Question about Panasonic DMR-E55 DVD Recorder
Panasonic dmr-e55eb-s what voltage is the zener diode t3d45 ?? thanks
Hello Brian. Its not a Zener, it appears to be some type of polarised VDR or similar device. I have just literally one hour ago repaired an E55. I was about to replace the STRG6353 and had taken the old one out. I thought it a good idea to check a few components before going ahead.. I did a diode check across td3 and it showed short circuit in both directions. So I disconnected both ends and then it showed open in both directions.. Read a bit more on various forums and decided it was ok to fit the new STRG. I made a much larger heat sink for it. The machine immediately came back to lift.
If you want a bit of moral support e-mail me at johnatjbrewerdotfsnetdotcodotuk. Happy new year..
Posted on Jan 04, 2013
In panasonic modeltc-29sf3 pls give me the working voltage of zener diode with color code gray red red and red yellow in power supplyn section
just read the model and then google it, beside, if you short them, you need to replace them with same value, and this will be determined by the circuit, if you did not change the circuit - just buy two new diodes and install them, do not bother with voltages as they have some tolerance and type will determine it.
Jan 27, 2015 | Panasonic Televison & Video
What is the zener volt
I'm not sure what your question is. A zener diode is a voltage regulator of sorts. The zener voltage is the avalanche voltage...the voltage that the zener diode will maintain when it's connected in series with an impedance, usually a resistor, IF the voltage across the zener diode and the impedance, in series, is greater than the avalanche voltage (zener voltage), and the polarity of the voltage across the zener diode is thus: positive cathode, negative anode (i.e., reverse bias). The excess voltage (the margin) appears across the impedance. Zeners are often used as voltage reference diodes in regulated power supplies. Does this answer your question?
Apr 16, 2013 | Computers & Internet
My hitachi 29in ctv power supply 110vac had a problem on zener diode will blown if we switch on the tv. what spare parts to change so that the power supply zener diode will not blown again and the supply...
The secondary output voltage comes out from is more than it should be there. That is why, the protection zener diode blows off, as soon as you switch ON the set. First find and repair the power supply regulator, for correct output voltage. Refer its repair book for details. After repair include the zener diode in place. OK.
May 08, 2012 | Hitachi Televison & Video
I need to know whether the Panasonic DVD recorder takes minus discs or plus discs DMR-E55EB/EBL
Hello there,
According to the manual, i believe that this particular model takes DVD-R discs.
I hope this helps! Thumbs up are much appreciated.
May 05, 2011 | Video Game Consoles & Games
Burnt Zener diode... Voltage spec??
On the cathode of the zener diode look for a filter cap and check its value the voltage of the zener should be less than the working voltage of the zener. Basicly its likely being used as a shunt regulator as protection and regulation of the voltage. When the zener hits a certain threshold it will breakdown and start conducting to ground until the supply regulates and then it will recover. If the filter cap for that voltage rail was 25V I would guess that the zener would probably be regulating between 12 and 20 volts. I'd pick a 15V Zener its probably +- %10 on the original and any system should be able to take a %10 tolerance as a general design rule.
May 07, 2009 | Emerson Televison & Video
Panasonic TC-21S10M2 TV
R2M diode is 130v zener, the missing diode is RM25 which is 55V zener for over voltage protection.
May 05, 2009 | Panasonic Televison & Video
Ziener diode
Yes, Zener diodes can work both on forward and reverse biasing. The primary difference between a zener diode and the ordinary junction diode is it is designed specifically to operate with a reverse bias voltage that is high enough to cause the the device to breakdown and conduct a high reverse current. Hope this answers your question and provides you with some help. If you need further assistance please let me know.
If you do not mind, would you please rate my help. I would very much appreciate it. Thanks
Dec 08, 2008 | HP Pavilion dv6000z Notebook
Panasonic DVD Recorder DMR-E55EB/EBL On turning this appliance on, the self check message appears and does not disappear, even after an hour or so. In the manual it says waiting until the message...
i have a Panasonic TV model no MDR-E55EB/EBC WITH FREE VIEW BUILT IN HOW CAN I RECORD TO A DVD RECORDER I CAN RECORD THE ANALOGUE STATIONS OK BUT NOT FROM THE FREE VIEW PLEASE HELP ME THANK YOU
Oct 18, 2008 | Televison & Video
UNKNOWN VALUE OF VOLTAGE ZENER DIODES
I was not able to find any service or schematic for this model. The colors means that the value is 22.6 volts zener diode with the other blue band indicating where the cathode is.
Could you tell me where or what other components this zener diode is connected to?
Jul 02, 2008 | Televison & Video
Panasonic DMR-E55EB cooling fan appears not to work
The fan is thermostatically controlled - it only works when the unit gets hot. The hotter it gets, the faster the fan spins.
Apr 30, 2008 | Televison & Video
Panasonic DMR-E55 DVD Recorder Logo
158 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
