Question about Water Heaters
What does E4 mean on Kruger water heater
Not getting any hot water, changed battery do not have warranty book
5 Suggested Answers
  • 234 Answers
SOURCE: I have a Rheem EcoSense hot water heater and all
Have you try to reset the power to the heater?Then turn the hot water facuet on to see if it will start up.
Posted on May 02, 2009
  • 7 Answers
SOURCE: no hot water in electric water heater
warranty is 6 yrs on parts
Posted on Mar 17, 2010
  • 349 Answers
SOURCE: Rheem hot water heater
Check the relief valve,drain and element's,water lines to make sure that they are not the source of the leak. If the tank is leaking you may be able to fix it for now.
The tank depending on condition of the tank if it is pretty sound. Clean up the area of the hole with sand paper. Go to any hardware store and get a JB Weld two part kit. JB Weld will fix almost anything . You can go to www.jbweldit.com for more information about this product. I wish you well and hope this will fix it for you.
Posted on Jun 27, 2010
SOURCE: how to change a thermostat on reliance 606 hot
I wrote a page for changing water heater thermostat.
The photos take you through step-by-step
I recommend replacing both upper and lower thermostats so it eliminates thermostats as possible cause if water heater keeps overheating.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
The Reliance 606 manual shows your water heater uses generic upper and lower thermostats from hardware store.
http://www.reliancewaterheaters.com/lit/om/manuals/185761-000.pdf
Likely the thermostat will solve the problem:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Posted on Nov 10, 2010
I need to know the efficiency of my John Woods electric hot water heater. Model JW840S40N-AV 400. item 9200604016-B4670. serial 1623A029614 Thanks
JW=John Woods
8=8 years warranty
40=40 gallon
S= (profile) S=standard, T=tall
40=wattage, 40KW
(Don't know what the rest means)
Sep 25, 2017 | Water Water Heaters
Hot water tank wont heat water, how do you relight or resat, its a reliance self cleaning 808
Reliance Water Heater Literature ' Owner's Manuals ...
www.reliancewaterheaters.com/resources/instruction-manuals
Welcome to the Reliance Water Heaters Owner's Manual and Installation ... 9 40 EKRT - 40 Gallon Tall Self-Cleaning Electric Water Heater - 9 Year Warranty . ..... 10 50 DHPST - 50 Gallon Electric Heat Pump Water Heater - 10 Year Warranty .
How to light the pilot on a Reliance 606 water heater ...
? 3:27
https://www.youtube.com/watch?v=VU2PsFVd2ug
Jul 12, 2011 - Uploaded by kilroywashere123
How to light the pilot on a Reliance 606 water heater ... How to fixwater heater, will not stay lit - sealed combustion no hot water - Duration: ...
Reliance Water Heaters - Consumer Affairs
www.consumeraffairs.com > Homeowners > Bath & Plumbing
Rating: 1.6 - ‎84 votes
I purchased a Reliance 606 water heater in 2010. ... That they don't TELL you there's areset button or that I'm having conspiracy thoughts ... After several attempts, I was able to relight it. ... It's heading to the junk pile and I will purchase a new reliable (NotReliance) ... Checked breaker and changed breaker still no hot water!
Dec 28, 2015 | Reliance Water Heaters
Are Kruger tankless water heaters good?
One thing they don't tell you about tankless heaters is that when they turn on, they may cause the lights in the house to flicker. Make sure that you have a good breaker panel (one that is relatively new with plenty of capacity) and run a circuit specifically for the tankless heater.
Mar 02, 2014 | Rinnai Water Heaters
No hot water. Display reads ER3.
Hi, If you have the book for this system, then go to the problem solving to the rear of manual. This will tell you what code ER3 means, and what you need to do to correct it.
If you dont have the manufacturer's book then try to down load it!.
All boilers and water heaters have different fault finding codes, so can-not give any more info, unless you can tell me the exact problem.
Thanks Paul.
Aug 22, 2010 | Water Heaters
Richman gas lp tankless hot water heater. used for infloor heat and kitchen and bathroom hot water. getting c2 and 11 error code. water temp. setting 120. ran great last year. made no changes. we have very...
I had the same problem with my Paloma a year and a half after installation...contacted Rheem\Paloma\Richman customer service (800-432-8373) and they recommened a local installer in my area. The technican diagnosed the problem as the "flow control valve"; he managed to get Rheem/Paloma to cover the part under warranty...I only had to shell out the money for the install.
Nov 09, 2009 | Rheem Tankless Hot Water Heater...
Blinking red light,
It seams alot of people have this same problem All must get ahold of manufacturer and report this it must be there pump's thank you for useing fixya
Jan 14, 2009 | Noritz 6.3 Gallon Residential Tankless...
A.O. Smith Water Heater Problems
someone has messed with the differential setting - so the water heats to correct temp but cools too low before coming on. get book -easy fix
Oct 26, 2008 | Water Heaters
Water Heaters Logo
189 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
