TV control do not respond when operated manually or via the remote
The TV switches On and Off manually, picture obtained. Unable to make any adjustment ie change channel, adjust the volume using the remote or by using the manual buttons on the TV. I have eliminated the remote control in that new batteries have been installed. I get the same behaviour from the TV with the batteries removed from the remote. Apart from identifying any dry joints on a circuit board I would appreciate advice on any further trouble shooting and possible part replacement and cost to repair via TV technician against cost to replace with new. Many Thanks
  • Mike Dec 30, 2012
    I've solved my own problem to update the TV is a Samsung LE26B450C4W. In addition to the symptoms listed the TV channel kept repeatedly changing down which I dictated a possible issue with the buttons at the side of the TV. I was able to disconnect and remove the buttons and it's associated pcb. The TV now behaves and can be stated with the remote control.
  • 1665 Answers
SOURCE: remote control not operating
Check first its batteries or replace them
Posted on Jul 06, 2008
  • 108 Answers
SOURCE: Unable to change any settings, volume, channel, AV input etc
you have a defective main board. replace the main pcb
Posted on Jan 09, 2009
  • 11896 Answers
SOURCE: TV won't change channels or adjust volume
Do you have a universal remote? If the batteries are taken out for a little period of time, the remote will loose the codes and they will have to be reset. You can find the codes by google universal remote codes.
If you have a factory remote that came with the television, than it may be faulty or the sensor on remote or tv may need to be cleaned.
Posted on Mar 11, 2009
SOURCE: can't turn tv on with remote, only manually, when on volume is at 100 and cannot be adjusted with remote or manually. channels cannot be changed with remote or manually. Changed batteries in remote,
replace with new batteries and it works --- so simple
Posted on Sep 22, 2009
  • 4889 Answers
SOURCE: TV does not respond to
When this kind of a problem appears it is usually due to a malfunctioning microprocessor IC . The IC cannot be replaced and the board has to be replaced as a whole. Replacement board should run you about 100$. I can find you a replacement if you are interested in fixing it.
Posted on Jan 11, 2011
013/ 054/ 055/ 060/ 065/ 067/ 089 These are the three digit codes to Jvc brand TVs. As there is no remote control with you, the first thing to know is, to which code do your TV respond. Some TVs will respond to three digit codes, some others will only respond to four or five digit codes. If your TV do respond to three digit codes, a universal remote control, which have the above said codes in its code list will work. If you wish to get three, four & five digit code list to some popular remote controls, check the links given above. You can choose the proper remote control to your TV. But before buying a new remote control, make sure about the number of digits of codes that TV must have.
Feb 23, 2013 | JVC Televison & Video
My laptop responds to tv remote
you can turn off the IR on the laptop or put black tape over it!
Sep 19, 2009 | Microsoft Windows XP Media Center Edition...
My Toshiba 2939DB needs to be tuned in to pick up SKY. I cannot tune the TV as I do not have the original remote control - any tips?
There are many companies on the net that make generic remote controls for TV,VCR etc and it may be possible to obtain an original. If you Google "Replacement remote controls" then I'm sure you'll find one. Don't be tempted by these cheap remotes where you get a code book with them, many of them will NOT operate certain functions of the TV, including tuning. Beware!
Your problem seems to be that you want to tune the Sky box into the TV via the RF output of the box. Why not connect it by scart socket? You'll get a much better picture and if your set is nicam, stereo sound too.
I wish you luck!
Sep 12, 2009 | Televison & Video
How to make tosiba tv show the movie that is playing on a tosiba
You may need to manually switch the input on your tv via the menu on the front panel switches if your universal remote does not have an input button or it just wont respond.
Aug 25, 2009 | Toshiba 27AF43 27" TV
Need a code for universal cox cable remote to turn on and off Kenwood KR-V-8040 Receiver
[PDF] Cox Manual File Format: PDF/Adobe Acrobat - View as HTML
not respond to the Cox Universal Remote Control after trying all of the codes listed for your brand,or if your brand is not listed at all,try searching for ... - Similar pages
  1. More results from »
  2. Universal Remote Control Codes Apr 17, 2009 ... More Cox Remotes, Includes Cox Digital Interactive, Universal DVR, Navigator, Millennium and Model ER1 PDF manuals. Cox Universal Remote ... - 73k - Cached - Similar pages
  3. How to Program a Cox Universal Remote for Your TV | How to Program a Cox Universal Remote for Your TV. Have you ever dreaded programming your universal cable remote for your TV? Many people put off this very ... - 52k - Cached - Similar pages
Jun 01, 2009 | Kenwood Audio Players & Recorders
I have a 2004 Toshiba color TV 27".
simply look up the codes or contact your cable company for the toshiba tv codes to input into the cable remote. you may also be able to operate the cable box via the TV remote if the correct codes from the tv owners manual are entered.
Nov 25, 2008 | Toshiba 27A33 27" TV
TV -Ferguson (Wide Screen) model no: W7023U. unable to operate either with remote control or manually.
Is it possible it has locked itself? It can be locked in 3 ways according to manual.
1. by pressing the remote's stand by key for more than 3 secs.
2. By programming an auto stop.
3. By putting it on stand by after programming a wake-up time.
Flashing "red on" indicates it is locked. It can only be turned on by the remote. Press any number key on the remote to unlock it.
Aug 16, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
