Question about Propellerhead Reason 4.0 - Windows and Mac Upgrade Version for PC, Mac
Notes don't stop even after I release the key
I just got the Edirol PCR-300 midi keyboard, and set it up with Reason 4. Reason indicated that the setup went fine, but when I try the keyboard with one of the sound modules, the note just keeps playing at a constant volume and doesn't stop even after I release the key. Any help with this would be greatly appreciated.
  • smellybanana Jan 24, 2009
    Thanks very much for your help, but I did not see anything in the midi preferences about any note off instruction. The only thing I find in there is that my Edirol is set up as the master keyboard, and when I click on it to edit the settings, the only thing that comes up is a dialogue box for what I want to set as the midi input and output. Also, I am using PC, not Mac. Thanks anyway though.
  • ultimatewein
    ultimatewein Feb 23, 2012
  • 3 Answers
The keyboard  is not sending a note off instruction after the key is released. Try checking midi preferences in reason.If your using a Mac check that the edirol is present by launching Audio MIDI Setup utility located in the utilities folder. You can download the latest Mac driver from Roland below: EDIROL PCR-300 32-key MIDI Keyboard Controller :: Download
Posted on Jan 20, 2009
Windows 7 64 can not install the driver
Windows 7 64Bit requires signed drivers. Try looking on vendor's website otherwise I am afraid you need to either get a new controller or disable this requirement (not supported by MS)
Jun 07, 2012 | Edirol PCR-M30 32 key USB MIDI Keyboard...
Do not get MIDI signal via EDIROL UA25
Midi is data only, there is no actual sound to the midi tracks themselves. They need to be assigned to either a software synth or an external synth to actually make the sounds you want to hear.
For instance if you load a demo of a midi sequance you will need to add a software synth such as the TTS-1 or Roland sound canvas which are general midi compatable and will play the instruments sounds assigned to the demo's midi channels. Use the Synth Rack feature in Sonar to open one of them. Then you will need to assign the output of each of the midi tracks to that particular synth and you will get sound. Make sure to assing the synth's audio track to you UA-25 as its audio output.
I would suggest reading in the manual and following the tutorials included in the manual to get yourself familier with how this is all done. spacer.gif
May 25, 2008 | Edirol UA-25 External Sound System
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
Edirol PCR-50 wont output any data for most keyboard keys
Yes people it can be fixed by yourself at home, cheaply and easily. I’ve got an Edirol pcr-80 & prc-a30. Both have had intermittent key troubles and keys that just don’t work anymore or low/high level compared to other keys. These problems seem to start after a year or so. I’ve paid hundreds of dollars getting them fixed until I tried this on a whim. The contacts under the keys are a carbon-based contact so cleaning them with metho/alcohol just dries out this carbon. Some people say cleaning them with a pencil easier helps and it can do slightly but not properly. What you need is “Graphite Powder”. (Link for a picture of a appropriate product – just cut and paste it in your Internet heading bar, or Google image search graphite powder…)
Graphite powder is a dry fine powder that is conductive and perfect for the job. You can purchase at any locksmith – maybe a good hardware store, and it is sold as “non liquid lubricant for locks and machinery.”
All you need to do is unscrew the case, remove the springs that hold the keys in, remove the keys. (White keys first then black keys. Keep in order.) Peel off the rubber strip under the keys and turn over so you can see the little carbon nipples that touch the circuit board. (2 for each key) Pour a little power out on a sheet of paper and use a cotton tip bud to apply a little powder to these. Now apply a little to the carbon contacts on the circuit board where the little nipples touch. Do all this with your midi keyboard plugged in to your computer/synth etc so you can hear how you’re going with getting contact before you put it all back together. You might get a key or two going off when doing this because the graphite power is making a continuous contact across the circuit board. Just blow/lightly wipe away excess to stop this but you want to leave all the contact points evenly (if slightly) coated. Try touching the rubber strip contacts with the circuit board contacts to see if you can get a sound. This can be a bit tricky to line up and get an even contact. This sorts its self out when everything is back together.
Now put back the rubber strip. I used I tiny screwdriver to help push the rubber guide back in the holes on the circuit board. Now put the keys back (black first – with the short springs then white keys with the longer springs) screw the case back together and let me know how you went.
This I think will dry up again in time but if you get a good bit of use out of it you can just do it again… For free…
May 29, 2010 | Edirol PCR-50 Keyboard
Edirol pcr 50 dont know how to work
Dont forget that the PCR50 is a Midi controller and as such has no "sound" of its own. You must have Midi compatible player or composer type software (like Reason, Cakewalk, Sonic, etc) to link up to the PCR50 to get any sound.
May 12, 2010 | Edirol PCR-50 Keyboard
How do i hook it up can it be used threw the usb or does it have to be connected with midi
As far as I can tell it will connect with USB as it has a USB connection.
Nov 17, 2009 | Edirol PCR-50 Keyboard
Some keys not triggering when humidity low.
You might want to try take a can of compressed air as used for computers and blow out any debris that may have built up.
See if that fixes it. You might also want to check out the editol web forums and ask in there as I am they might have more idea
Mar 10, 2009 | Edirol PCR-30 32-key Midi Keyboard...
Problems recording on acid pro 7 with edirol ua4-fx
point nr 1:
when you record midi, you are not recording sound but a key code and time info it was pressed.
point nr 2:
the midi keyboard may be seen as a remote controller.
check the midi configuration on your software host
Jan 22, 2009 | Edirol UA-4FX External Sound System
Edirol UA 4FX _Short Audio Signal dropout
try runing a cleaner ccleaner and ace utituies ok that stop those hickups give a atry make pc run alsot faster
Jan 28, 2008 | Edirol UA-4FX External Sound System
Propellerhead Reason 4.0 - Windows and Mac Upgrade Version for PC, Mac  Logo
407 people viewed this question
Top Propellerhead Computers & Internet Experts
Chris Larocque
Nikki  Mclean
Nikki Mclean
Alun Cox
Are you a Propellerhead Computer and Internet Expert? Answer questions, earn points and help others
