Question about Sony KDL-32M3000 32 in. LCD Television
My Sony KDL-32M3000 has ghost (dark red) display with slow motion picture. What could be the cause and how can it be repaired. Thanks
  • Sony Master
  • 8,617 Answers
Thats usually caused by bad flex tab bonds on the LCD panel itself. If you search for flex tab issues vidoes it will show how the pisture can get slow motion in areass as well as double images in that area.
Posted on Dec 30, 2012
  • Sanath Sirimanna Jan 01, 2013
    Thanks Sonny Berry. I checked the flex tab issues and but could not get an idea to resolve the issue. Do you recommend any solution?? Thanks
  • Sonny Berry
    Sonny Berry Jan 01, 2013
    I have had some sucess by doing a Compression type repair meaning locate which tab connection by pressing slightly on each one and the picture will snap in perfectly when you touch the one that has the issue then using thin layer of rubber between the panels frame and the flex tab itself so the panels frame causes the rubber to press slightly down on the tab bonds. If you need more info on the tab bonds go to www.tvrepairworld.com and hit the contact us button on their website and ask for info about the flex bonds and include your model number.
4 Suggested Answers
SOURCE: i have a sony 32m3000 color is dark and red also
@circuitworld: You claim in your profile that you repair plasma and LCD TV's, but you just told someone with an LCD to replace the convergence IC's and linear buffers. First off, convergence IC's are in rear projection TV's not LCD's, and the buffer boards are in plasma's, again, not in LCD's
@gardenwc: Typically what you are experiencing is a bad video controller or an actual faulty panel, the latter of which is not cost effective to replace.
Posted on Feb 02, 2010
SOURCE: Hello. My SONY KDL-32M3000 gets vertical
man, same problem here!! we got this tv, the same model as the one you have, we got this last 2008.. so basically its already 2years.. and last night.. i got this white stripes that are vertical then suddenly shuts down.. i dont know what to do.. im pretty sure sony wont cover this cuz its already more than a 1yr we got this tv, but still.. i cant believe tv like this has a short life span.. our old box tv was even more better.. it lasted 6yrs!!!
Posted on Oct 06, 2010
budmrtn
  • 11361 Answers
SOURCE: Sony kdl-32m3000 picture is suddenly
The typical repair shop will charge you $50~70 just to give you an estimate, the repair bill can be from $150 and up plus parts.
I suspect the problem to be in the T-CON board but need to see what you are seeing on the screen.
I will help if you can post the pictures.
Learn about T-CON board: http://www.mediafire.com/?zzjygannjty
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Aug 29, 2011
Has verticle lines and turns off.
SONY LCD TV 32 inch, Display problems. Display half white colour.
Jan 20, 2012 | Sony KDL-32M3000 32 in. LCD Television
I have a Sony KDL-32M3000 LCD TV.. When I turn the tv on you can see the screen lite up with no kind of picture, Almost like a lite comes on then goes out the the lite comes on again with no picture but I...
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks!!@#
Mar 25, 2011 | Sony KDL-32M3000 32 in. LCD Television
I have a Sony Bravia KDL-40s5100 and the screen is now red and dark and seems to be in almost slow motion. My warranty is up by 28 days and Sony will not honor the repair and told me it was my cost. From...
This problem can be caused by bad connections on the LVDS cable (the signal cable from the main pcb to the display control pcb.), sometimes cleaning the control pcb socket/cable plug can cure this. Other possibilities are: the display control PCB, or more probably, the display itself.
Jan 03, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
My Sony KDL-32M3000 has dark reddish picture, checked the ribbons around the frame they're ok, power supply is ok, Hi voltage board is ok, I'm guessing the main video processing board since I don't have a...
It will be either BM board (Video Processor board) or Tcon Board (top side of panel). I have similar problem...my TV turns on, lamps turns on (you can see them from back side panel holes) but just a dark blue picture appears with no image (like picture when external input is selected without signal), no OSD appears....some times I can heard audio (using Antena).
I'm thinking getting the BM board.
Dec 25, 2010 | Sony KDL-32M3000 32 in. LCD Television
Hello. My SONY KDL-32M3000 gets vertical white lines when started then dark screen with ghosts. Tried to contact SONY but, no help Tv is out of warranty. Is that possible for a SONY tv ?. Is that the...
Sep 23, 2010 | Sony KDL-32M3000 32 in. LCD Television
Sony Bravia with really bad ghosting
The little board on top attached to panel.
Jul 05, 2010 | Sony Bravia KDL-32ML130 32 in. LCD TV
I have a sony 32m3000 color is dark and red also
Nov 03, 2009 | Sony KDL-32M3000 32 in. LCD Television
Slow moving image sony bravia KDL32M3000
Hello darwin_gabou, My names Dave! You have a bad A/V input board.
Part #: A-1376-788-A
Link to part: http://www.shopjimmy.com/catalog/product/view/id/169673/s/sony-a-1376-788-a-bm-board-for-kdl-32m3000/
Please feel free to contact me if you have any question. I'll be more then happy to answer any questions you may have!
Dave
503-432-9904
Premium TV Tech
www.pleasefixitdave.com
pleasefixitdave@yahoo.com
Sep 23, 2009 | Sony KDL-32M3000 32 in. LCD Television
Sony KDL-32M3000 32 in. LCD Television Logo
827 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
