Question about Linksys E3000 Wireless Router
Only one ethernet port works
Wireless all work fine, but as time goes on Ethernet ports drop one by one. If I plug a device into the only remaining "GOOD" port all works right and the indicator light show up showing the connection. If I plug into any of the three bad ones the computer shows no connection and the lights on the router show no connection. The good port is port two. I have logged in to the admin of the router and see no place where it specifies the ports individually so see the problem. If memory serves me right, I went through this a year ago or so and then one day they all started working again. I have restarted the router so many times I lost count. I am running dynamic broadband settings on the internet side and appear to have a solid internet connection.
  • 345 Answers
Http://support.linksys.com/en-us/support/routers/E3000
Download the newest firmware for that router (be sure to get the right version number, this is VERY important) and see if that helps. if it doesn't help, It sounds like you have a router that is going bad.
Posted on Nov 03, 2013
3 Suggested Answers
kleeper
  • 87 Answers
SOURCE: Internet Intermittent Drop Out
I know that it has worked previously, which frequently happens even though it may not technically correct. When software is changed on one or more computers, or seemingly, enough time passes, things go haywire.
Your cable modem connects you to the outside world, it assigns IP addresses by DHCP (if enabled), to each connected device, so does a wireless router. If you connect the WAN port on the wireless router to a regular port on the cable modem/router, your wireless router will recieve an IP from the first router. Then it will assign addresses similarly which could be the same range, This is known as double NATting. Since you connected the the wireless router as a hub, it only assigns wireless addresses, not wired ones. Since they may be in the same range, this could work, but not reliably.
Here is what to do;
  1. Do nothing to the primary cable router.
  2. Connect a laptop or other computer to one of the lan ports of the wireless router. Nothing should be connected to the other ports.
  3. Manually assign this PC the address 192.168.1.2
  4. Using your web browser on the PC, connect to http://192.168.1.1
  5. The default login is left blank, password is admin.
  6. Network Setup tab
    The Network Setup section changes the settings on the network connected to the Router’s Ethernet ports. Disable the DHCP server setting
    Wireless Setup is performed through the Wireless tab.
    At the bottom of the page click SAVE SETTINGS
  7. The Setup Tab - Advanced Routing
    This tab is used to set up the Router’s advanced functions. Operating Mode allows you to select the type(s) of advanced functions you use. Dynamic Routing will automatically adjust how packets travel on your network. Static Routing sets up a fixed route to another network destination.
    Operating Mode. Select the mode in which this Router will function. Since another Router exists on your network, select Router. When Router is chosen, Dynamic Routing will be enabled.
    Dynamic Routing. This feature enables the Router to automatically adjust to physical changes in the network’s layout and exchange routing tables with the other router(s). The Router determines the network packets’ route based on the fewest number of hops between the source and the destination. This feature is Disabled by default.
    From the drop-down menu, you can also select LAN & Wireless, which performs dynamic routing over your Ethernet and wireless networks. You can also select WAN, which performs dynamic routing with data coming from the Internet. Finally, selecting Both enables dynamic routing for both networks, as well as data from the Internet.
  8. Connect wireless WAN connector to one one cable router lan ports
The PC should be changed back to DHCP for its IP and everything should work normally. All PCs on the system should get their IP address from the primary router only and should be visible to each other.
Posted on Oct 22, 2008
  • 83 Answers
SOURCE: Lost CD
To get my connection to work, I had to configure my Netopia DSL modem for Bridged Mode and let my router take care of the routing and address assignment. I would also try to get a working connection before configuring security. You can always do that later. You have the order of powering up you equipment correct. Read this link. It works for me.
http://www.dslreports.com/faq/15855
Posted on Apr 22, 2009
I am trying to set up a switch between my PS3 and my PC. I have an external DSL modem. I purchased a 5 port switch(Rosewill RC405-x) but no luck. Can I use an ethernet splitter instead?
