Question about Panasonic KX-TG5422M Cordless Phone
I have a Panasonic KX-TG1031B and am using 3handsets on another sys but I ended up with NOS 2 & 4, is there anyway that I can change these NOS. to 1 & 2 ? Or even better if I could add these 2 Handsets to my other system?
SOURCE: I have a Panasonic KX-TG6051CM
I had the same problem, and it seems that the battery charging circuit in the handset had locked up, constantly charging the battery until it overheated. I was able to reset the circuit in my handset by completely draining the battery. Here is the procedure:
1. Remove the handset from the charging cradle, and leave it on for a few days until the battery runs out, and the handset finally turns off. At his point, the battery will be very low, BUT NOT COMPLETELY DRAINED.
2. Next, you must manually drain the charge remaining in the battery by shorting out the two contacts on it. Shorting won't damage the battery, since it is holding very little charge at this point. An easy way to physically do this is to remove the battery, and place a piece of thin wire across the the two contacts of the HANDSET. I am referring to the contacts inside the handset that connect to the battery, NOT the contacts on the bottom outside that connect the handset to the charging cradle. Next, put the battery back in, sandwiching the wire between the battery's contacts and those inside the handset. This will hold the wire in place. DO NOT PUT THE HANDSET BACK INTO THE CHARGER, WITH THE BATTERY SHORTED OUT.
3. Wait about 30 minutes for the battery to completely die. Remove the jumper wire, and but the handset back into the charger.
4. If the battery was fully discharged , you will get a message on the handset telling you that you should let it will charge for 7 hours. If you do not get this message, then either the battery was not fully discharged, or your problem is different from mine. Try the procedure again in Step 3 for another 30 minutes to discharge the battery some more.
5. If you get the "Wait for 7 hours to charge" message on the handset, then leave it in the charging cradle for the 7 hours requested. After that, it should work fine.
Let me know how you make out.
Posted on Aug 11, 2008
SOURCE: Panasonic kx-tga101cs incorrect voicemail message
Press and hold "Clear" until it beeps. It will clear the invalid voice mail msg.
Posted on Jul 28, 2009
sarahkp
  • 11 Answers
SOURCE: hard to hear on one of the handsets
we have the same phones, the volume can be adjusted using the key pad but only slightly the hearing overall with this phone is not so great you end up straining half the time to hear the conversation
Posted on Sep 04, 2009
Phonesmith
  • 113 Answers
SOURCE: How do i Names to Extention numbers on the Panasonic KX-T7636
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook press Program * * or Program * # followed by the system password ( default is 1234). Now press 004 and then ENTER. Enter the extension number you want to change. Now enter the name (the same way as texting on a cellphone) To save the changes press AUTO DIAL / STORE. To go to the next extension press NEXT on the screen. When you are done lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
THANK YOU
Posted on Mar 23, 2010
SOURCE: Panasonic cordless handsets all say line in use
Return to the manufacturer for replacement. I've spent hours on this and have had my line tested. It's a base station fault.
Posted on Oct 02, 2010
Our company uses the PANASONIC KX-T7730 phone system, just wanting to know if customers can call directly to our extension numbers?
if your pbx has a built in disa feature, then you need to program
the DIL (sys. pgm. # 418) to DISA-OGM 1. Then you need to
record an OGM (program 9,1,1) to tell you customers that
they can dial the ext.# directly.
Oct 29, 2013 | Panasonic KX-T7730 Corded Phone
KX-TG1031B how do you retrieve messages at a remote location?
it's called remote operation. Press "MENU", then "number sign" and enter a 3-digit code of your choosing. Press "SAVE" and then "OFF" When you away from home, dial your phone number and after the greeting message starts, enter your 3-digit remote access code.
Dec 21, 2010 | Panasonic Lands Phones
How do I change the time on a KX-T7730 phone?
Basically, there are 2 ways of programming the date
and time - the short way and the long way.
