Question about Mattel Fisher Price Magna Doodle (PC)
Magnetic issue with magna doodle
Does it require batteries?
    Sergeant:
  • 475 Answers
You might have gotten a bad magna doodle you might have to call the company and get anew from them.
Posted on Dec 30, 2012
1996 honda magna vf750c won-t turn over
Hi, Bmore_scorpi before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Security alarm needs a reset.
10. Starter relay, solenoid or starter circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1994 Honda Magna won start
1996 Honda Magna VF750C has new battery but no clicking sound heard when...
Honda Magna VF750C Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VF750C Owner Manual
Apr 08, 2017 | 1996 Honda VF 750 C Magna
How do I order
http://www.amazon.com/s/?ie=UTF8&keywords=magna+arm&tag=googhydr-20&index=aps&hvadid=34601805648&hvpos=1t1&hvexid=&hvnetw=g&hvrand=12532063791080661631&hvpone=&hvptwo=&hvqmt=b&hvdev=c&ref=pd_sl_6hykn25j93_b
Jan 05, 2015 | Televison & Video
1995 VF750. The bike will start after i take off of the trickle charger. Idled for about 20 min then died and won't start. Put back on the trickle for a couple minutes and it started again. I think the...
You may just have a dead cell in the battery. The battery needs to be checked under load. Most shops will do a battery check for free. At least you can eliminate the battery itself as a culprit.
Apr 07, 2014 | 1995 Honda VF 750 C Magna
I have a CST/berger Magna-Trak 202 magnetic locator that just stopped working.
Likely the on/off button is no longer at the right position to make contact with the tab. Take it apart, and you may need to glue a little piece of plastic to the button.
Feb 01, 2013 | Bosch CST Berger MagnaTrak 200 Series...
How to remove ink from magna doodle screen
You could try removing it with fingernail polish remover or a product called Goop Off.
Oct 05, 2012 | Motorcycles
Doodle penguin instructions
Doodle Penguin instructions available for download here: http://reast.net/?p=185
Jan 27, 2012 | Crayola Toys
How could i know if my friends are on line even they are in invisible mode
The easiest way to know is to use the "Doodle Environment", once you are logged in, double-click the user who might be hiding and from the IM window, click "Environment" and then "Doodle", if your friend is online hiding there as invisible, then the Doodle environment will load and you can play with the doodle, but if he/she isn't online, you'll see "Waiting for your buddy to load Doodle" message on the page.
Hope this helps,
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 23, 2010 | Yahoo Messenger
2 year old daughter cratched my plasma screen with a magna doodle pen it is a plastic screen
Your plasma cover screen should be glass, not plastic. I have no knowledge of Panasonic or any other manufacture that made a plasma TV with plastic....all plasma TV's have a glass cover. Clean the surface with a rubbing alcohol solution and a cotton ball.
Feb 06, 2010 | Panasonic TH-42PX500U 42 in. Plasma...
On/off sound
hi
What sounds like? Like a frying pan? a high voltage sparking? or what?
Thanks!
Dec 27, 2008 | Curtis CM32020S 32" TV
Mattel Fisher Price Magna Doodle (PC) Logo
88 people viewed this question
Top Mattel Toys Experts
thegtw
Tracy E
Level 1 Expert
Tom Chichester
Are you a Mattel Toy Expert? Answer questions, earn points and help others
