Question about Yamaha P95 Digital Piano
My yamaha p95 piano woll not turn on. the power lead is fine and has been tested. can anyone help
2 Suggested Answers
  • 43 Answers
SOURCE: key doesn't work properlyon yamaha p95 piano
take it back, its still under warranty. That means the key has a contact problem in the circuit. you have to take it all apart, clean it, check the contacts....probably lint. You can try vaccumming it and it might fix the problem. I bought one too and it wasnt good
Posted on May 07, 2012
Manual for Yamaha P 160 Need a Manual
For the P95 user manual visit
https://uk.yamaha.com/en/support/manuals/index.html
However there is no P160 should this read PSR160 in which case select this at the same link.
Dan
Apr 30, 2017 | Yamaha P95 Digital Piano
Sounding a half step too high
Use the factory reset
Hold down highest white key whilst turning on
This should return to factory settings - pitch should now be back at A440
If you need to adjust then see page 19 of the user manual where it explains fine tuning.
Mar 14, 2015 | Yamaha P95 Digital Piano
P95 making noise when pressing any key or any sound. (piano,organ,etc.)
thats a motherbord problem./ ic called tone generator which is usually faulty.
Sep 24, 2014 | Yamaha P95 Digital Piano
How can I plug an amplifier into a Yamaha Digital P-95 piano?
Get an AUDIO to STEREO adapter from best buy, radio shack, etc. for a low price then use an audio cable from the stereo jack to the amplifier.
Sep 05, 2014 | Yamaha P-95 P95 DIGITAL PIANO BLACK
Why power cutting out on yamaha-p95
Hi, This could be for a number of reasons the most common causes are :
1) Socket where mains adaptor is plugged in becomes loose on the PCB and will need to be replaced / repaired
http://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=17018
2) The power supply unit fails and needs to be replaced. You should only use the correct power supply for your instrument.
Jun 24, 2014 | Yamaha P-95 P95 DIGITAL PIANO BLACK
Key doesn't work properlyon yamaha p95 piano
May 07, 2012 | Yamaha P-95 P95 DIGITAL PIANO BLACK
Hello- my P95 sustain pedal does not work when plugged in but the sustain works when you disconnect the cord from the back of the keyborad
This is confusing... you say "the sustain works when you disconnect the cord"? How can that happen? and doesn't work when it is plugged in.
MOST sustain pedal problems are due to people using a different pedal than the keyboard is designed to use. It is very common that someone tries to use a Roland sustain pedal on a Yamaha and oof course it doesn't work because the Roland pedal is normally closed and Yamaha usually requires a normally open contact.
A FEW keyboards now check the state of the pedal input when power is first turned on and configure the pedal polarity accordingly. For these keyboards, make sure the pedal is plugged in before power is turned on.
Apr 02, 2011 | Yamaha P95 Digital Piano
The Yamaha P95 is have a semitone out. Using the transposing function moves it up or down a semitone, however it's still out from concert pitch where it should be?
how come mine is ok, maybe it's depends on where you bought it.
<a href="http://bestdigitalpianoreview.com/yamaha-p-85-review">Yamaha P85 Review</a>
Feb 12, 2011 | Yamaha P95 Digital Piano
Yamaha P95 Digital Piano Logo
66 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
