Question about Garden
Troy bilt snowblower 123cc starting problems
Will not stay started.
    Novelist:
  • 157 Answers
Carburetor might be gummed up with old fuel. I would recommend carburetor overhaul. That should be the fix. When storing your snowblower till next use, either run the engine until out of gas or add fuel stabilizer to fuel tank to prevent fuel break down that causes damage to carburetors when not used for a long time.
Posted on Mar 08, 2014
4 Suggested Answers
  • 71 Answers
SOURCE: Can start a troy bilt pro chipper.
i need to know what kind of engine does this machine have ..you said it hadnt been started in a few years?? was there old gas in it when you tried to start it??if so you need to first drain it and before you put fresh gas in it make sure you dont have dirt or rust in the bottom of the tank take a flash light and do a GOOD visual inspection. if there is any dirt or rust you may need to remove the tank and clean it re assemble it and put fresh gas in it .if this dont work check to see if it has a inline gas filter if so replace it if not it should have a setiment bulb.. carefully remove it (use caution when removing it to avoid damage to gasket)..dump fuel bowl and wipe it clean put a cup of gas in the tank and see if you are at this point getting gas to the float bowl if you are go ahead and replace float bowl and fill tank put a couple of table spoons of marvals mystery oil in tank you can get it at any parts store it comes in a red bottle and try to start it if this dont work i can talk you through a couple more procedures i know beond a doubt if i was there i could get it going and chances are if i walk you through a couple more procedures you can do it if you have any mechanacle aptitude email me at mrdmburns@cableone.net
keep me posted i will help you through it hope this helps but if not we will keep at it good luck and keep me up on results.
Posted on May 07, 2009
  • 5 Answers
SOURCE: finding a shredder screen for troy-bilt
Just found some parts for my Troybilt Gardenway chipper-vac Model 47279 on this website http://www.partsandservice.com/bin/ipl.cgi
I would think they might have something for your machine.
Posted on Oct 12, 2009
  • 113 Answers
SOURCE: replacement blades for Troy-Bilt chipper-shredder
The knife kit for the 47042 and 47044 Tomahawk Pro chipper is part number 1772231MA.
There are several for sale on Ebay or from a Murray dealer
Posted on Aug 18, 2010
How do I find the carburetor adjustment. in fact how do I get at the carb??
take it in to a mower shop for the repair as you exhibit very limited mechanical knowledge
the problem is that there is a blocked main jet or fuel flow restriction in the carby
Sep 08, 2016 | Troy-Bilt 123cc 21-in Single-Stage Gas...
My Troy bilt squall 2100 snowblower does not idle steady. It races and slows while idling.
It sounds like the carb needs cleaning and readjusting, or the fuel filter is clogged. Good-Day! Remove and clean out carb, it may be dirty inside.
Nov 13, 2014 | Troy-Bilt Squall 2100 208 cc 21-in...
Remove rim from Troy bilt snowblower?
Excellent. Put some grease on the axle before you put it back together so it comes apart next time.
Aug 02, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
Snowblower troubleshooting
Either the gas is old (replace it with fresh gas) or the carburetor needs cleaning inside. Unless, of course, someone has tampered with your idle mix adjustment screw.
Feb 18, 2014 | Troy-Bilt 179cc 24-in Two-Stage Gas Snow...
Augur wont turn on troy bilt model 2410 snowblower,stall s out when i engage the augur
ICE OR HARD PACKED SNOW IN BLOWER HOUSING
warm up or pour hot water down chute to thaw out
Feb 13, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
2410 troy bilt snowblower wont start...no spark
unplug the switch to make sure it isnt just stuck in off position *(internally stuck while the switch will still move) If it starts you can unstick the switch with some WD and a couple back and forths with the key.
If you still have no spark you are gonna need a new coil.
Dec 31, 2012 | Garden
I have a ******* troy bilt snowblower it won't ******* stay ******* started can anyone ******* not refer me to ******* different ******* brands and leafblowers and other ******* things other than
The diaphragm in the Carburetor is probably bad. If you are mechanical it is not that hard of a fix. Of course this is assuming that you have cleaned out all the old gas and replaced it with 100% real gas. NO ETHANOL. I also keep gas treatment in all of my tanks and spare gas cans. Varnish from old gas makes small engines like snow blowers that are only used seasonally a Bi*** to start and keep running.
Order or go out to your lawn center and buy a new diaphragm, I bet it fixes it.
Dec 30, 2012 | Garden
I have a troy-bilt squall 2100 snowblower that wont start. Primer bulb doesnt seem to do anything. Use of starting fliud in the air intake will get it to start briefly. Removed carb bowl and there seems...
I share your frustration. We just had our first snow fall of the season and my Troy Bilt Squall 2100 would not start or do anything. The snow blower is well maintained and does not have 2 hours use. I use 0-30 synthetic oil and installed fresh gasoline. It is simply maddening to have plunked down close to $500.00 and have a useless snow blower. Trying to get through to Troy Bilt's help line is next to impossible.
Nov 21, 2010 | Honda Garden
Troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
May 29, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
489 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
