Electronics - Others Logo
Posted on Jan 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
USB device malfunction
I have operating system windows XP svpk3, but the USB pen drive is not detectig, it requried deriver, can you help me to get the...
Cleverer2
Level 2:
  • Expert 298 Answers
  • Posted on Jan 18, 2009
Cleverer2
Expert
Level 2:
Answers
298
Questions
0
Helped
98934
Points
775
Did you reboot the PC after SP install?
If not... shutdown, restart without USB device installed, reinstall SP, reboot, Try USB device again.
Fixed!
2helpful
2answers
Im using v165w pen drive.when i connect to pc its not detecting the USB.i also tried with another pc also,the same problem occurs.i tried with both windows7 and windows XP..Wat can i do to solve the...
If two computers(and two different operating systems) arenot detecting the pen drive then most likely there is something wrong with thatpen drive and it needs replaced.
In Windows 7 you can check the following.
Plug the pen drive into an available USB port.
Click the Windows Orb(Start menu in XP). Right-click on "Computer"(My Computer in XP) thenleft-click "Manage". If "Computer" does not exist in the "Start" menuthen it should be on the desktop.
In the left pane click "Disk Management".
In the right pane, the first column will show you the drives currentlyinstalled(C:, D:, E:, etc). C: is typically the drive your operating system isinstalled on. To check what drive is what, just click the Windows Orb(Startmenu in XP) then click "Computer"(My Computer in XP). If you see the same driveletters under "Computer" that you see in Disk Management then the pen drive isnot being detected. Do you hear any sounds coming from Windows when you plug inthe pen drive? If you have a different pen drive is that one beingdetected? Are other USB devices detected when plugged into thecomputer?
How to disable pendrive using ashampoo powerup xp platinum
Dear Abhi:
Pendrive is a portable USB flash memory device that can be used to quickly transfer audio, video, and data files from the hard drive of one computer to another. With a construction that is small enough to fit into a pocket, the pen drive derives its name from the fact that many of these usb drive devices resemble a small pen or pencil in size and shape.
So, you can remove safely from your computer same like your flash drive.
Please give me comments if you have made it.
Regards,
Angel
I have a 4 GB kingston datatraveller 120 pen drive
Try re-formating the Pen Drive. Also check your USB and HUB drivers in Device Manager
Pen drive shows device is write protected while formatting. So please give me solution so that I can format the Pen drive & use it again. Kingston Pen drive with 4 GB capacity. Using Windows XP...
if you see your pen drive properly you will find a lock that you need to switch to other side for unlock device
this lock make device write protected
hope it helped you
1helpful
My Kingston USB 2GB can't work in my desktop pc .
There are two most common causes of Pen Drive not working
1) The usb port You are connecting it has not enough power output to operate the pendrive (many older computers and laptops have this issue) solution buy an powered USB HUB one with a power adapter You put in a wall socket and then connect Your Pen Drive thruu this hub
2) Operating system lacks drivers for Your particular Pen (windows up to Millenium lack proper usb support and newer I mean XP Vista? (Not sure bout this last one) need administrative privileges to recognise some Pen Drive for the first time or even a driver diskette (some very rare cases).
Kingston dti/1gb
Have you tried finding the drivers for the USB Flash Drive?
Sometimes XP may need a compatibility drivers.
14helpful
5answers
Pen drive malfunction
when i fix the pen drive to the PC it throughs a massage "USB devive not recognized"
3helpful
5answers
Transcend pen drive problem
Dear Sir,
i have a transcend pen drive 2 GB which runs perfectly on windows XP on other computer but it is not recognised by Computer. My Motherboard is Asus and Operating system is Windows XP. Initially it used to show a message "One of the USB driver sttached to this computer has malfunctioned, windows does not requesnized it". How can I do solve the problem. My email : [email protected]
Inability to recognize Kingston pendrive in windows98
Windows 98 is not capable of recornizing the mass storage devices, but windows 2000 and XP, vista has the capability to automatically recognize the USB mass storage devices.
Thats why your Windows 98 is not recognizing. So, to use the mass-storage device like your pen drive you have to install device driver to your windows 98 system for your pendrive.
If you don't have the driver, then goto pendrive manufacturer site, there you can found the driver for your pen-drive for windows 98, download it, and install on your windows 98 system..... n njoy,,... :))
Thanks
Iqbal
[email protected]
5helpful
6answers
USB pen drive
I would suggest you post the Make and Model of the pen drive to get further help. tnx.
Top ASUS Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you an ASUS Electronics - Other Expert? Answer questions, earn points and help others
