Question about U.S. Robotics MAXg USR5461 (738168036790) Wireless Router
What is the primary and secondary DNS?
All is in the title
  • U.S. Robotics Master
  • 7,627 Answers
F4i honda 2001 light is flashing 7 times on diagnostic code {fi light} then staying on does anybody know what 7 blinks mean
7 = Coolant Temp sensor or wiring.
A long blink = "10"
A short blink = "1"
DNS = Engine does not start
EON = Engine operates normally
BLINKS : PROBLEM, SYMPTOMS
No blinks: ECM malfunction, DNS
No blinks: ECM power / ground circuit malfunction, DNS
No blinks: ECM output line malfunction, DNS
No blinks: MIL circuit malfunction, EON
Stays lit: Data link circuit malfunction, EON
1 blink: MAP sensor circuit malfunction, EON
2 blinks: MAP sensor performance problem, EON
7 blinks: ECT sensor circuit malfunction, Hard start at low temp
8 blinks: TP sensor circuit malfunction, Poor performance on quick throttle operation
9 blinks: IAT sensor circuit malfunction, EON
11 blinks: Vehicle speed sensor circuit malfunction, EON
12 blinks: No. 1 Primary injector malfunction, DNS
13 blinks: No. 2 Primary injector malfunction, DNS
14 blinks: No. 3 Primary injector malfunction, DNS
15 blinks: No. 4 Primary injector malfunction, DNS
16 blinks: No. 1 Secondary injector malfunction, DNS
17 blinks: No. 2 Secondary injector malfunction, DNS
18 blinks: Cam pulse generator, no signal, DNS
19 blinks: Ignition pulse generator, no signal, DNS
21 blinks: No. 1 O2 sensor circuit malfunction (California only) , EON
22 blinks: No. 2 O2 sensor circuit malfunction (California only), EON
23 blinks: No. 1 O2 sensor heater malfunction (California only), EON
24 blinks: No. 2 O2 sensor heater malfunction (California only), EON
33 blinks: E2-PROM in ECM malfunction, EON
48 blinks: No. 3 Secondary injector malfunction, DNS
49 blinks: No. 4 Secondary injector malfunction , DNS
Aug 30, 2014 | 2001 Honda CBR 600 F(4)i
Could someone pls help me to configure my Samsung GT-B7722. My network Sun Cellular (Philippines) says they do not have the setting for my phone model. Thank you!
Since Sun Cellular does not have specific settings for your phone for an automatic configuration, you can still connect to the internet by configuring your device manually. You just have to look for internet settings in your phone and input the configuration as indicated below.
SUN GPRS Settings (HTTP & WAP)
Connects to:The Internet
Access Point:minternet
User & Password :
Primary DNS:210.23.234.65
Secondary DNS:0.0.0.0
IP Address:
SUN MMS Settings
Connects to:MMS Connection
Access Point:mms
User & Password :
Primary DNS:0.0.0.0
IP Address:
Go to programs-accessories-MMS Setup
MMS Connection
IP:202.138.159.78
Port:9201
Mmsc Address:http://mmscenter.suncellular.com.ph
MMS Download:Auto
Mar 22, 2011 | Samsung SGH-D900 Cellular Phone
I AM SIGNING UP 4 XBOX LIVE AND MY INTERNET CONNECTION FAILED IN RESULT OF AN INCORRECT SECONDARY DNS SERVER IM WONDERING WHERE DO U GO 2 FIND THAT
Have you tried dns settings in automatic? I take it from your post that you have the primary dns server, my primary and my secondary has only one number difference,
primary 194.168.4.100
secondary 194.168.8.100
you only have 9 numbers to try so its worth a go, I hope this helps because I know from experience what a frustrating pain in arse this can be.
Remember thumbs up if this helps.
Feb 03, 2010 | Microsoft Xbox 360 Console
DNS problem. I even upgraded the WRT54G by downloading some files.
try to use the global DNS address
primary-208.67.222.222
secondary-208.67.220.220
or
primary-4.2.2.2
secondary-4.2.2.1
Jan 17, 2010 | Linksys Wireless-G WRT54G Router
What is the primary DNS and secondary DNS?
There are two basic types of DNS - primary DNS and secondary DNS, which are generally applied to each newly registered domain. They are name server computers where the record of your domain name is stored. The information on both servers is identical. The two DNS values are usually configured by your ISPor hosting provider and given to you as a very important part of your domain registration order details.
In general, domain names can work with only one name server - the primary DNS. However, practice has shown that a domain name needs to have at least two name servers assigned in order to be available at any time. In case there is a problem with the primary name server, the secondary name server will be able to answer the online request for a particular domain. This back-up requirement has turned into an accepted Internet standard that prevents domain names from going offline.
Sep 23, 2009 | D-Link DSL-G604T Wireless Router
Cant log into yahoo mail
I had the same problem 2 days ago, I tried a lot of things and finally got the the solution.
It was a DNS resolution problem
In my wireless netgear DG 834GT router settings (through IE), at the DNS address I unchecked "get automatic from ISP" then checked to use the primary DNS at 4.2.2.2 and secondary DNS at 4.2.2.3 ( I followed the Router's manual instructions )
Maybe u have to see in your Router manual what address u have to put for primary and secondary DNS?
Good luck, hope this will help
Sep 15, 2009 | Yahoo Mail
Make additional DNS
Yes, all Windows Servers have the option to install DNS.
Set up a second Windows server and configure it to be a secondary server for your DNS domains on you current server.
Add the second DNS server's IP address to the secondary DNS field to your DHCP scope options and to all computers with static IP configuration so they will use it when your primary DNS is unavailable.
Don't underestimate Window's built-in Help and Support. It will help you install DNS and configure it.
Good luck.
Jul 29, 2009 | Dell Computers & Internet
Same problem as everyone else :"DNS error and some numbers"
Go to internet settings and manual set up then try these dns settings.
primary dns 4.2.2.2
secondary dns 4.2.2.1
~I find i dont always need to use the secondary one.
hope this helps :)
Jul 07, 2009 | Sony Playstation 3 (PS3) Console
Random DNS Error
You may need to manually configure your PS3 connection on the console. Let's see.. I can suggest to first go to your Settings Menu -> Network Settings -> Choose:"Settings and Connection Status List" this will display a pretty detailed information about your connection to your local gateway (router).. Check specifically for Primary and Secondary DNS. In my experience, using the PS3's auto setup for the connection seems to enter the default gateway's ip (labeled "Default Router" on PS3 Status Screen) in place of the real DNS entries..
Question
: Sooo how do you check your primary/secondary DNS for your network? Answer: On your PC, open a web browser and enter your default gateway ip into the browser.. log into your router (assistance can be found in your router manual or by calling your router manufacture). You should see a status page of sorts that displays your ISP's primary/secondary DNS entries.. Simply transfer those two IPs to your PS3 manually to correct the DNS issue.
Hopefully that should resolve your issue!
Jul 10, 2008 | Sony Playstation 3 (PS3) Console
Primary And Secondary DNS
Are you using a Cable Modem and a Router? I get problems like that when my Router is not working well. In which case I reset the Router (by unplugging it). Try connecting the PS3 straight into the Cable Modem, bypassing the Router.
Mar 23, 2008 | Sony Playstation 3 (PS3) Console
Open Questions:
U.S. Robotics MAXg USR5461 (738168036790) Wireless Router Logo
48 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Michael Galve
Michael Galve
Aris C.
Aris C.
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
