Question about Pioneer Audio Players & Recorders
Reset pioneer vsx d701s to factory setting - Pioneer Audio Players & Recorders
SOURCE: Pioneer Receiver VSX-D508
I just set it to theater1 setting and it made the center speaker still no sub but the reciever has plenty of base.
Posted on Apr 13, 2009
  • 30 Answers
SOURCE: pioneer vsx-d510 coaxial dvd connection problem
I recommend you use an optical connection. Your VSX-D510 has only one optical input, but I believe it is assignable. Use a good optical cable and connect directly to your DVR. Follow the manual to assign the input and it should work.
Good luck
Posted on Aug 02, 2009
dunnbiker
  • 8546 Answers
SOURCE: pioneer receiver vsx-d510 sub not working
Rear Surrounds are not supported on this unit, they would be the 6th and 7th channels in a 7.1 rig. I think you mean Surrounds (channels 4 and 5 in a 5.1 rig).
Lets ponder: How is there any relationship between Surrounds and your separately-amplified Subwoofer? I don't see it, unless you inadvertently chose OFF for the Sub definition when you were in the Speaker selection menus adding the Surrounds. Look again.
Posted on Jan 19, 2010
SOURCE: Pioneer VSX-1019 with a flashing red MCACC
you can "release" the error by pressing the "down arrow" and the "zone 2 on/off" for 2 seconds.
Posted on May 23, 2010
  • 11800 Answers
SOURCE: Bonjour, Mon amplificateur pioneer vsx-D701S qui
L'amplificateur se met en POWER OFF parce que le syst?me de protection de la planche d'alimentation a ?t? active par un cour-circuit. Comme tous les fils ont ?t? enlev?s il est clair que court-circuit est interne - une composante importante a failli.
Remplacer le fusible n'aboutira a rien: il sera instantan?ment brule quand vous allez tenter de l'allumer. L'amplificateur doit ?tre test?e, la composante qui a failli trouv?e et remplac? - la pi?ce plus probable est un des circuits d'amplification. Ceci est un travail de professionnel, et il va ?tre cher - au moins 150€.
Posted on Jan 25, 2011
How to reset a pioneer vsx d411 stereo receiver
there is no reset , If you want default settings/ factory settings unplug it for a while. What are you wanting to do with the amp?
May 20, 2016 | Pioneer Audio Players & Recorders
How do you troubleshoot a Pioneer VSX-1023 A/V receiver?
Try to do the factory reset on the Pioneer:
Switch the Pioneer into standby (turn it off).
1. Simultaneously press old the buttons on font panel for 5 seconds - BAND & STANDBY/ON
2. "Reset" on the front panel press
AUTO SURROUND/STREAM DIRECT
3. Then press ALC/STANDARD SURROUND
OR
Simultaneously pressing "down" and "on/off" for 5 seconds to reset the Pioneer
Mar 05, 2015 | Pioneer VSX-1023-K Receiver 7.1 Channels,...
How too reset pioneer 4800
Check page 69 of the manual :
Resetting the main unit
Use this procedure to reset all the receiver's
settings to the factory default. Use the front
panel controls to do this.
1 Switch the receiver into standby.
2 While holding down the BAND button,
press and hold the STANDBY/ON button
for about two seconds.
3 When you see RESET? appear in the
display, press 'AUTO SURROUND/STREAM
DIRECT'.
OK? shows in the display.
4 Press 'STEREO/A.L.C.' to confirm.
OK appears in the display to indicate that the
receiver has been reset to the factory settings.
http://www.pioneerelectronics.com/StaticFiles/Manuals/Home/VSX-819H_OperatingInstructions0508.pdf
Jun 15, 2014 | Pioneer VSX-819H-K A/V Receiver
Resetting vsx-d510
On the remote controller, press and hold "remote setup" and 0 simultaneously for about 5 seconds. When it's successful the remote display will blink 3 times.
Feb 21, 2012 | Pioneer VSX-D510 Receiver
How to reset pioneer vsx-819h
http://audio.manualsonline.com/manuals/mfg/pioneer/vsx819hk.html
It's in the manual. Page 12.
Resetting the Main Unit
Use this procedure to reset all the receiver's settings to the factory default. Use the front panel controls to do this.
2 While holding down the BAND button, press and hold the STANDBY/ON button for about two seconds.
3 When you see RESET? appear in the display, press AUTO SURROUND/STREAM DIRECT.
4 Press STEREO/A.L.C to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory settings.
Sep 08, 2011 | Pioneer VSX-819H-K A/V Receiver
My pioneer vsx 815 amplifier has a flashing blue standby light. Have tried resetting by pressing enter and advanced surround keys. All it does is flash a few other LEDs and then goes back to the flashing...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Pioneer-VSX-815-K-Receivers-manual/id/385dj989/t/2/
"enter and advanced surround keys"? I don't see that documented as a special function in the manual.
BTW: other than the Flashing light, is there a malfunction?
Page 72 describes how it REALLY resets...
2 While holding down the TONE button, press and hold the STANDBY/ON button for about three seconds.
3 When you see RESET? appear in the display, press ENTER .
4 Press SYSTEM SETUP to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default
settings.
Mar 04, 2011 | Pioneer VSX-815-K Receiver
How do i reset my pioneer vsx 919 ah amp reciever back to its original settings
In the manual, page 72
Resetting the system
controls to do this. Set MULTI-ZONE to OFF.
• Disconnect the iPod and USB memory device from the receiver beforehand.
2 While holding down ENTER on the front panel, press ?µ STANDBY/ON.
The display shows RESET < NO >.
3 Select 'RESET' using PRESET +/-, then press ENTER on the front panel.
The display shows RESET? OK.
4 Press ENTER to confirm.
OK appears in the display to indicate that the receiver has been reset to the factory default settings.
• Note that all settings will be saved, even if the receiver is unplugged.
Feb 01, 2011 | Pioneer VSX-919AH-K A/V Receiver
Apr 12, 2009 | Pioneer VSX-D508
Improper equalizer between VSX-49TXi and LD player,no sound now
You may want to buy the service manual (SM) from Pioneer for this unit. It has a lot of info on resetting and testing the receiver under the "Test Mode". It is highly improbable that you could ruin the firmware by connecting the receiver in an unusual way. You may just need to reset it to factory specs. Another option if you bought it from a local Pioneer dealer is for them to reset. It usually involves getting into the secret menu to do so.
I had one of these for a short while and they are quite nice receiver.
Good luck
Dec 22, 2008 | Pioneer VSX-49TXi Receiver
48 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
