Question about Master Heaters BLP375AT
My BLP42 Master Propane wont stay lit what can I do?
What can i do
  • 188 Answers
Here is a link to your owner's manual... http://12.153.20.74/manuals/122371-01C.PDF.
If your getting no spark, then check to see if the ignitor wire is disconnected or loose. Check gap (The gap should be set between the ignitor electrode and target plate to 0.71". Then, check to see if piezo ignitor is loose. Lastly, it may be a bad ignitor electrode.
If you need to purchase a replacement part you can contact Master Parts at 800-446-1446 or you can find them on-line at www.masterparts.net. I hope this helps!
Posted on Jul 13, 2009
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Pool heater stays lit for approx. 30 seconds then shuts off. pilot stays lit whole time but burners wont stay lit. water flow is good
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
http://www.laarsman.co.uk
Miles
Jun 02, 2010 | Teledyne Laars Laars Lx Pool Heater /...
My pilot light wont stay lit
Hi try cleaning the pilot light out make sure the thermo couple is in the flame,check where the tcouple goes in to the valve nothing stuck in there try this it could be the valve not working
Feb 07, 2010 | Heating & Cooling
SPC-40 wont stay lit
Problem is either the thermocouple or the thermoelectric valve. I have one of these as well with the same problem. On mine it is not the thermocouple. I have replaced the thermocoupler and still have the problem. A thermoelectric valve is $42.25 at http://www.masterheaters.com/propane/
Im looking for a cheaper part. Any suggestions?
Gru es 1234 @yah oo.c om
Jan 12, 2010 | All-Pro Propane Garage Shop Heaters - All...
My universal lp forced air heater model 30 fsa wont stay lit
if its lit by a pilot your thermocouple is bad the purpose of the thermocouple it to keep the gas valve open
Oct 24, 2009 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Torpedo heater wont stay lit.
Do you have the serial number or the manufacture date? There are some design changes and I would need to know the year of manufacture to assist accurately. Usually it is a relay or the thermocouple connection that will affect the unit staying lit.
Mar 29, 2009 | Reddy Portable Forced Air Propane Heater...
Wont stay lit
go to this site www dot desatech dot com. Here you'll find parts to repair your heater. a propane heater uses a millivolt generator to sense the flame. along it's cappilary are two push on spde connectors. these connect to the high limit temperature sensor which is mounted on the flame backplate of your heater. to see if it is the high limit shutting down your heater, jumper across the two spade connectors. if the heater stays on, this is your problem. if the flame still goes out, then the millivolt generator is shot.
Nov 09, 2007 | Coleman 5075751 Utility Heater
Master Heaters BLP375AT Logo
190 people viewed this question
Top Master Heaters Heating & Cooling Experts
T bone 1963
Gil Shultz
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Master Heaters Heating and Cooling Expert? Answer questions, earn points and help others
