Question about HP PSC 2410 All-In-One InkJet Printer
Al encender hace ruido constante el reloj de arena en pantalla
Al encender la hp psc 2410 la pantalla se queda con un reloj de arena ,hace un ruido como de movimiento de cartucho, y poco despues hace un ruido como de engranajes que no ruedan al mismo tiempo parece que uno gira pero el otro esta quieto durante casi dos minutos.
Una vez que el ruido desaparece, la pantalla sigue con el reloj de arena y el piloto de encender sigue parpadeando.
  • oscar2009 Feb 14, 2009
    Yes we do have the same problem. How can we put it right.
    Thanks for your assistance.
    Oscar
SOURCE: Error al instalar driver de scanner HP Deskjet F380
hi dear
i need ho deskjet f380 All in one
thanks
Posted on Sep 23, 2008
pineworks
  • 4041 Answers
SOURCE: error 5600 Canon ip1700
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Posted on Feb 27, 2010
puertobori
  • 7733 Answers
SOURCE: En el display me muestra el error "Atasco
Trata este link en ingles pero facil de entender.
Posted on Oct 22, 2010
puertobori
  • 7733 Answers
SOURCE: El indicador del cartucho de
Ve a eate enlace y descarga la aplicacion Try using the HP Print Diagnostic Utility in Windows - HP Customer Care (United States - English) luego abrela y empezara el diagnostico.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Dec 01, 2010
puertobori
  • 7733 Answers
SOURCE: buenas cordial saludo alas
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
    NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Posted on Dec 03, 2010
Compre mi maquina de motilar marca wahl, modelo 8267 en colombia, pero viaje a francia con ella y al momento de encender la maquina esta hace un ruido muy fuerte, debe ser por que el voltaje el mas alto,...
lo mas probable es que sea la frecuencia con la que trabaja la maquina... pues en colombia a frecuancia electrica es de 60Hz y en europa es de 50Hz
Feb 12, 2012 | Cars & Trucks
A CABO DE COMPRAR UNA ACER ONE MINI. PRENDE LA COMPUTADORA PERO LA PANTALLA SE QUEDA EN NEGRO, HACE UN RUIDO COMO SI LEYERA EL DISCO DURO PRO NO APARECE NADA. QUE ES LO QUE PUEDO HACER
puede hacer la bateria que esta baja, tratar de cargarla primero sacale la batteria luego poner sela y cargar y prenderla de nuevo haver si funciona
Feb 19, 2011 | Acer Aspire One PC Notebook
ACABO DE ADQUIRIR UN COBY MP727, SI ACEPTA LA CARGA POR MEDIO DE LA COMPUTADORA PERO NO RECONOCE EL USB PARA EL ENVIO DE MUSICA
tiene que o?r el equipo hace un ruido cuando se conecta el USB en el puerto. si esto no ocurre, usted tiene un puerto USB muertos. si usted est? escuchando el ruido cuando se conecta el USB a la computadora luego contin?e con el siguiente p?rrafo.
si est? usando Windows XP, vaya a "Mi PC" y el dispositivo debe aparecer como otro disco duro, al igual que tu (Disco local (C:)), disco duro interno. Usted puede abrir este al igual que una carpeta y desde all? debe ser capaz de colocar la m?sica en el dispositivo.
Jan 09, 2011 | Coby MP727 MP3 Player
RUIDO EN EL DFRENO DELANTERO
Hola
Asegúrese que las almohadillas de freno tienen su charla de anti shims en la espalda y tienen el compuesto de chillido de anti en la espalda y que los resbaladores son lubricados con la grasa de calibrador
Caja fuerte de Paseo
Bike-Doc
Jun 03, 2010 | 2001 Suzuki AN 400 Burgman
HOLA NECESITO EL TIEMPO DE UNA ISUZU RODEO 1995 4 CILINDROS. CUANDO LA PRENDO TIENE UN FALLO QUE HACE COMO UNA EXPLOSIONES EN EL MOTOR, Y ASI CORRE. SI TIENEN LA SOLUCION SE LOS VOY A AGRADECER...
Tengo una isuzu rodeo 1995, empezo a encender la luz de check engine y se me apagaba y no queria encender...luego encendio, a veces hace como si no tuviera gasolina pero a veces enciende y se apaga, la utilizo asi pero cuando enciende el check engine se queda sin corriente y se apaga por completo, le lleve a hacerle un chequeo y ni el tecnico encontro nada, me pueden ayudar con ese problema?
Nov 29, 2009 | 1993 Isuzu Amigo
Error en sistema 0013 en BenQ DC610
CBCX, efectivamente el error se debe a que el lente se trabo y no pasa las pruebas movimiento iniciales que hace el equipo al encender. Por esta razón aparece el error de 0013. Mi experiencia a sido que el engrane que provee de este movimiento se sale de su posición original provocando que se trabe. Yo tengo una cámara del mismo modelo. El problema se resuelve abriendo la cámara y ajustando el engranaje (Es un pequeño engranaje rojo que esta en la parte superior del lente). Adicionalmente se debe fijar el soporte del engranaje, yo coloque un poco de cinta adhesiva en el soporte del engranaje para que no se mueva nuevamente. Esto en la mayoría de los casos resuelve el problema de manera permanente. Adicionalmente es recomendable actualizar la última versión de firmware del equipo.
Como referencia, he descubierto que si estas en el campo tomando fotografías y te ocurre el problema, si le das un golpe firme con el pulgar, en la parte delantera de la cámara justo entre el flash y el emisor para el ajuste del foco el problema también se solventa de forma temporal ya que el engrane entra nuevamente en posición. Puedes hacerlo también dentro del estuche de la cámara con la palma de la mano. A pesar que esto nunca falla, el equipo queda funcionando nuevamente, esta reparación es de carácter temporal y adicionalmente, es obvio que no es sano recomiendan esta práctica, pero puede salvarte en caso de que estés de viaje tomando fotografías y no tengas un servicio especializado.
Feb 03, 2009 | Nikon Coolpix 3200 Digital Camera
Al encender se queda negra
Si el sistema se ve durante unos segundos esto quire decir que no es la pantalla, ma la ordenadora que se bloquea.
Si la computadora ni siquiera empieza a cargar Windows entonces es un problema de hardware, RAM, perifericos, tarjeta de video, disco duro, o motherboard.
Si empieza acargando windows y se apaga, entonces tiene que volver a instalar Windows.
Nov 17, 2008 | Acer AL2017 20" LCD Monitor
Pantalla negra VAIO VGN-UX280P
Por lo que comentas, el problema debe haber estado en algun contacto de la pantalla que no permitia su correcto funcionamiento. El invertidor or inverter posiblemente no estaba funcionando bien. A este punto puedes si luego de cambiar los LCD el viejo volvio a funcionar es posible que el problema este alli. Puedes enviar tus LCD screen para que sean revisados y tal vez reparados para evitar un gasto mayor. Te recomiendo que sino tienes experiencia en este campo lleves tu equipo al servicio especializado.
Nov 06, 2008 | Sony VAIO VGN-UX280P Notebook
HP PSC 2410 All-In-One InkJet Printer Logo
351 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