If you are using the KX-T7730 phone on a Panasonic
KX-Txx 308/824 system:
SHORT WAY:
( ext 101, 10 or 9 ) with the handset on the
cradle/hook:
1. Press PROGRAM 0
2. Enter Date and Time
( The format is: yymmdd,
1 to 7 1=Monday 2=Tuesday etc, hh:mm,
0 or 1 0=AM 1=PM ) see example
3. Press AUTO DIAL / STORE to save your changes
4. Press PROGRAM to exit program mode
EXAMPLE:
If the date and time is 3 February 2010 Tuesday 2:15 pm you will enter as follows:
100203 2 02:15 1
LONG WAY:
From the Switcboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook:
1. Press PROGRAM * # followed by the system
2. Now press 000 and then SP-PHONE.
Enter the year.
3. Scroll to the month with the right scroll key
(located at the right bottom corner of the phone).
To change the month use the AUTO ANS / MUTE
button.
4. Now scroll right again and change the date and
day.
To change the day, again use AUTO ANS / MUTE
5. Scroll right again and the time will appear.
Set the time.
To change am/pm scroll to it, and again,
use the AUTO ANS / MUTE button.
6. Press PROGRAM to exit program mode and you
are done.
Mar 29, 2010 | Panasonic KX-T7730 Corded Phone
How to set the clock at a panasonic kx-t7730
SHORT WAY:
cradle/hook:
1. Press PROGRAM 0
EXAMPLE:
100203 2 02:15 1
LONG WAY:
From the Switcboard / Main telephone ( ext 101, 10 or 9 ) with the handset on the cradle/hook:
Enter the year.
button.
day.
Set the time.
are done.
Mar 27, 2010 | Panasonic KX-T7730 Corded Phone
KX-T7730 - Used to have 3 incoming/outgoing lines. Have cut this down to 2(lines 1 and 3). Outgoing calls are automatically selected by line 3, 2, 1. When calling out the second person can't get an outside...
If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system.
From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
1. Press PROGRAM * # followed by the system password ( default is 1234).
2. Now press 400 and then SP-PHONE. Enter the line number you wish to change. ( In your case 2)
3. Press AUTO ANS / MUTE to change between Connect and Not Connect.
4. Press AUTO DIAL / STORE to save your changes.
5. Press PROGRAM to exit program mode and you are done.
Mar 17, 2010 | Panasonic KX-T7730 Corded Phone
Hi, How do you change the time on a Panasonic KX-T7633 CORDED PHONE
There are several way that may adjust the Panasonic phone clock, please try the following suggestion method:
Method 1:
1) Press PROG soft button, follow by HOLD button.
2) LCD show direct the time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press END or HOLD to end the setting.
Method 2:
1) Press PROG soft button, follow by HOLD button, follow by # button.
2) LCD show time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press again # button to select between AM and PM mode.
4) Press again STORE to save the setting.
5) Press END or HOLD to end the setting.
Method 3:
1) Press PROG button, follow by key * * 1 2 3 4.
2) Press key 0 0 0 to display the day/time setting.
3) Press |> or SP-PHONE button if u wish to change the date.
4) Press |> or SP-PHONE button to change the time.
5) Press CLEAR or TRANSFER button to change current hour entry.
6) Press |> or FWD/DND button to change current minutes entry.
7) Press |> or FWD/DND button again and AUTO ANS button to change between AM or PM.
8) Press STORE to save the setting.
9) Press END or HOLD to end the setting.
Hope these help.
YBC (/\)
Oct 19, 2009 | Panasonic KX-T7633 Corded Phone
Change the time on the KX-T7633 pnone
Method 1:
Method 2:
Method 3:
Hope these help.
YBC (/\)
Jul 10, 2009 | Panasonic KX-T7633 Corded Phone
Clock on Phone
To set the time of the phone, there are several way that may help, please try the following suggestion method:
Method 1:
Method 2:
Method 3:
Hope these help.
YBC (/\)
Jun 24, 2009 | Panasonic KX-T7633 Corded Phone
Trouble with the display
Hi Mary
Which system are you using?
If you are using panasonic kx td 1232 then just press the * key keeping the handset on hook.
If you are using a panasonic kx tda system then just press the transfer button keeping the handset onhook.
To change the date you will need to goin the program mode by pressing the Program button followed by *# 1234. then it will show on the display sys pgm no : enter 000 and press autodial or enter. Then you can change the date.
Aug 08, 2008 | Panasonic KX-T7453 Corded Phone
Panasonic KX-TG5422M Cordless Phone Logo
441 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
