yes. But you need your Model 5 music center connected. Just like any receiver. -Without the main LS head unit, this will not be able to turn on.
May 28, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Bose lifestyle model 5 music center
Bose lifestyle 5 series III does not play any CD or DVD, it keeps saying unsupported formated . Can anyone offer suggestions.
Dec 01, 2007 | Bose LifeStyle 5 Series-III CD Shelf...
Bose LifeStyle 5 Series-III CD Shelf System Logo
211 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Sheila Brown
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
