Question about True T23 Refrigerator
How to remode bad thermostat on true refrigerator model t-23-2
5 Suggested Answers
ronaldo_ross
  • 1056 Answers
SOURCE: T-23 Refrigerator quit cooling.
Look in the back see if that compressor is running. It is balck kinda ball shaped. It pumps freon so to make the refrigerator cold. If it runs but do not get cold then it needs freon.
Posted on Feb 18, 2010
SOURCE: NEED A THERMOSTAT FOR A TRUE MODEL T23
gasketsandmore.com has everything at good prices i just got gaskets and temp control from them reg shipping in two days good company
Posted on Jun 16, 2010
  • 112 Answers
SOURCE: The cooler will not cycle
Inside of the unit on the right side of the coil. You may need a little mirror to see it easier. There is a metal plate with a little v cut to indicate where the setpoint is and the knob should have numbers from 1 to 9. The typical setting is 5.
Posted on Jan 04, 2011
heatman101
  • 43501 Answers
SOURCE: I have a True refrigerator
You will need to find out why the unit is not shutting down properly....
It may be that the thermostat sensor will need to be placed in a different spot...or the temperature may just need to be raised higher...
Does the thermostat turn off the unit if the temperature is raised??? If so, then place a thermometer in the cooler and then adjust the thermostat to 38F by that thermometer and not by the t-stat calibration, it may be off even if it is new...
If the t-stat is not cycling the unit then you will need to use an electrical meter to trace out the power to the unit and find out why it is not shutting down...
heatman101
Posted on Mar 31, 2011
I have a true double door commercial refrigerator. it stay below freezing even though I set the temperature very low. it is freezing everything.
thermostats on those things are notoriously bad. probably a bad thermostat. should have numbers 1 - 9 and usually set on 5
Aug 18, 2013 | True Refrigerators
I have a true upright commercial display refrigerator.I think the tempature control is faulty.It freezez everything,I use it for beer and wine.I have cleaned the condensor and still no luck.No matter what...
it is just a temp control, look real good at the control and see if you can see any holes in it that might have a small screw that can be turned. Maybe an in and out, you may be able to adjust it this way. let me know.
Mar 15, 2011 | True GDM-23 Refrigerator Commercial
The cooler will not cycle off when temp is reached. Just keeps running and becomes a freezer instead of a refrigerator. Where is the thermostat adjustment locatd on a True Model T-23
Nov 16, 2010 | True T23 Stainless Steel Refrigerator
Jan 05, 2010 | True Food VWR Storage Refrigerators with...
The fridge freeze the food
The thermostat is probably stuck closed and bad. A good replacement would be a Ranco A12-1560. If its not the thermostat there may be a stuck relay on newer modes coolers.
Nov 05, 2009 | True GEM-23
I have a True GDM 33 model is it possible tochange the temperatur
If your cooler is constantly running too cold the thermostat is probably bad. I can hook yu up with a thermostat. ;) www.northeastcooling.com
Nov 18, 2008 | True GDM-33-SSL-54 Refrigerator
Help?
turn thermostat all the way to the left to turn it off. restore power and see if it stays on and inside fan is running. Then turn thermostat to rite to turn on compressor. If the power trips when turning thermostat back on, the compressor may be bad. :(
Dec 27, 2007 | True GDM-41 Refrigerator
True T23 Refrigerator Logo
26 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
