Question about Garden
I have a ******* troy bilt snowblower it won't ******* stay ******* started can anyone ******* not refer me to ******* different ******* brands and leafblowers and other ******* things other than
One more time-it won't stay started
  • 36 Answers
The diaphragm in the Carburetor is probably bad. If you are mechanical it is not that hard of a fix. Of course this is assuming that you have cleaned out all the old gas and replaced it with 100% real gas. NO ETHANOL. I also keep gas treatment in all of my tanks and spare gas cans. Varnish from old gas makes small engines like snow blowers that are only used seasonally a Bi*** to start and keep running.
Order or go out to your lawn center and buy a new diaphragm, I bet it fixes it.
Posted on Dec 30, 2012
SOURCE: belts slippin on troy bilt horse
Have you adjusted the locking cam for forward. This cam is held in place with one bolt. The further you move it down the tighter it will make the belt
Posted on May 05, 2009
  • 4 Answers
SOURCE: Troy Bilt Rotor tiller, won't start
lac spark plug on motor pull cord if no spark take the pull start cover off and sand rust off fly wheel
  • 112 Answers
SOURCE: How to install belt on Troy bilt tiller:
With engine OFF If you put belt on engine pully and driven pulley then work the clutch handle you should be able to see how belt goes so it tightens when clutch is worked.
Posted on Jul 16, 2009
SOURCE: how do i put a troy-bilt tiller 3 hp.into free
The way to move without the motor running...
1.on each wheel pull pin in center of hub
2.push wheel closer to motor.
3.put pin back in to axle but not though hub
4.do the same steps to other wheel
now you can push tiller
Posted on Aug 05, 2009
SOURCE: where do i find serial numbers on troy bilt horse tillers
On the old Gardenways Horse the serial number is stamped into the top of a little flange on the side of the transmission just to the right (viewed from behind) of where the handles attach. It may be covered in gunk so a douse of mineral spirits and a little scraping will reveal it.
You can download the manual and parts list from the Troybuilt site. Enter "HORSE" for the model and the serial number.
Posted on Aug 06, 2009
Remove rim from Troy bilt snowblower?
Excellent. Put some grease on the axle before you put it back together so it comes apart next time.
Aug 02, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Augur wont turn on troy bilt model 2410 snowblower,stall s out when i engage the augur
ICE OR HARD PACKED SNOW IN BLOWER HOUSING
warm up or pour hot water down chute to thaw out
Feb 13, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Troy-Bilt Horse XP, Model 13bx79kt011 - Won't Move
You need to check the belt to the hydro units is connected properly and is tentioned and not slipping in the pilleys
May 31, 2013 | Garden
Brand new Troy-Bilt XP Horse, model 13bx79kt011 - Won't Move
Confirm the park brake is off. If a hydro-static drive tractor starts but engagement of the operator controls for the transmission drive results in neither a forward or reverse drive of the mower itself, the operator should check that the manual bypass controls have not been left in the activated (bypass) position.
Look in to where the lever connects and confirm the movement. You should be able to hear the hydraulic oil with a slight whine as you activate the drive forward pedal!
See page 18 for bypass setting?
Cut and paste link
http://www.troybilt.com/wcsstore/TroyBiltUS-CAS/Attachment/ownersManuals/riders/HorseXP_2012_769-07569[1].pdf
Jun 27, 2017 | Garden
Troy bilt snowblower 123cc starting problems
Carburetor might be gummed up with old fuel. I would recommend carburetor overhaul. That should be the fix. When storing your snowblower till next use, either run the engine until out of gas or add fuel stabilizer to fuel tank to prevent fuel break down that causes damage to carburetors when not used for a long time.
Dec 30, 2012 | Garden
How maintenance Troy bilt, 6.50 190cc 21" 2 in 1 push mulch mower with rear bag?
my troy-bilt 21" mulch mower 6.50hp/190cc won't start after it run for any amount time.
Sep 05, 2010 | Garden
Garden Logo
106 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
