Question about Traxxas T Maxx 3.3 Monster Truck
Traxxas t maxx 3.3 starts fine but as soon as it stops moving it stalls!!!!!
The truck will run fine but as soon as I put the truck on the ground it's cuts out. Please help
    Master:
  • 482 Answers
Loosen the tension on the slip clutch
Posted on Mar 07, 2013
  • 10 Answers
SOURCE: Traxxas Revo 3.3 shifting problem
you might need to reset the opti drive. turn the power on with the engine still off and hold down the optidrive button for 5 sec. see it that works.
Posted on Jul 07, 2009
SOURCE: my truck 3.3 t maxx wont move foward or reverse
sounds like blown diff or tranny gears tear it down
Posted on May 11, 2009
  • 88 Answers
SOURCE: When i hit the gas the engine goes but the truck barely moves
If the engine revs up and the truck barely moves either the clutch shoes are not engaging the clutch bell or the slipper clutch is loose and is slipping too much.
Posted on Dec 11, 2009
  • 88 Answers
SOURCE: Traxxas Owners Manual T-Maxx
You can get them from Traxxas directly. I think that you may be able to download them from their website.
Posted on Dec 24, 2009
  • 88 Answers
SOURCE: i have got a traxxas revo 3.3 with reverse but
Sounds like a problem with the opti drive module. It may need adjusted.
Tmaxx 3.3 starts and runs when holding off the ground but as soon as i put it on the ground it dies
Change your clutch shoes and spring, if shoes are still good,then just the spring
Mar 07, 2013 | Traxxas T Maxx 3.3 Monster Truck
T maxx 3.3 will start rate up but will not run at all but if i pick it up all 4 tire's spinn like mad but when put down just sits there and runs and smokes but will not move HELP PLZ!!
Check to make sure you don't have a bad servo. When you pick it up the wheels will spin just do to the amount of power the little engine is putting out. Put when you pull the trigger do they go faster? If not then the check these
1. make sure your trims are set correctly on the remote
2. you are on the right frequency - usually there are 3 settings..frequency can be checked by making the tires move side to side also.
3. if you have the trim set right, and the right frequency then you may need to replace the servo
May 30, 2012 | Traxxas T Maxx 3.3 Monster Truck
My traxxas motor looses power after running for awhile
this happens to mine sometimes too. i have found that if you richen the high speed needle about a 1/4 turn it works fine. it will also keep your engine temp. down.
Jan 16, 2012 | Traxxas 4910 T-Maxx RC Monster Truck
Traxxas 2.5 is overheating
wow, 315 degrees is way too hot. one way to fix that is to turn the high speed needle out 4 1/2 turns from all the way in. this will help fix the stalling problem and the heat.
Jan 02, 2012 | Traxxas 4910 T-Maxx RC Monster Truck
I took my traxxas t maxx 2.5 to the beach and started it up. It ran well for the first 5 minutes then ran prettly bad. When the t maxx was stopped and I gave it wide open throttle it would barley get up to...
Firstly the engine could have breathed in some sand from the beach thus causing the lack of power , it could also be that the glow plug requires changing too, this is a common problem on nitro cars, especially when the engine gets too hot and doesnt get much cooling. Reset to factory settings on the carb(see your manual or download one) then restart , also make sure you are using the correct fuel , it must be 20% nitro. Lastly for the replacement from 2.5 to 3.3 yes you can do it . all you have to do is unbolt the old 2.5 replace with the 3.3 plumb in and wire is as before , check the messing on the spur gear. though be cautious not to over rev the engine as you will strip the spur gear.
Apr 16, 2017 | Traxxas 4910 T-Maxx RC Monster Truck
My traxxas tmaxx 3.3 idles alot and wont go neutral
if the car isnt staying put when idling then the clutch shoes are sticking to clutch bell.If engine is stalling then would have to retune.
Aug 05, 2010 | Traxxas T Maxx 3.3 Monster Truck
T Maxx 3.3 full throttle issues.
Sounds like either the slipper clutch is too loose or the clutch shoes are not engaging the clutch bell.
Jun 16, 2010 | Traxxas T Maxx 3.3 Monster Truck
It will start just fine but will not move
Check the plastic gear where it meets the metal gear. These plastic gears stip real easy on these. Have had a few of the Traxxas
Apr 17, 2010 | Traxxas T Maxx 3.3 Monster Truck
My t maxx 2.5 is driving and steering by itself. when the engine isnt running everything works fine, but as soon as i start it it drives and steers and i have no control. ive taken it to many places...
Sounds like an antenna problem. Make sure the antenna is isolated from any metal of the chassis or engine. Also make sure the antenna is not damaged anywhere. You could try purchasing crystals on a different frequency, but I think that it is more likely a mechanical issue.
Nov 01, 2009 | Traxxas 4910 T-Maxx RC Monster Truck
Jan 27, 2009 | Traxxas T Maxx 3.3 Monster Truck
Traxxas T Maxx 3.3 Monster Truck Logo
110 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
cwradio73
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
