Question about Panasonic Kx-fp200 Fax Machine And Phone
Panasonic Communication error poor line condition
Error 322 How to fix it?
There was a communication error with the receiving fax machine due to poor telephone line conditions.
Solution
  • Set the receiving machine to receive at a slower transmission speed
  • If the session fails after sending several pages of a large document, resend the document as several smaller documents.
  • Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Oct 15, 2013 | HP Officejet 7210 All-In-One InkJet...
Err code 322 every time ces up on my HP 6600 print scan web copy n faxachine .
Video might not help but 322 is an error with the receiving fax machine due to poor telephone line conditions. Solution is to set the receiving machine to receive at a slower transmission speed if it still fais resend the documents in smaller sizes. Hope this helps
Apr 16, 2013 | Office Equipment & Supplies
Communication error 43 message every time and with every number.Panasonic fax kx-fhd332
COMMUNICATION ERROR (Code: 43, 44) means that "A line problem occurred". There might be a problem with the phone jack where your fax machine is connected to. Try to connect the telephone line cord to a different jack and try again.
Mar 21, 2011 | Panasonic KX-FHD331 Plain Paper Thermal...
I need assistance with fax error codes # 322 and # 358. What do they mean?
Error code 322- There was a communication error with the receiving fax machine due to poor telephone line conditions.
Solution
Error code 358--
The remote user pressed the Stop key,
The remote machine encountered a system problem such as no paper or a paper jam.
Try
Configure the local fax machine to use a slower reception speed.
Disable ECM mode on your machine.
Try sending a fax to another location.
Mar 03, 2010 | HP Officejet Pro L7680 All-In-One Printer
Poor line condition-can't send fax
Try turning off the E.C.M. mode off ( error correction mode )
I have had a lot off problem's with communication problem's with this function turned on.
It is in your manual under advance fax function.
if need more help let us know.
Dec 11, 2008 | Brother FAX-575 Plain Paper Thermal
What is communications Error (48) for a panasonic KX-FP250
communication error 48 is for telephone line problem .just clear ur line .there will bi some noise in line .confarm it by using another line.MIAN AKHLAQ
Nov 26, 2008 | Panasonic Office Equipment & Supplies
Communication error
the problem is most likely not the machine, once it has established communication it should be fine.
if there is a break in the line for whatever reason then, it will give you the error.
try to fax to a different fax, does it still do it? plug a phone in that outlet and call a freind, chat awhile, is there any static or anything unusual with the line?
Dec 13, 2007 | Brother IntelliFax-2820 Laser Fax
Assa1875@sbcglobal.net
The error is a communication error. Either the tel line is noisy or the signal too weak. The problem lies outside the machine, and the machine can only identify the global problem not the root cause. You may want to call your Panasonic Tech to check the line condition and tweak the line settings, but other than that, you are at the mercy of your sending party or the tel line company.
Oct 26, 2007 | Panasonic Panafax UF-595 Plain Paper Laser...
Poor line condition error Brother intellifax 5750e
Poor line condition is an error referring to the phone line itself. Even though it may sound clear small amount of static confuse the fax machine and cause the error. Try using a new phone line. If that doesn't help I recommend getting a line filter from OfficeMax
Oct 11, 2007 | Office Equipment & Supplies
Panasonic Kx-fp200 Fax Machine And Phone Logo
18 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
