Question about Sharp El-6710s 34kb Electronic Organizer
I haven`t used my sharp el-6710s in a couple of years. And when I finally put a battery in it.It keeps on showing press reset and when I do it show data problem. How can I fix the problem?
4 Suggested Answers
drifterK
  • 4924 Answers
SOURCE: jgeorge@yahoo.com.auhave put new batteries in
The device have to be powered and on when you press the reset button ..and if it the reset is functioning it has to restart the device when is pressed..Only then you know for sure that it was reset ....Another thing to do is to remove any memory card or anything that may not be read proper in it ...and start it again ..If same thing happens than remove and reinsert the battery ..and power it up without any media in it ..like stick or card of memory ..If still makes the same issues..you have to get to the support site ..and download the firmware soft and install it again ..cause it was damaged during the battery changing process..If it has a permanent rechargeable battery ..you should change it ..while the device was plugged into the charger ..cause if it do not have a cmos battery ..the memory flash lost the firmware when it was with no battery at all ..reinstalling the firmware will do the job in this case..
Posted on Jan 12, 2011
SOURCE: i inserted a new battery to Sharp EL 6092 ,it tell
First press the reset button then when the display says "RESET OK ?" press the CAPS button then the button marked "2nd" (bottom left hand corner) then press Enter. Display will then say "BUSY". Reset is then complete.
Posted on May 28, 2011
SOURCE: Can you tell me how to reset my organizer
push the reset with pencil and then 2nd edit & enter
Posted on Jun 07, 2011
I have anEl6710s and can't read the screen , is there a fix or do I need a newer one?
chances are it has been pressed on to hard or extream heat or cold will cause this better off buying a new one
Oct 14, 2014 | Sharp El-6710s 34kb Electronic Organizer
Need instruction book for EL 6710S
Initially, pls try here for the EL-6750, a slightly newer version..
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 18, 2008 | Sharp Computers & Internet
Sharp el 6710s
im still trying to figure out why my hp 4620 doesn't print or copy
Jan 24, 2014 | Office Equipment & Supplies
How to reset Sharp el 6710s
Hi! Today I had the same problem, after you click on reset, the screen will show you RESET OK?, there you just need to press 2nd and ENTER key, the screen will show the word BUSY for a while, and then it will be reset; you'll be prompted to enter your business data and you're done.
Dec 04, 2012 | Sharp EL Office Equipment & Supplies
Mar 08, 2010 | Sharp Personal Organizer & Spanish/English...
The calculator is intermittent: Most of the time
Not knowing what to do, I tried anything that could possibly help:
I installed fresh batteries and I pushed the reset button on the back of the calculator (Sharp EL-546L) and finally, it work all right after more than 5 years I own the calculator and where it did work correctly for 5 minutes. I tried the reset button in the past (long time ago) and it didn't work. This time it worked because, maybe, I've used fresh batteries.
Marcello
Jun 03, 2009 | Sharp EL-738 Scientific Calculator
EL*6710s
Try this: after pressing reset, then press 2nd and enter.
Jan 10, 2009 | Sharp AL 1631 Copier
EL 1801V - how to set time/date?
To change the date, enter the date in MM.DD.YY format, pressing the decimal key between the month and day (will show as a decimal on the display) and the day and year (will show as a dash on the display). Then, press the Time/Date key (the one that looks like a clock and a calendar). The new date will show on the display. Note that if the month is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. To change the time, enter the time in 24-hour HH.MM format, pressing the decimal key between the hour and minute. Then, press the Time/Date key. The new time will show on the display. Note that if the hour is less than 10, you do need to press the 0 (zero) key for the first digit, even though it will not show on the display. Hope this helps! :)
Sep 02, 2008 | Sharp EL-1801P Calculator
Ho w to set the date and time
Go to the link below. You need adobe acrobat to read. THere is a section in the manual called "Adjust Date & Time"
For Date:
Put Calculator on RATE SET
Press Time/date key: enter the date using a decimal between the month, day and year (all 4 digits) please the date/time button. It should reset. (Exmple: 01.16.2009)
For time:
Leave Calculator on RATE SET
Press Time/Date key until time shows up. just like date, press the hour then the decimal then the minute. (Example if the time is 10:15 you enter 10 . 15) Press the Time/Date Key and the time is set.
This link is the manual:
http://www.sharpusa.com/files/cal_man_EL1750PIII.pdf
Jun 04, 2008 | Sharp EL-1750PIII Calculator
Sharp El-6710s 34kb Electronic Organizer Logo
35 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
