I use onboard sound card but my computer have no sound. when i look in device manager tha audio driver is aready installed. when i try to pdate, there no update available.
  • 298 Answers
Uninstall, reboot and reinstall it. Some other prog grabbed his interrupt.
Posted on Jan 18, 2009
No sound
Hi there.
If there is no sound coming out from your desktop, make sure that the audio card driver is installed or updated. To check on this, go to Device Manager ( START - Right Click My Computer - Properties - Hardware - Device Manager). See if there is a yellow exclamation point before AUDIO. If there is, then you need to download the driver from the Emachines website.
Thank you!
Sep 22, 2011 | E-Machines eMachines Desktop PC
Am trying to call computer to computer but a message keep coming up saying that i do not have a sound card or my sound card is not turned on.
try re-installing the audio controller. Your onboard sound card driver may be corrupted. check device manager for issues. try downloading fresh driver from your computer MFG's website. If no dice, install a PCI sound card and that will fix the prob.
Good luck
Jan 23, 2010 | Toshiba (4CH-VOUT) Sound Card
From my onboard sound ac'97 did not hear any sound. when i try to sense form sm frunt , sarround, mic in connector fail apeared.
visit you device manager and make sure all drivers for your sound card are installed
1. right click my computer
2. click properties
3. click hardware tab
4. click device manager
if under sounds (audio) category you will see yellow question marks, then please install the required drivers
Aug 10, 2009 | Computers & Internet
Dell computer with no sound
you must check in your BIOS (when start up press del) and see if your settings whit sound card is ok,you have options to make onbord sound card after removed pci sound card
Jul 14, 2009 | Computers & Internet
Soundcard seagate ST320014A
Sound Not Working (discrete sound card)
You probably need to make sure the new sound card is properly installed. Check device manager and make sure the new sound card does not have a yellow exclamation mark next to it.
If the card and driver are propery installed, then you can either disable the onboard audio from BIOS (enter this when the computer first boots up by pressing either F2 or delete several times)
Or
go to control panel, sound, and check the sound card as the default. Do this for .WAV and .MIDI and whatever else you see.
And that should take care of it.
No Sound (integrated Sound card)
check device manager. This can be done in Win XP by right clicking my computer, properties, hardware, then click device manager. Alternative way to enter device manager is by clicking start menu, control panel, system (performance and maintenance), hardware then device manager.
In the deice manager window see if any question marks or exclamation points are visible.
If so, see if it the mark is for an audio device.
If it is an audio device, uninstall the device.
Next, try to install the sound card driver again. If that fails, the enter the device manager and uninstall the sound card again, restart the PC, ignore the hardware manager, and try to install the sound card driver software again.
Jul 07, 2009 | Intel Computers & Internet
No sound coming in compaq presario C700
Evidently you downloaded the wrong drivers. Check make and model of your sound card, or check the onboard sound in the "DEVICE MANAGER." (I'm assuming you run Windows XP). Go to the correct manufacturers website and get the right drivers. Or, it could be something as simple as the speakers are muted or disabled. Go to control panel, sounds and audio devices and make sure speakers are enabled and turned up.
Jun 25, 2009 | Compaq Audio card Sound Card
My unboard sound card is not working. In the sound and audio devices properties window it shows no audion device. How do I get this to work?
One option that you have is to re-install the drivers. Because this hardware is onboard, you will have to specify what model computer you have before anyone can provide you with help on how to find those drivers.
Once you download and install the drivers for your motherboard, you can go back to device manager to check the status of you audio. If it still doesn't work after re-installing the audio drivers, I would suggest that you totally disable the onboard audio and install an expansion card with audio ports in one of your open PCI slots.
If you will post a comment providing information about the model computer and/or motherboard you're using, it will be much easier for someone to help you find the appropriate audio drivers. From that point, you can figure out whether or not the onboard audio is still functioning.
Thanks for using Fixya!
Apr 10, 2009 | HP Computers & Internet
Audio is not working for P5SD2-VM motherboard...
You probably need Microsoft UAA drivers first
1) Remove any installed audio drivers through device manager
2) Download Microsoft UAA drivers for your O/S
3) Install them and reboot
4) go to device manager right click sound and update driver
It will go on the net and in most cases find and install them
Nov 28, 2008 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
My computer cannot detect my multimedia audio controller
Uninstall your sound drivers through device manager. then install the UAA drivers and REBOOT
then install your sound drivers
The only thing I can think of was you did not reboot after installing UAA drivers
Nov 10, 2008 | Intel D845GVSR Motherboard
Audio Driver issues
Right click my computer icon, click properties, select hardware then click device manager, check the audio device you can see the yellow question mark,insert mother cd driver then right click the yellow question mark and update the driver. otherwise change the audio driver..
Jul 02, 2008 | Intel DG31PR Motherboard
Computers & Internet Logo
David Payne
David Payne
