Question about Toshiba 57H81 57" Rear Projection Television
Bad bulb i need a new bulb but cant find one # p16lfm00bmb
  • 298 Answers
Here is Manual
http://www.pdmnetworks.com/play/servicemanual.pdf
Here are parts sources
http://www.mcmelectronics.com/product/483513127198
Posted on Jan 18, 2009
I have a 2007 honda 919 hornet, the headlight quit working. I changed the bulb and checked the fuse, headlight will not come on. Is it the relay or do I need to clean the starter botton?
head light has a relay
and starter solenoid has a fuse
not blowing fuses is good
could be a bad earth at the bulb holder
if you cant go faster than JAWS
"you are going to need a bigger bike "
if you touch the bulb glass with fingers while fitting the bulb
it may blow the bulb
Nov 26, 2016 | Honda Cars & Trucks
Wired in new directional on sportster wont flash
From your description, it sounds like the new bulbs (that won't flash) are LED bulbs.
When you replace the stock Harley incandescent bulbs with LEDs, you NEED to add a LOAD EQUALIZER to make the bulbs flash:
http://www.jpcycles.com/product/381-877
The amp draw is different with LEDs, and they won't flash without the equalizer.
May 06, 2014 | 2001 Harley Davidson XLH Sportster 883...
MY HEAD LIGHT WILL NOT COME ON.EVERYTHING ELSE WORKS.CHECKED FUSE IS OK.NEW LIGHT BULB.
Bad ignition switch. Very common problem with these bikes. It needs a new ignition cylinder and key. Or if you are mechanically inclined,you can take the ignition cylinder apart and check the connections inside.If they are worn slightly,its fixable. But most times they wear to the point where they cant be fixed,and must be replaced.
Aug 29, 2012 | 2003 Honda VTX 1800 Retro Spoke
Samsung HLN617w
engine is bad most likely. youd either need a brand new engine which is well over 500 big ones or they do have used ones available.
i have an hln617w that everythings good except the bulb. cant afford new one if your interested let me know
Oct 03, 2011 | Samsung HLN617W 61" Rear Projection HDTV
Buick Century, turn signal stops working replace daytime running bulb and then works fine for a week or two, and then it fails once again! Is there a flash regulator or something else that needs to be...
CHECK TURN SIGNAL FUSE.IF FUSE IS GOOD.TURN SIGNAL IS BAD.IF FUSE IS BLOWN.FIND SOURCE OF THE PROBLEM.BEFORE REPLACING THE FUSE.FOR THE DAY TIME LIGHTS.YOUR LIGHT BULBS IS HALOGEN.WHEN REPLACING THEM YOU HAVE TO WEAR CLEAN GLOVES FREE FROM OIL GREASE OR DIRT.BECAUSE THE BULBS WILL OVER HEAT AND BLOW.YOU CANT TOUCH BULB WITH HANDS.YOUR HAND HAVE OIL IN PORES.SO YOU HAVE TO WEAR CLEAN NEW GLOVES WHEN HANDLING BULBS.
Aug 18, 2009 | 1999 Buick Century
I cant get my high beams to turn on. New bulbs.
the problem could be in your fuse control....check on the fuses related to your high beam and get back
Aug 15, 2009 | 1993 Chevrolet Corsica
Rear flasher not working front flasher flashing rapidly
with the blinker on hold the socket in your hand and wiggle on the bulb and see if it starts to blink. if so then you have a bad socket that needs replaced or sometimes can be cleaned and apply electrical grease. if you cant get the bulb to blink then get in vehicle and watch the signl indacator while putting pressure on the selector in which ever direction your having problems with. if you get it to work properly by doing this then you will need a new switch .
Jan 29, 2009 | 2003 Ford Explorer
Red bulb
convergence amp ic are bad
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 19, 2008 | Panasonic PT-56WX53 53" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
