Warsh fills with water but will not run, just humms
  • Washing Mach... Master
  • 17,130 Answers
Possible that the motor or the Motor capacitor has failed. Please check for free movement of the spindle, if not it can be stuck up and will need to be removed and reset a possible bearing failure.
check this link: bearings failure
Posted on Dec 31, 2012
I turned on the jets before tub was full. Now all i get is a humm. i think i may have an air lock. not sure what to do?
Fill your tub and turn the pump on. Get under the tub down by the pump and while the pump is running, loosen the top pump union until some water starts spurting out. Once you loosen that pump union you should hear a loud swoosh of water kicking through the pump then you can tighten down the pump union.
Rod
www.uspartscenter.com
Feb 03, 2013 | Home
Has power, nothen works
Hello & Welcome to FixYa
If it has power but nothing is working then first check the control, if the lights are there on the control, then try to hear if the motor is running and if it does fill with water. If it fills with water and you hear a humm/buzz sound from the bottom panel then it is the motor that is bad and needs replacement. If it is completely dead then it is the main board also known as the electronic control that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 12, 2010 | Kenmore 18 in. 14432 / 14439 Built-in...
No water flowing into drum, water supply is fine, just humms
My Samsung washer was not filling with water after cleaning the debris filter. All I did to fix it was to dump a half gallon of water into the tumbler, then I ran the beginning of the rinse cycle and it worked. It seems like the pump needed to be primed.
Sep 16, 2010 | Samsung WF337AA Front Load Washer
Washing machine will not fill with water. only agitates. will drain and will not spin only humms
unit should not agitate with no water. pressure switch has to be satisfied to begin wash cycle. what kind of washer?
Jun 21, 2009 | Washing Machines
Won't fill
check to see if the water is turned on? do you hear a light buzzing or humm noise?
Jul 26, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