You did not explainhaow you connected all your equipment together.
Connect your PC and PS3 into the 5 port switch.
Connect your DSL modem into the 5 port switch, if there is a WAN/internet port on the 5 port switch then connect the DSL model into this port.
You may need to power off the 5 port switch wait a 1 min and power up the 5 port switch again so it can setup an IP address table for the connected ports.
If this still does not work the replace the 5 port switch with a normal 5 port hub.
Mar 20, 2012 | Rosewill RC-405 - Switch - 5 ports -...
Ethernet Controller Error
Since your wireless is working, the missing driver is for your ethernet port. Go to gateway support driver download (link below). Select your computer by following the on screen prompts and download the driver for you LAN port.
http://support.gateway.com/us/en/product/default.aspx?tab=1
Mar 01, 2012 | Gateway NV7921u (890552676248) PC Notebook
I need to lock my router from others using my wifi
    • 1 Disconnect the power cord from your high-speed modem. Locate the Ethernet port on the back of your modem. If an Ethernet cable is already plugged in, trace the cable to the second device and unplug the cable from it; otherwise, plug one end of an Ethernet cable to the open Ethernet port on your modem.
    • 2 Plug the unused end of the Ethernet cable to the port on the back of the router labeled "modem." Plug a second Ethernet cable into one of the open ports located above the "modem" port; connect this cable to the Ethernet port on your computer.
    • 3 Reconnect the power cord to your modem; wait for the lights on the front panel to turn green before proceeding. Plug one end of the router's power cord into the corresponding port on the back of the device; plug the remaining end into any available electrical outlet.
    • 4 Turn on your computer and log into your operating system as normal. Insert the installation CD into the computer; the installation application should load automatically (if it doesn't, you can find the application by manually browsing the CD's contents).
    • 5 Follow the onscreen instructions; after you have made the initial configurations, click on the option labeled "Security Assistant" on the left side of the installer window. Select the desired security type for your wireless network and click on the button labeled "Next."
    • 6 Choose a network key and enter it into the appropriate field; press "Next" and follow the onscreen instructions.
    • 7 Open your computer's wireless network settings and enter the wireless network name, security type and network key into the appropriate fields. Save your changes. Set-up is now complete.
Tips & Warnings
  • You can access additional settings via the modem's manual configuration interface. Open your web browser and navigate to 192.168.2.1; when prompted for a password, leave the field blank, and click on the button labeled "Submit."For optimal signal strength, choose a location for your router that will be near your computer, with as few walls and other obstacles as possible.
Read more: How to Set Up a Belkin N F5D8236-4 Wireless Router ' eHow.com http://www.ehow.com/how_5106168_set-belkin-fd-wireless-router.html#ixzz1ONVtjSQ1
Jun 05, 2011 | Belkin F5D8236-4 Router
I need to know where to plug the big yellow phone cord. One end goes in the top plug in the back of the router and where does the other end go? In the back of the motorola motem? What else is supposed to...
The cord you are referring to is a CAT5 network cable. The color isn't important, but they usually ship the routers with color cords to help with the installation. Typically you would have the following setup:
1. A CAT5 network cable that runs from your broadband modem TO your Belkin Wireless Router in the "Internet" port. (Port "a" in the diagram)
2. Now plug another CAT5 network cable in to the back of your computer's Network Interface Cord TO one of the remaining ports on your Belkin Wireless (Any of the port "b" in the diagram).
However, you will need to run the configuration software that come with your router.
Please let me know if I can further assist you.
Regards,
KYTechnology
Mar 02, 2011 | Belkin Basic Wireless Router
Bigpond have sent me my 4 port Wi-Fi modem thompson TG782T Home Network Gateway, now I am sitting here trying to figure out just where everything goes!!! I received a cd rom however I can't get it to work,...
Telephone wall-plate <---- 4-strand telephone-cord ---> telephone-port in modem
AC power from wall-plate to modem.
