Question about Zanussi ZBF360X Electric Single Oven
My zanussi oven will not switch on
The oven will not turn on,power is on as clock is set but when dials are turned the oven is dead
  • 1462 Answers
SOURCE: zanussi oven wont work. clock flashing 'auto'
you need to set clock before oven will work. do you still have instruction book as it will tell you there how to do it
Posted on Jun 19, 2008
SOURCE: Setting Clock and Timer
Worked it out for myself - no solution needed now thank you.
Posted on Jun 22, 2008
  • 417 Answers
SOURCE: Zanussi lower oven not working
You should try to get a replacement dial first and go from there.
Posted on Oct 14, 2008
SOURCE: clock
Hi this is propably too late now but we moved in to our new house six months ago and have a Zanussi ZBF 360 oven, and had no idea how to set the timer / clock. After fiddling around with the oven clock for the last 6 months i managed to set the clock. It shouldn't be much different to the one you have. Hope this helps you and others in the future.
Click the middle button until the little red things on the screen moved round to the clock symbol, then press + or - to get to the correct time, once you have done this it will flash for a few seconds then it will stop flashing and the clock is set. The same goes for the timer to set it when you want to cook something for a period of time eg: ten mins.
As for getting the oven timer to turn it's self on and off I am still messing with it and when i have mastered it I will let people know.
Posted on Feb 01, 2009
  • 142 Answers
SOURCE: zanussi zkc6040 oven keeps switching power off
overheat stat or cooling fan.
Posted on Sep 14, 2009
Oven won't turn on, had a power outage on the street 3 times today. Tried flipping the fuse, but nothing has happened. Any suggestions? Not sure which model Zanussi it is, except it is not brand new!!
The electronic clock/timer must be in manual mode for the oven to operate. When the power to the oven is cut the electronic clock/timer reverts to automatic mode when the power comes back on.
Mar 07, 2011 | Zanussi ZBS963X Electric Single Oven
The bottom oven on my zanussi zuq 875 has stopped working. No power indications of any kind.Top oven works fine. Followed instructions in manual but no power at all.ie; indicator lights, fan ,oven light....
Have you checked that the timer clock is set and not flashing,because the rest of the cooker will work after power outage but for the main/fan oven to work the clock needs resetting.
Hope this helps.
Jun 13, 2010 | Zanussi Ovens
My oven is saying "stop" . Previously to this is was showing F02 and the fan wouldn't turn off. We turned the main switch for oven off and back on and it now says "stop"
Previous fault F02 is indicating an overheat fault- service manual says to replace main electronic control board. However, switching off at wall has reset the clock- you need to set the time before the oven will work-press middle button until small triangle is next to clock icon, set time using temperature dial. Once clock has ben set, try using oven to see if F02 fault reappears- sometimes switching off at wall will clear fault. Good luck!!
Mar 16, 2010 | Whirlpool AKZ159IX Oven
Turn off the timer on an old imperial st george
I have this exact same oven and this "feature" annoys me no end. To turn it off ... turn the clock dial to PAST the time that the timer dial shows. EG: If your timer dial is showing 6, turn the clock dial so that it rolls past 6 o'clock. This will pop out the timer dial and thus turn off the timer, allowing you to use the oven normally.
To stop accidentally pushing/turning that timer dial, I removed the knobs. Good luck.
Jan 23, 2010 | Ovens
Main oven does not heat up
When you turn the main oven on, does the oven fan switch on?
When you turn the main oven on does the cooling fan come on?
Does the dial illuminate when the oven is turned on?
Does the oven thermostat neon come on the the oven is switched on?
Have you had a power failure recently and have not set the clock?
Are you sure that the clock/timer is NOT set and in manual mode?
Dec 13, 2009 | Stoves 720EF Electric Double Oven
Oct 14, 2008 | Zanussi ZHQ575 Electric Double Oven
Zanussi oven wont work. clock flashing 'auto'
Jun 18, 2008 | Zanussi ZBQ665 Electric Single Oven
Clock
May 07, 2007 | Zanussi ZBF660 Electric Single Oven
Aeg oven
cant see controls on pic so this is guidance turn function dial to "oven" you may be able on this dial to select fan or convential oven. turn stat up to required temp. it is so easy that i just wonder if you haqve another problem. the usual is the clock set to "auto" in error. drag you handbook out and set the clock making sure you get in on manual. easiest way is to switch off at the wall and start from scratch. get back to me if this does'nt help
Apr 19, 2007 | AEG U7101-4 Electric Double Oven
Zanussi ZBF360X Electric Single Oven Logo
Top Zanussi Ovens Experts
ashburton
Charles T Nevin
Charles T Nevin
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
