Question about Intel Motherboard
I HAVE CMOS BATTERY FAILURE PROBLEM WHILE BOOTING MY DESKTOP. WHERE TO FIND THE BATTERY AND HOW TO REPLACE IT
  • 34 Answers
You can find a replacement battery at any local retailer that sells battery watches. If there's a walmart in your area you can go there. Just take the dead battery with you so you can get the correct replacement.
Posted on Jan 22, 2009
    Problem Solver:
  • 14 Answers
Try changing watch battery in mother board
Posted on Jan 18, 2009
Desktop wont boot past floppy disk seek failure
There is a menu in the BIOS (set-up) menu that disables the floppy drive. This option enables or disables the floppy drive.
Aug 15, 2012 | Dell Computers & Internet
When booting my dell optiplex GX270 desktop,"alert! system battery low pops out, press F1 to continue or F2 for setup utility" and the screen colour chances. please, what do i do?
i think this is the problem about your cmos battery so first you change your cmos battery contained in your lap top.it is attached with your laptop motherboard.
Sep 03, 2011 | Dell OptiPlex GX270 PC Desktop
Error is the firmware has detected that a coms battery failure occurred
Hello!
i just want to inform you that CMOS battery failure is not a big deal
you just need to replace CMOS battery from the motherboard
CMOS battery is responsible for date and time management in you PC
also it gives a refrence point in time and space when booting
so if you are a serious programmer you may change it immidiately
and if you are a normal user and you are least bothered with system time and date then
you may keep ignoring this message.
thanks and regards
kindly rate this solution!!
Feb 10, 2011 | Intel D945GCLF Motherboard
Hi... i'm using DG31PR intel motherboard. for the past few months am getting these errors while booting... CMOS CHECKSUM ERROR CMOS BATTERY FAILURE i've replaced many new CMOS batteries.. but still not...
I would reset the CMOS. This is done by removing that CMOS battery. Also, find the jumper that says "J-21" and move it to the alternative position. The jumper is located on the motherboard. Boot up without that battery in , and choose "Reset" that should clear out the junk. Also, replace the battery. Go to www.intel.com and look for a "bios update" the DG is a value board. a huge value board and one of Intel's bummer boards. Update the firmware. Once you do that, you should be good to go.
Nov 07, 2010 | Intel D101GGC Motherboard
When my PC is booting up it displays a warning about 'low voltage'. It is a Dell home computer that is several years old but has been excellent. Do I have to replace something electrical?
Hi! If you are using a surge protector, try to plug the machine directly to the wall then check if you will get the same error message. If yes then try to check if the cmos battery is securely placed on the motherboard, if yes then try to reseat the cmos battery. If all things fails try to call dell support and ask for a cmos battery replacement if your system is in warranty then they will replace it.Hope this helps...
May 30, 2010 | Dell Dimension 8250 PC Desktop
''Firmware has detected cmos battery failure''
CMOS battery in the motherboard much measured .3 volt which is a Lithium coin cell battery.check whether the battery gives the correct measurement (recomend to use branded battery like from sony).
if the measurement is correct then reset your BIOS setting by removing all the jumper in the motherboard for about 60 secs.and place it again and start your pc;set yr BIOS to default setting,
let me know if it comes handy to you
Dec 04, 2009 | Intel Computers & Internet
My PC is not booting!!
first try to boot with new ram or try your ram in other cpu to confirm that its due to ram problem or something else......then try to replace your cmos battery or chk it with multimeter whether its working or not then try to change SMPS with new one............
Sep 28, 2009 | Computers & Internet
Desktop GX270 eats moniters, not booting now
Motherboard failure
Likely a capacitor failure on the motherboard
Jan 30, 2009 | Dell OptiPlex GX270 PC Desktop
Desktop won't complete boot
Open up the desktop and replace your CMOS battery, or atleast test it and see if the re-booting stops. If not and you have your XP installation disc you may have to do a system repair, start your pc with disc in and press enter when prompted, but make sure that your cd drive is set up as first boot in the bios.
Dec 11, 2006 | HP Compaq dc5100 Small Form Factor PC...
Intel Motherboard Logo
119 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
