Question about Kia 2007 Rondo LX
2007 kia rondo battery dead after light switch left on
If you leave the lights in the ON position the battery dies. NOTHING will work. Nothing electrical will work when you try to start the car. Must jump the car off. Could it be a bad bulb in headlights?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 144 Answers
The alternaor may not be charging the battery fully, check out the alternator
Posted on Aug 23, 2014
2007 kia rondo brake light fuse keeps burning out. replaced the brake light switch already. any idea what would cause this? its a 15 amp fuse can i replace with a 20 amp? ty
yes you can but only if you want to burn the wire harness.
fuses burn to prevent damage to the harness and setting the car on fire and the correct fix is to find the dead short after the fuse
check that you have the correct bulbs in the stop lights because if a single point contact has been used in a double contact holder that is a dead short
check for damaged wires or screws that have cut through the wires
Jun 19, 2017 | Kia Cars & Trucks
Replaced roof dvd players side bulbs lights in kia sedona 07 plate now they only work when switched not automatically when door opens?
Kia Carnival & Sedona Forum [Archive] - Kia Forum - Kia-Forums.com
www.kia-forums.com > Kia Forum > KIA Models
Jul 8, 2006 - [Archive] Discussion area for every generation Kia Carnival and Kia Sedona. ... 2006 SEDONA EX front and rear blowers dead · 2007 Kia Sedona LX 3.8L... out of the intercooler air intake · 2002 Kia Sedona Front heater will only work with a slap! ... 2003 Kia Sedona, Will Crank but not start after replacing MAF, crank and ... Kia Carnival & Sedona 2006+ [Archive] - Page 3 - Kia Forum
Apr 11, 2012
Kia Carnival & Sedona (2002 - 2005) [Archive] - Page 5 - Kia Forum
Jul 24, 2008
Kia Carens & Rondo Forum [Archive] - Page 2 - Kia Forum - Kia ...
Aug 15, 2007
More results from www.kia-forums.com
[PDF]2006 Sedona Owner's Manual - Kia Canada
www.kia.ca/.../ownersmanual/2006_sedona_Owners_Manual_E... Kia Motorsrecommended special tools, genuine Kia replacement parts and .... Room light main control switch.....3-123 ...... work properly, the power sliding door and ..... fuel only. • Check to make sure the fuel filler cap is securely closed after refu- .... roof, you have to reset your sunroof sys- ...... bulb check when you turned the ignition.
Jan 30, 2016 | Kia Cars & Trucks
Left lights on overnight and dead battery. jumped and started and have lost power only will go about 30 mph. Does battery need to charge fully before I get full power back?
Never seen that before. But charge battery and try reset your computer by disconnect ing battery wait 2 min and re conect computer may dav gotten spike while boosting
Oct 13, 2015 | 2007 Kia Rondo LX V6
Kia rondo 2007 stereo wiring colors
2007 Kia Rondo Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Brown
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Yellow
Car Stereo Dimmer Wire: Black/Orange
Car Stereo Antenna Trigger Wire: Blue
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Orange
Right Front Speaker Positive Wire (+): Brown
Right Front Speaker Negative Wire (-): White
Left Rear Speaker Positive Wire (+): Red
Left Rear Speaker Negative Wire (-): Blue
Right Rear Speaker Positive Wire (+): Black
Right
Rear Speaker Negative Wire (-): Yellow
Apr 17, 2014 | Cars & Trucks
Kia rondo stuck in neutral
You have a bad brake switch or it is not adjusted properly. there is a recall on those.
Dec 22, 2012 | 2007 Kia Rondo LX V6
How do I replace a brake light switch on my 2007 kia rondo?
It's located on the brake pedal. you'll need a 14mm wrench. There are 2 14mm nuts that sandwich the switch to the bracket. take the bottom nut off and the switch will come off. Install reverse of removal but you need to adjust the switch depth once its on the bracket. then snug the bottom nut and plug in the switch.
Aug 06, 2012 | 2007 Kia Rondo LX V6
I just attempted to replace my low beam light on my Kia Rondo and when I went to start the car back up after about an hour I noticed I for got to hook back one of the relays. When I went to plug it back in...
a desconected relay will not drain the battery, you might have some other issue. start the car using boost and then check if your alternator is charging around 14 volts
Dec 03, 2017 | 2007 Kia Rondo LX V6
Kia 2007 Rondo LX Logo
52 people viewed this question
Top Kia Heating & Cooling Experts
Mike Squire
terry stevens
Andrew Taylor
Andrew Taylor
Are you a Kia Heating and Cooling Expert? Answer questions, earn points and help others
