posted by Brina1014 on Jun 23, 2007
I got my new phone yesterday. It works fine except for whenever I receive a call, it automatically rings with my default ringer, not whatever ringtone I set to the contact. I bought the ringtones that are set to contacts but the default came with the phone. How do I fix this?
Comment by Brina1014, posted on Jun 23, 2007
Update: I went to the Verizon store today and I was told that with the white MOTOKRZR K1ms (I'm not sure if that's the only colour/style, but I know for sure it's this one), Ringer ID won't work while the phone is on Ring AND Vibrate all the time. If it is, it will use the default for everybody.
Another solution I found is to turn the ERI Alert ON, not OFF. This will make the phone use Ringer ID AND Vibrate at the same time. However, this will also make the phone say "Verizon Wireless" before the ringtone starts and when you make a call before the ringing begins.
Best wishes,
Brina1014
Best wishes,
Brina1014
Best Solution
posted on Oct 29, 2007
If this doesnt work then your phone must be possesed..
1. Go to your phone book. Choose a contact.
2. Go to options. Then Edit Contact.
3. Now scroll down all the way to Ringer ID:__ and hit select it.
4. You should see a list of songs and sounds like silent, Vibe Dot.. etc
5. Scroll down until you want the ringer for that contact.
6. Once you found the ringtone hit select it. You should now have the ringtone for that contact. NOW hit "DONE" or it will not work! If you dont hit done it will use the DEFAULT ringtone provided by the phone. Also, if you have a memory card in your KRZR k1 and all your songs are on the memory card you wont be able to use it, move them to your phone memory so you can choose it from the list. mobiles24.com also can give you free ringtones too.. check it out.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Motorola MOTOKRZR K1 Cellular Phone
Email this problem
Email this problem
Can you Help with these Cellular Phones problems?
STICKY KEY - The * symbol keeps...
The * symbol keeps appearing... Answer This...
motorola krzr km1
motorola krzr km1
i need help uploading pictures... Answer This...
pls unlock my t mobile USA...
IMEI: 359425002784276 thanks in... Answer This...
Motorola K1 Locked to Fido
hi, i need some help i have a... Answer This...
Repair Service
Find Cellular Phone Repairman Near You:
