Question about Monster Panasonic System Cable Sa-ht720 Sa-ht730 Sa-ht733
Connect panasonic SA HT 720 to digital cable box
I had a professional connect the cable to the tv and the dvd to the tv, but he was missing the piece to connect the dvd to the cable box, what piece to connect the two?
Sanyo TV connect to cable box connect DVD player
If your DVD/VCR combo player has three RCA connectors (yellow, red, and white), you can connect them to the corresponding inputs on the front of your TV.
Dec 29, 2012 | Sanyo Televison & Video
Run DVD through tuner
ok a bit confused, Tuner ? like amplifier or Tv Tuner ? regardless seems like a easy fix .
First your cable box as 3 cables:1st . Power cable to outlet
2nd. From the wall ( usually a Coaxial cable coming from outside box ) into cable box.3rd. HDMI or Second coaxial cable ( One of these usually goes to the back or side of your Tv depending where inputs are located.)
Now Dvd has 2 cables 1st to Power2nd. To TV ( Hdmi or Coaxial )
On the back of your Tv will have 2-3 HDMI inputs . Assign 1HDMI jack to each media your trying to use.In this case TV HDMI 1, HDMI 2 DVD.
Assigning HDMI's will now reflect on your TV menu selection. Choosing HDMi 1 or HDMI2 from Tv menu will allow you use or view desired Media option in this case DVD or TV.
Now if there is Amplifier / Tuner involved like to connect surround sound to, connection may be a bit trickier however same principal.Plug all media into HDMI 1, HDMI 2, respectively,this time to the back of the tuner NOT to back of TV.Once you have done that You will need a third HDMI cable now from the back of the Tuner ( output Jack, usually has lighter color markings indicating Output HDMI) to your HDMI 1 jack in the back of your TV. Now you have bridge TV/ Cable , DVD into Receiver / Tuner and Selecting media will now be done not through TV Menu as before but through Tuner / Receiver menu or selection.
Good luck .
Good Luck
Sep 20, 2012 | Panasonic DVD-A120 DVD Player
Moved and lost power supply from dvd to wall. SA HT-720 model SR#DE4 1F005628 Theater Home Sound System
http://www.nodevice.com/user_manual/panasonic/dvd_cd/sa-ht720.html
There is a power CORD p/n K2CB2CB00006, but no external power supply.
You could search for that specific part and pay an arm and a leg for it or just go to any Radio Shack or electrical supply store and pick one up for about $8. You may even have one unused somewhere around the house.
Aug 03, 2011 | Panasonic SA-XR15 Receiver
Can I connect a Sony DVD Player DVP-SR90 to the Panasonic Home Theatre SC-HT75 to achieve surround sound without direct SCART connection - and how?
You can connect your Sony DVD player to your Panasonic HT using an analog RCA audio cable (white and red) for stereo sound. Connect to the AUX inputs on the HT and select AUX. Since the Sony DVD player only has SCART, you would need an adapter, scart to RCA. Like this one:
http://www.maplin.co.uk/scart-to-3-phono-plugs-with-in-out-switch-28102
Check for compatibility. Use the red and black RCA plugs for the audio into the HT.
Your Panasonic HT does not have a digital audio input which would be required for multi-channel surround sound (Dolby Digital 5.1)
Mar 14, 2011 | Panasonic SC-HT75 System
I have an older Panasonic HDTV Viera and I am trying to hook up a Panasonic DVD/sound suround model SA-HT920 and am not having any luck getting it too work. I have the sound turned off on the tv speakers...
What does the TV really need from the receiver in all of this? Minimally, Component video for the DVD and managing the SA-HT920, not much else.
A TV is not normally an optimal source of audio.
Your broadcast TV-related sound would be higher quality and easier to obtain if you got it from the Cable or Sat box you probably have. Route ITS BEST (digital multichannel) audio directly to the SA and and its BEST (HI-DEF) VIDEO directly to the TV. You could also run vanilla analog audio to the TV so you can watch news in lo-fi audio on the TV.
The exact model of TV would be helpful to know as audio capabilities may vary.
Should you still feel the need to run TV-originated audio to the SA from the Viera through its headphone or audio output, connect that to any available analog RCA input.
Connection of a jack into the audio output will pass unmodified TV audio to the SA. That's a good thing as the REAL audio electronics needs an unmodifed source for best results.
Feb 13, 2011 | Panasonic Audio Players & Recorders
The sylvania plasma tv does not have a coaxial cable connection, how do I connect my local cable?
You just can't. Not without an external receiver.
Your TV is simply missing a piece of hardware - it is called TUNER - that can understand the signal that runs through the cable (or an antenna) and decode it into simple video signal.
So the only solution is to buy an EXTERNAL TUNER device (also called external receiver or external set top TV box).
Those are rather cheap compared with what they used to be, but if you care for an advice from professional it is: sell your TV and use the revenue towards the purchase of a new one. All TVs currently in the mainstream sales channels have that thing built-in.
Some of the older models that you will find on Craigslist (like yours) do not.
it is usually not a problem for users with cable TV because most cable TV boxes also have a built-in tuner. If you are talking about how to connect your TV to your local cable company then the right thing to do is call your cable operator and tell them you want a newer receiver that outputs standard composite (one yellow one red one white) or component (green, blue, yellow and white and red) - if your TV has the later.
Hope this helps. If it does please rate accordingly.
Cheers,
www.coppelltvrepair.com
Oct 18, 2010 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
How do I get my Panasonic sa-pt670 to play all the speaker. watching tv and with ps3
Does you Tv set have optical out? If so might I suggest running HDMI into your television set from the PS3, then run an optical audio line out from the tv into the optical line in on your HTIB
Feb 24, 2010 | Panasonic Home Theater System System
Cant hook dvd/vcr to my cable box the manual says I need a extern
The cable box IS an external tuner.  You should connect the video output (either S video, HDMI, or component video) of the cable box to the video input of the DVD.  Then connect the audio output of the cable box to the audio input of the DVD via stereo RCA cables.  If your tv monitor has multiple inputs (ie: video 1, 2, and 3...) connect the video and audio output of the DVD to your tv monitor using an alternate video input (if cable box goes into your tv thru video 1, connect the DVD to video 2).  If your cable box only has one output, or your tv has only one input, then just connect your cable box to the DVD as above, and connect the DVD to your tv.
Jun 21, 2009 | Philips Magnavox DVD/VCR Dual Player
Monster Panasonic System Cable Sa-ht720 Sa-ht730 Sa-ht733 Logo
82 people viewed this question
Top Monster Audio Players & Recorders Experts
Lawrence Oravetz
Phillip Hicks
Phillip Hicks
Bill Boyd
Are you a Monster Audio Player and Recorder Expert? Answer questions, earn points and help others
