Our netflix is running through Apple TV, but after a few moments the screen goes black and only audio remains, can anyone help?
    Sergeant:
  • 475 Answers
Try to disconnect everything then try to reconnect the wiring in the back of it maybe something came lose.
Posted on Dec 30, 2012
SOURCE: LTV-27w7 blackscreen
Have you tried unplugging overnight? Sometimes mine gets screen garbage and that clears it up. Of course, now it says "Auto Scan Required" every time I power up. Maybe I should've grabbed that after Xmas 32" at Fry's for $400.
Posted on Dec 28, 2007
SOURCE: westington LTV-27w7 HD black screen
If the power light stays on green, I would look tward a backlight issue. If you can see any image at all then the backlight controler or the backlights are bad. If there is nothing then if could be a power supply overheating or an inverter failure. More than likely as the unit heats up a failed solder connection is loosing contact causing the screen to go black.
Posted on Feb 10, 2008
SOURCE: goodmans flat screen TV.Blank screen
If it is a LCD TV, and there is a faint picture, it is probably the backlight or inverter board (probably the latter). This is a common problem (especially with PC monitors).
Do an internet search for your model and inverter, you may be able to replace it.
Make SURE you REMOVE the power lead before opening the set !!!!
Posted on Mar 03, 2008
SOURCE: Picture blacks out after a few seconds after turning on the tv
Anytime an LCD has a shade of pink, that means the CCFL lamps are about to go out. Now that you have a black screen, I'd say you just need some new bulbs.
Posted on Oct 04, 2008
javswr
  • 44 Answers
SOURCE: sanyo ce32ldy1b lcd 160gb black screen with sound
It sounds like you have a power supply problem, this powers the inverter! Where you just replaced the inverter, we could assume it is good! Look for some bad caps (capacitors) on the power supply board. They will look bulged on the top an may be a little leaky (brownish stain). The power supply can fail on some output and be good on others. Was the back light inverter new? If all else fails, see if you can return the back light inverter and get another! I hope this is helpful!!
Posted on Mar 02, 2009
I have a 50inch LG TV that when switching between programmes the TV goes blank for a moment
Are you using cable and if so which company and box?
ELECTREPAIRUSA@ELECTREPAIRUSA.COM
Dec 07, 2016 | LG Televison & Video
Sony flat-screen bravia tv picture goes black but keeps playing audio when playing Netflix or DVDs.
your dvd player needs its own connection as does netflix and cable,get a new hdmi cable for each
Jul 11, 2015 | Samsung Audio Players & Recorders
How do you reboot anapp
You can remove the app from an iPad, by keeping your finger a few seconds on the app. When they app start wiggling, toy can press the top left x and answer yes, to remove it. Then from the App Store download the same app again. You see it with a cloud symbol, because you already bought it.
To reset the iPad, just press both the on / off switch and the home button for 10 seconds. The screen goes black and a few moments later the Apple loge appears. Wait till it is gone and a few moments later, you can press the on of button again.
Mar 11, 2015 | Apple Ipad I-pad
I can't connect to netflix streaming. I have Verizon Fios Wi Fi but I can't find where to put in the Network number or the password using the TV menue. Please help me. THank You!! Al Gordish
The tv is on in HDMI and the Apple tv on. When I turn my TV on an Apple comes on the screen and it takes awhile to establish itself, it disappears on again and the circle goes around until on the screen from the top >top films>Films>TV programs>music>iTunes >computers,next line
netflix I click on Netflix ,on the screen they ask Who is watching Netflix answers:kollagu,kids,sign out.
it seems to me that you have not succeeded in the registration phase. I have not counted how often I failed. I can not lead you through it because we do not have an official access to Netflix in this country. So we have to go a backway to get to it.
i am sorry if I have misunderstood your question, but know how I can use my Netflix
kolbrun
Feb 07, 2015 | Panasonic Viera TH-50PZ80U Plasma TV
The picture on my TV goes black after few seconds
Hi my name is Roety,
I can help you with your issue ,
Sounds like a lamp going bad
No model listed makes it hard to guess here
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Dec 15, 2009 | Televison & Video
TV goes black, won't power off
If the power indicator remains on (or LED remains green) when the unit goes dead, you will need to replace the main board to resolve.
Dec 22, 2008 | Vizio L32 32 in. LCD HDTV
DLP Projection tv, Models WD-52631,57731,65731. The tv powers on but the screen remains black, the audio comes on but after approximately 30-40 seconds,the audio starts to skip and then the entire tv...
DLP Projection tv, Models WD-57731, The tv powers on but the screen remains black, the audio comes on but after approximately 30-40 seconds,the audio starts to skip and then the entire tv system shuts down. I reset it a few times but that doesn't change the problem
Jul 26, 2008 | Televison & Video
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
Electro Med Services...
