Etower 633m C drive has changed to C Drive REMOVEABLE DISK. Can not install HP D4160 printer. How do I correct this problem?
  • 827 Answers
This is normal with windows xp and nothing to worry about you cannotchange that. Win xp recognises sata hard disk as removable disk, so dontworry about it, and continue using it normally.
This has nothing to do with not being able to install a printer.
Download the software for the HP D4160 printer from here:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=501857&lc=en&cc=us&dlc=en&submit.y=4&submit.x=2&lang=en&cc=us
Unzip it to a folder.
Now plug in the printer. The Add New Hardware wizard will pop up, click Advanced and next to continue the installation. Browse to where you unzipped the driver to and select it to execute the installation.
When it has installed, reboot.
Hope this answers your questions
Chris (ziraffa)
Posted on Jan 18, 2009
Erase hard drive hp1055
In service test menu scroll to "3.Hard disc drive", & press enter, if test drive passed don't replace the hard disc or modification or changes. If test failed then check as shown below:
1 Switch the printer OFF. Remove the EIO Card (if installed) and re-install the Hard Disk Drive making sure it installed correctly by pushing it firmly inwards and checking that the two installation screws are completely tightened. Switch the printer ON again and repeat the Hard Disk Drive Test. If the Hard Disk Drive Test fails again then replace the Hard Disk Drive.
2 If the Hard Disk Drive Test passed after removing the EIO Card,then switch the Printer OFF and reinstall the EIO Card, making sure that the two installation screws are completely tightened.
Switch the Printer ON again and repeat the Hard Disk Drive Test. If the Hard Disk Drive Test fails, then the EIO Card could be faulty.Replace the EIO Card.
3 If the Hard Disk Drive Test continues to fail after replacing the EIO card or the Hard Disk Drive, then replace the Electronics Module..
I am having little knowledge, if I am wrong Pl don't comment, pl forgive me.
May 20, 2013 | HP DesignJet 1055cm InkJet Printer
Need software for hp desktop printer D4160
HP Deskjet D4160 Printer Basic Driver Installation Instructions:
1. Click on the Download Only button and a File Download box will appear.
http://www.nodevice.com/driver/Deskjet_D4160/get39222.html
Sep 10, 2009 | HP Deskjet D4160 InkJet Photo Printer
Where to install driver
put the driver onto a removeable disk, like a pen drive, then go onto the printer section in the control panel, find the printer you need the driver for then,right click on it and select properies > drivers> install driver from disk then selct your removeable disk and select the file which has the driver in and 'install' it
Jul 21, 2009 | Lexmark X3480 All-In-One Printer
Getting error code 04C300 00310000
Hi;
if you HP 1050C Plus display System Error 04CXX Try the following Steps to resolved an error:
1.)Press ENTER and switch the printer OFF. Remove the Hard Disk Drive (if installed) and make sure that the EIO card is installed
ON again. If this error code continues to appear then replace the EIO card.
2.)If this Error Code disappeared after removing the Hard Disk Drive, then switch the Printer OFF and reinstall the Hard Disk Drive, making sure that the two installation screws are completely tightened. Switch the Printer ON again. If this Error Code reappears, then the Hard Disk Drive could be faulty.
Replace the Hard Disk Drive.
3.)If this system error continues to appear after replacing the EIO card or the Hard Disk Drive, then replace the Electronics Module...
May 26, 2009 | HP DesignJet 1050c InkJet Printer
Wont print no print dialogue box
Here's a link from HP website that will scan and try to fix the problem automatically. Also insure the driver installed correctly with software.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01072463&lc=en&dlc=en&cc=us&lang=en&rule=15233&product=501857
May 26, 2009 | HP Deskjet D4160 InkJet Photo Printer
Please help me ??? system error
System Error: 04Cxxx
Problem
Description:
EIO Accessories (EIO Card/Hard Disk Drive) Error.
Corrective Action: Try the following:
n Press ENTER and switch the printer OFF. Remove the Hard Disk
EIO card.
n If this Error Code disappeared after removing the Hard Disk
n If this system error continues to appear after replacing the EIO
System Error: 0000D8 XXXXXXXX (Non-Continuable)
Problem
Description:
External Library Error.
Corrective Action: Refer to System Error Code 070100
System Error: 070100 XXXXXXXX (Non-Continuable)
Problem
Description:
Firmware Error.
Corrective Action: Power the Printer OFF and ON again to see if the System Error
disappears.
If the Error Code reappears, then report the error to the HP response
Center or the nearest HP Support Office, stating the following
information.
n Model and Serial Number of the printer.
n Which firmware revision the printer is using (See Note below).
Check firmware in Utilities / Statistics / Code rev.
n The complete error number (See Note below).
n The Service Configuration Print þ
n The Current configuration sheet.
n Which software application the customer is using (name, version, etc.).
NOTE When reporting the System Error Code, make sure that you
supply the full Error Code (including the last 8 numbers where
applicable) and the firmware version. Without this information,
HP Support Personnel cannot help you.
Apr 06, 2009 | HP DesignJet 1050c InkJet Printer
Need help installing my hp printer (Deskjet D4160) no disk
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=501857&lc=en&cc=us&dlc=en&submit.y=7&submit.x=9&lang=en&cc=us
visit this web page and choose your operating system and download the Driver
Wish You and Your Family A Very Happy New Year
Dec 28, 2008 | HP Deskjet D4160 InkJet Photo Printer
HP PSC 1210 Xi won't scan after installing HP Deskjet D4160. Scan.msi can't be found
try to locate this file from drive software disk or re-install the setup. bye
Aug 25, 2007 | HP PSC 1210 All-In-One InkJet Printer
Computers & Internet Logo
311 people viewed this question
David Payne
David Payne
