Question about Lenovo ThinkPad R61i 14 inch widescreen with integrated graphics PC Desktop
My R61i Function keys are not working
I have R61i "8932A87" having Windows XP-SP2. All function keys are not working. I checked that keypad light and wireless function keys are working. Rest does not work.
I dont know if any specific driver required for function keys to work. But if required why those two keys are working?.
Even I installed bluetooth driver, blue tooth device does not get detected.
Can you please guide me about this.
- Mihir
Ive got this problem, my the keys num 1, letter q, a and z dont work well, i mean, when i press letter a, a series of letters arrears, what is the problem? i tried to replace it with other keyboard but it always show the same problem, please help. sorry for posting in here instead of replying to the above problem posted..
thanks in advance..
Posted on Jun 01, 2011
  • 32 Answers
A software issue for sure
The reason why I say this is because you stated that the device could not be detected even with bluetooth driver.
Posted on Nov 23, 2009
All buttons have stopped working
Hi, different possible places to check,
The flex,
keypad IC.
The flex of the phone.
The flex is connected to the screen and it makes the screen display,Also if the flex gets damaged it will make the key pad not to work.
The keypad IC is found inside the phone boardand it make the keypad the function.If IC gets damaged, might cause keypad noe to function.
It depend of the keypad your talking about, if it's the lower key pad or the upper keypad where the menu is.
If it's the upper keypad is damaged, that means the keypad area is faulty,and will need to be replaced.
Have a nice day.
Sep 03, 2010 | Sony Ericsson Cyber-shot C905 Cell Phone
Xp service pack 3 key
There is no "key" for SP3, its just an update.
Just click on the start menu and perform a Windows/Microsoft Update to install SP3 and then perform another update to update SP3.
Regards.
Jun 26, 2010 | Microsoft Windows XP Professional SP3 Full...
Compaq 510 function key not working in xp
Volume control are not working? Do you forget to install sound drive?
dell latitude d620 battery
Apr 29, 2010 | HP Compaq Evo Notebook N410c
Some of my keys don't work.and restart my computter to the begining.
hope ur a professional..!!
howevr, try dis..
You'll need to edit the Registry Key HKEY_CURRENT_USER\keyboard layout\preload..change the "1" value setting to the Key name below..You'll also need to expand the file in the File Name to the System32 folder. You can use "System Sentry's" 'Inflate a File' feature to install the file..Layout Name: French; File (Y2K/XP): kbdfr.dll; Key Name: 00010407..
hope dis works..if not can post me comments..i'll try to resolve it better..
the other option:
You will need your windows xp CD to install additional language..
Go to Control Panel..
Click on Regional and Language Options..
Click on Advance option..
Select Language you require..
Click on Apply..
It will Prompt "Please insert Windows XP Cd"..
Insert the CD, and it will install the required files for running the language..
if the above all fails:
u r keyboard is likely to b defective or ur ram..
lightly strike/tap the keypad using ur hand..
open the keyboard..deep clean all the carbon contacts beneath the keys using Iso-Propyl alcohol..put/stick 'Carbon-Dots' (available in cheap level spare market) as n where necessary..
{In laptops with a small screen (14,15" ) the keyboard is accordingly smaller than for desktops, and there is no numeric keypads, or arrow pad. So the keys 7,8,9 0, U,I,O,P,J,K,L ,comma, dot, / have a triple function: the primary function, the shifted function, and a third accessed by an FN-Fx key combination. The actual key combination may depend on manufacturer. If that key combination has been activated, the foregoing keys perform the third function they were designed for..
Read your laptop manual to find out how the Fn- function key works and deactivate the Fn-Fx combination responsible for your keyboard behavior..}..
best is to seek advice of ur system admin/vendor....
Nov 27, 2009 | Gateway 2520915 Keyboard
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Mar 22, 2009 | HP 2133 Notebook PC
Function Keys
hi there
you have lock the the number on the keypad to remove this function as caps on caps off simply press fn and key F11/numLK same time and it will return to normal letter function on your keypad
May 19, 2008 | Acer NSK8458AN Keyboard
About windows setup
Hi niket_shah, sorry but you're board Asus M2N-MX, does support Win XP SP2.
Chances are that while installing windows updates one or more updates failed. People like myself know from repairing PC's which updates need to be installed first. If you're Win XP SP2 did not or would not install than either the Win CD is not a valid Microsoft Win XP SP2 CD or (You have a copy) & there is something wrong with the CD. After a fresh (New install) of Win XP with SP2 there is more than 90+ updates for SP2 which must be downloaded through windows update program. Or you're windows will not function properly.
Just to show you what versions of windows the M2N-MX board does support. Click the link listed below. Once the link loads click the + sign next to Audio. Scroll down the page an notice the different Window version listed for you're board.
http://support.asus.com/download/download.aspx?modelname=M2N-MX&SLanguage=en-us
To recap this issue. The problem is either the WinCD or possibly you're hard drive. Make sure you allow windows to perform a full format before installing window. (Not a quick format).
Mike
Apr 12, 2008 | ASUS M2N-MX Motherboard
Keyboard LX501 : Function keys work but number and alphabetic keys and other keys dont
Check the underside of the keyboard and see if there is a reset button (might be a small pin hole).
If not it might be a software problem.
Mar 23, 2008 | Logitech LX501 9674190403 Keyboard
How to install Windows XP Professional SP2
Check this Sol'n..
1. Boot(start) ur computer.
2. Press F2 to open up your BIOS Setup
3. Go to boot menu and set the 1st boot order to CD drive using function key. ex. F5
4. Change the SATA settings to IDE. Not
5. Save the new settings using function key before exiting. Ex. F10
It will restart and surely boot on your XP cd (if inserted)..
The rest are typical OS procedure.
From
#14DeeP
CCC-OTC Computer Operator
Mar 09, 2008 | Computers & Internet
Lenovo ThinkPad R61i 14 inch widescreen with integrated graphics PC Desktop Logo
288 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
