When turn tv on there is sound but no picture and the power indicator is flashing
Only happens now and then
    Sergeant:
  • 214 Answers
I would get it repaired immediately before it takes other things out with it.
Posted on Dec 30, 2012
SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Posted on Jul 19, 2007
  • 1153 Answers
SOURCE: tv power button flashing no picture or sound
Short in powersupply check secondary fuse and all other fuses too. Were there a color problem before this/ Because most of these set have convergence problems. The amps May need to be changed and resistors around them.
Posted on Aug 25, 2007
SOURCE: TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Posted on Sep 14, 2008
  • 7 Answers
SOURCE: TOSHIBA TV NO SOUND NO PICTURE, POWER LIGHT IS ON
the lamp in the projector might have went. try replaceing it. to do so try
ADTECH SYSTEMS they may help
there in mass.
call David Crepeau at 978 261 1087 tell him Ryan Bolduk sent you
depending where you live. They maybe able to send someone out from there sub company
Posted on Sep 18, 2008
  • 8 Answers
SOURCE: toshiba TP43H95 projection tv has power but no picture
If it shuts off and then the power light starts blinking red or it never comes on but the power light just blinks red continuously that is usually indicative of the convergence ICs (STK 392-110). You never want to replace the ICs without also replacing the resistors that are associated with them. There are usually 6 resistors, one for each of the colors and there corresponding direction, IE Red horizontal, red vertical, blue horizontal, ect. In the case of this model tv all of the resistors are 2.2 Ohm and 2watts. You will find them right where the STK 392-110 ICs are. Right in front of them. They are blue and have this color code on them. Red, red, gold, gold. These are represented by stripes on the resistors. You can get the parts from www.bdent.com They carry the ICs and the resistors. If you do not feel comfortable completing this repair I could do it for you if you send me the board. My email address is: missionelectronics@sbcglobal.net The cost is 375.00 and that includes parts.
Good Luck.
Posted on Jun 26, 2009
Negative picture,lamp indicator flahing 3 minutes after turning tv off
sounds like your system board is really shot ....did you have a power glitch recently? got backup?
Feb 11, 2008 | Sharp 65DR650 65" Rear Projection...
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
No picture, no sound, indicator light on then goes into flashing
micro chip problem it is damage.have a tech look on your set for repairs.good luck.
Feb 28, 2010 | JVC 47 in. LCD TV
TV PICTURE GOES OUT AND THEN SHUTS OFF
sounds like dodgy buffer board or video pcb
Sep 25, 2009 | Televison & Video
Vizio P50HDM No Picture/No Sound
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
TV won't turn on
Is a good thing you have an indication of power,it means some volts supplies are working ,your set might have a shorted output transistor and he is the responsible for lighting up the picture tube and energize a transformer that also provides voltage supplies,if the transistor is bad it has likely open the safety resistor that gives him the power to operate.If you are familiar with tv service you can check this part to start but if you are not too familar with tv service be safe and call for the assistance of a servicer.
Oct 09, 2006 | RCA F27650 27" TV
No sound or picture
Your tv is going into protection mode, it has detected a short in one of tv's circuits. thus, not allowing your tv come on. Can give you more detail if you want to repair it yourself, or call a factory authorized repair shop to assist you.
Sep 04, 2006 | Toshiba 43A10 43" Rear Projection...
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
