Question about Samsung 3.5 cu. ft. High Efficiency VRT Front Load Washer
Samsung front loader not spinning at high speed
Will not reach full speed or doesnt spin at all
  • Donna Smith Dec 30, 2012
    It was the debris filter in front of machine filled with hair eeewwww!!!Check same on front loaders monthly
  • Samsung Master
  • 17,129 Answers
Yes ! this is related to fabric and hair accumulation and so it will be best to check the drain filter when you experience this issue.
Posted on Dec 31, 2012
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: my samsung vrt front loader
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Aug 28, 2010
  • 6277 Answers
SOURCE: Samsung Front Loader P801 5
First the 'E6'. The only Manufacturer's decode I have for Samsung 'E6' is 'water temperature rising/ falling too quickly, check thermistor'. I would go through the balancing act (detailed below) and then see if it recurs. If so it's a service call I'm afraid ;-0(
Now the dancing
Although you say it's level I would recommend you try my method to make absolutely certain before considering something inside ;-0)
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly!
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Posted on Apr 07, 2011
Will not go into final spin
Just a Idea, belt is slipping this is why when it is empty it works on high speed when full its to heavy and belt slips
May 06, 2010 | Frigidaire HE 3.1 cu. ft. Extra Large...
Maytag neptune model mah 4000 awq has clothes that are wet when done and a small pool of water in the tub (front loader), door locks, motor agitates and spins back and forth, pump hoses are clear, during...
check to see if the door locked is lit up and the door is locked. if it is not locking it won't spin full speed. the last one I had needed a wax motor to lock it and a new control board since the wax motor shorted out the control board
Nov 04, 2009 | Maytag Washing Machines
Front loader, will not spin at high speed drain
Drain strainer on output side of pump could be clogged a little.
Sep 11, 2009 | Frigidaire ATF6000ES Front Load Washer
My clothes is wrinkles by my front loader washer
SPIN SPEED IS TOO HIGH- USE A CYCLE WITH A LOWER FINAL SPIN SPEED.
Jul 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
During spin cycle washer spins fine but toward the end of the cycle it spins out of control like it is out of balance? Any help is greatly welcomed.
Some front loaders have a super high speed at the end of the spin. Front loaders don't like small loads, the laundry does not spread out evenly enough for a balanced spin.
May 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front loader washing machine won't spin...
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
Jan 18, 2009 | Frigidaire GLTF530DS Front Load Washer
Samsung 3.5 cu. ft. High Efficiency VRT Front Load Washer Logo
404 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
