Question about Intel Motherboard
WHERE AND HOW TO FIND CMOS BATTERY ON INTEL D945GNT MOTHERBOARD
I M GETTING THE MESSAGE ABOUT BATTERY FAILURE BEFORE BOOTING OF MY DESKTOP. ANYWAY THE COMPUTER GETS BOOTED. I WANT TO REPLACE THE BATTERY. WHERE IS IT LOCATED ON MOTHERBOARD TO REPLACE IT. HOW TO REMOVE THE BATTERY AND PUT THE NEW ONE.
  • sattikch Jan 18, 2009
    NOT AN APPROPRIATE ANSWER. IF I HAD THE MANUAL, I WUDN'T BE ASKING THE QUESTION. I DO NOT RECOGNISE HOW CMOS BATTERY LOOKS. LET ME KNOW THE LAYOUT AND LOCATION OF CMOS BATTERY AND HOW TO REMOVE IT
    Problem Solver:
  • 14 Answers
Look at your manual
Posted on Jan 18, 2009
  • 1 more comment
  • foster clinton Jan 18, 2009
    well its basically like a little watch battery
    and on that perticular motherboard it is next to the mem. slotss
    it does have somthing to do with the problem too
Unit starts/stops-starts/stops after replacing 3v battery?
When you say starts/stops (etc) are you saying it just keeps trying to reboot? Or are you getting a message such as boot disk not found press any key to restart? Replacing the 3V battery will cause the CMOS to reset to factory defaults. You may need to go into the CMOS and make setting changes to point to the proper disk drive for booting. You may even have to change the type of disc drive since there is now the old MBR as well as the newer GPT format. Also, there is the possibility that if you are upgrading you may need to use the legacy CMOS instead of the UEFI that many newer mainboards come defaulted to. Any error in the CMOS settings can cause a boot failure.
Apr 03, 2016 | Gigabyte GA-H55M-USB3 Socket 1156/ Intel...
Error is the firmware has detected that a coms battery failure occurred
Hello!
i just want to inform you that CMOS battery failure is not a big deal
you just need to replace CMOS battery from the motherboard
CMOS battery is responsible for date and time management in you PC
also it gives a refrence point in time and space when booting
so if you are a serious programmer you may change it immidiately
and if you are a normal user and you are least bothered with system time and date then
you may keep ignoring this message.
thanks and regards
kindly rate this solution!!
Feb 10, 2011 | Intel D945GCLF Motherboard
Hi... i'm using DG31PR intel motherboard. for the past few months am getting these errors while booting... CMOS CHECKSUM ERROR CMOS BATTERY FAILURE i've replaced many new CMOS batteries.. but still not...
I would reset the CMOS. This is done by removing that CMOS battery. Also, find the jumper that says "J-21" and move it to the alternative position. The jumper is located on the motherboard. Boot up without that battery in , and choose "Reset" that should clear out the junk. Also, replace the battery. Go to www.intel.com and look for a "bios update" the DG is a value board. a huge value board and one of Intel's bummer boards. Update the firmware. Once you do that, you should be good to go.
Nov 07, 2010 | Intel D101GGC Motherboard
''Firmware has detected cmos battery failure''
CMOS battery in the motherboard much measured .3 volt which is a Lithium coin cell battery.check whether the battery gives the correct measurement (recomend to use branded battery like from sony).
if the measurement is correct then reset your BIOS setting by removing all the jumper in the motherboard for about 60 secs.and place it again and start your pc;set yr BIOS to default setting,
let me know if it comes handy to you
Dec 04, 2009 | Intel Computers & Internet
CMOS/GPNU Checksum Bad 0085
You may have a bad CMOS battery. Does it do this on restarts as well as cold boots.....if you only receive this message on cold boots, then you have a dead battery.
Nov 26, 2007 | Intel Motherboard
Intel Motherboard Logo
96 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
