Question about Cuisinart CJK-17BC Cordless Electric Kettle
Cordless Kettle Plastic button (internal part)broke, so lid won't stay shut,and kettle won't shut off automatically. Can I get this part and can I fix myself?? Thanks
  • 2 more comments
  • Frugal Nov 04, 2007
    Same problem and I need the sealing ring that the water level indicator goes through. Its made of silicone.
    I have tried a 2 dealers in Ottawa Ont Canada and they tell me to toss the unit and buy new!. Paid $70.00 2 years ago.
  • Anonymous Feb 14, 2009
    Our lid won't stay closed and nothing appeared to be wrong. So I took the handle mechanism apart and discovered the button extension 'thingy' was broken inside. Is there a replacement part?
  • Anonymous Mar 17, 2014
    Ive just noticed that there is a plastic piece loose in my pyramid accent kettle. Not sure where it fits?
  • Anonymous Mar 25, 2014
    The button on the lid does not always release the lid catch. Is it possible to remove the lid by unscrewing the two screws under the lid, and somehow clean the mechanism inside?
    New Friend:
I went to the hardware store and found a black plastic knob, added washer and nut inside--voila! Fixed for about $5.
Posted on Apr 11, 2013
There isn't a part available, cuisinart are horrible for parts, hence I will never buy anything from that company again.
Posted on Apr 25, 2008
SOURCE:
1.7 l cordless kettle model JKC930C lid release does not work
Had same issue on 2 B&D JKC930C kettles. Just push in button (hidden under front of lid) located in the centre above the spout with a butter knife and the lid will open.
Jul 12, 2013 | Applica Black And Decker Cordless Electric...
I bought a Bellini electric cordless kettle about three months ago from Target and now the lid won't shut, hence the kettle won't stop from boiling. What do I do - is there any guarantee?
i brought a belline kettle from target 2 months ago and now the lid wont shut where would i find a contact no for the company as target wont issue me a new one and i dont have my reciept after all who would have thought it would be faulty after 2 months
Aug 09, 2010 | Microwave Ovens
Cushion lid release button sticks and the lid does not close
Over time the heat can causes the plastic parts to swell until the button that releases the lid gets stuck. The button can be easily & carefully pried completely out of the hole with a knife **note the orientation of the button and spring for replacement. Clean the button & hole but expect the button to still stick when re-inserted back into the kettle. Take the button back out and if you take a knife and gently carve/scrape away some of the plastic round the inside of the rim of the 'hole' and around the edge of the plastic button, you can remove enough of the plastic so that the button now moves easily back and forth in the hole releasing the lid. Good luck.
Jul 05, 2010 | Breville "Ikon" Tea Kettle Electric Kettle
Kettle does not automatically shut off even when water is at above minimum level and boiling
I think that standards require an auto-shutoff on electric pots to keep the component from softening down. You could override the shutoff by either taping over the switch or utilizing an elastic band. You can check deep details on electric kettle review sites.
May 15, 2010 | Chef's Choice 677 Cordless Electric Kettle
Dualit glacier blue kettle spare lid
Our kettle has just broken so if you'd like our lid? - if so I'll pop it on ebay?!
Apr 04, 2010 | Dualit 72102 / 72100 Cordless Electric...
Plastic catch broken DeLonghi KBX1510
try supper glue??? but dont hold your breth that this will work,,, it realy dont like hot wet places! i know this from first hand experience,,,
as its holding up my left lung!!!!!! and im not kidding you there?
Oct 24, 2009 | DeLonghi KBX1510 Cordless Electric Kettle
I need directions for the TFal Vitesse cordless electric kettle. 7845162 Thanks
Fill with clean water to fill line. Have base plugged in. Place kettle on base and press down button on top of handle. Water should boil quickly and turn off automatically when done.
Mar 09, 2009 | Tefal 78451 Vitesse Cordless Electric...
Where can I find a replacement lid for Cuisinart Kettle CJK-17BC?
You need to talk to Cuisinart (follow this link to their contact us page http://www.cuisinart.co.uk/contactus.asp?menuId=20)
There is no harm in asking. I have had replacement cooker nobs, bin lids allsorts by just being honest with message and asking nicely.
But if all else fails EBAY =P
Mar 01, 2009 | Cuisinart CJK-17BC Cordless Electric...
Siemens porsche kettle om switch problem
Some switches are called momentary and others are the click on and click off type.
It could be a problem with the switch if is is the click on type.
It could be a relay that "seals in" when you press the on off switch to on.
By "seal in" I mean, the kettle is wired so that when the relay coil energizes, it closes a contact when it is electrified and becomes an electric magnet and the energy that was going through the on off button, is now going through the closed contact on the relay.
If you don't here a clicking sound like you used to, it could be a fuse inside inside of the electrical box on or by the kettle.
I don't know by the information, if this is a household small appliance or commercial?
Even if household, it should have the same basic setup.
This may be of some help to you
What About The Kettle?
Despite being metal the kettle is cool touch (a tough special grade plastic interior). A good safety feature is that the kettle will only switch on when the lid is closed, there is a special lid release button. The kettle also has automatic overheat protection. Of course the kettle is cordless and has cord storage in its base. Water quality? Well, it's better if you use filtered water, but with this kettle it is even better - it has a removable stainless steel limescale filter in the spout!
Feb 04, 2008 | Kitchen Appliances - Others
Cuisinart CJK-17BC Cordless Electric Kettle Logo
1,275 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Irene Tulloch
Tom Chichester
Anthony Ward
Anthony Ward
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
