Kitchen Ranges Logo
A
Anonymous Posted on Dec 30, 2012
Wolf range griddle won't light - Wolf Range Kitchen Ranges
3 Related Answers
A
Anonymous
  • Posted on Sep 04, 2008
SOURCE: Wolf Gourmet Range oven lighting delay
UPDATE to Solution #1: I just went to the Wolf Appliance website and found that the recall is still active, at least for the 48" models. Here's the URL: http://www.wolfappliance.com/recall.aspx There are instructions, affected models and serial numbers, etc. You can also call the "Rework Hotline" at 866-643-6408 or send an email to [email protected]
Peter Hampton
  • 193 Answers
  • Posted on Apr 26, 2010
SOURCE: Wolf Commercial Gas Range: turning knob on and off very difficult
easy pull the tap apart and clean it with metho and repack it with gas tap grease and take note how you pull it apart also watch out for the spring in side it
aquatom
Thomas Rutkowski
  • 109 Answers
  • Posted on Oct 08, 2011
SOURCE: Wolf gourmet gas range/oven 36"--oven lights and
Check the temp sensor as this may be on the brink!
How do I unlock my cooktop
Does anybody have and answer to that question? How do I unlock my cooktop?
1helpful
We purchased a wolf 36 in range 3 months ago and we keep getting a red light blinking light error message. We have had it serviced twice, but the problem persists. Has anyone experienced this problem?
Oven or griddle indicator light flashes.
• Turn knob off, then back on. Flame was lost and unit
entered safety lock-out mode.
contact your dealer or the warranty phone number to get step by step instructions to turn off.
Rumbling noise when starting the gas griddle on the 48" Wolf range
my griddle is also heated with propane and makes this noise. i have come across another home with propane and a wolf griddle that also makes this noise...did you resolve this issue, cause I'm interested in the result you found?
2answers
Have a Wolf Range Model A-6-9 half the burneres don't light.
I have the same model Wolf Range and need 2 of the Robertshaw SM4 spark modules for it. Robertshaw says they are discontnued. Where can I locate 2 spark modules?
Oven gas turns off
If your Wolf has pilot light, most cases dirty pilot light (flame looks yellow, normal flame looks blue), you have to disassemble the pilot light to clean it, thermocouple connection is loose, bad thermocouple or bad oven safety valve. you can try change the thermocouple first, if it did not solve the problem, then it will be bad oven safety valve. You can buy thermocouple thru Hardware store. Have fun.
Top Wolf Range Kitchen Ranges Experts
Paul Carew
john h
ADMIN Andrew
ADMIN Andrew
Are you a Wolf Range Kitchen Range Expert? Answer questions, earn points and help others