LAN port #1 <--- Ethernet cable --> network-port on desktop/laptop computer #1.
LAN port #2 <--- Ethernet cable --> network-port on desktop/laptop computer #2.
LAN port #3 <--- Ethernet cable --> network-port on desktop/laptop computer #3.
LAN port #4 <--- Ethernet cable --> network-port on desktop/laptop computer #4.
Configure the router's wireless adapter:
* set a SSID
* set an encryption-level, e.g., 'WPA'
* set a network password
Use the SSID/password to configure your wireless devices (iPod Touch, iPad, XBOX 360, etc.)
Nov 26, 2010 | Gateway Computers & Internet
Wired connection randomly drops
Since the wireless works fine on your router, then it is possible that there is a problem either on your ethernet cable or on the port of the belkin router.
Try a different ethernet cable. (Ethernet cable is the one that is connected from your computer to the router.) If you don't have a spare cable, you can directly connect the computer to the modem, just to isolate the issue and determine if it is the cable or the computer itself.
If you have determined that the cable is working fine, then try a different port on the router.
I hope this helps!
Jul 24, 2010 | Belkin F5D7234-4 Router
I cant install my router. The internet, power, WLAN, and DMZ lights are all on, but none of the Ethernet port lights are on, but when I try to complete the install I get the following error message: Unable...
If the ethernet light is not coming that means your router is not detecting your computer. Try to plug the computer on any other port.
To check if your ethernet ports are fine you can perform a loop back test. You can take a cable which is not connected to anything. Than put one end of the cable to one ethernet port and put other end of that same cable to any other ethernet port. If the light on the ethernet ports led up means your ports are fine and u need to reinsatll the drivers of the ethernet card on your computer. Else your routers ethernet port are not functioning. If that is the case you can try to reset the router.
Let me know your finding.
**If this works please rate else let me know in case of further help.**
Jul 03, 2010 | Linksys Wireless-G WRT54G Router
Ethernet port connection failure
You could get another ethernet card from ebay for less than $10. Although, honestly, I don't think the port could have oxidized in 5 years. What is the error message(s)?
Mar 29, 2009 | Linksys Wireless-G WRTP54G Router
Hookup with Vonage device
I am going to attempt to give you a solution here. But you must understand a few things before I begin.
First, I would like to clarify that if you have Time Warner internet service, you are on Cable Internet. Not DSL. (This makes a world of difference when it comes to using a router.)
Secondly, you did not specify model numbers of your devices. Therefore I am assuming that you are using the following devices:
If this is not the correct equipment, continue to follow the instructions but be dynamic and adapt my instructions to the equipment you have. It should be similar enough that you shouldn't have any problem easily doing this.
This instruction set is going to begin from a point that is assuming that we're installing all of this equipment from the standpoint of a completely new installation. From the ground up.
Let's begin.
UNPLUG AND POWER DOWN ALL OF YOUR EQUIPMENT INCLUDING THE CABLE MODEM, ROUTER, PC AND VONAGE BOX. Do not power on any of the devices until instructed to do so.
1.) Connect your cable modem to the cable from the wall.
2.) Find the ethernet port on your cable modem. Connect the blue ethernet (CAT5) cable to the ethernet port.
3.) Plug the other end of the blue ethernet cable into the "Internet" port of the router. (Older routers used to also call this a "WAN" port.) It is the only port that is seperated from the rest of them.
4.) Connect another ethernet cable to port 1 of the router.
5.) Connect the other end of the ethernet cable to the network port of your PC.
6.) Connect yet another ethernet cable to port 2 of the router.
7.) Connect the other end of this ethernet cable to the ethernet port of the Vonage box.
8.) Plug in the power adapter of the cable modem. Wait 1 minute for the cable modem to acquire it's signal and set up the connection to Time Warner.
9.) Plug in the power adapter of the Linksys router. It should only take 15-20 seconds to set itself up. (If you have made any configurations to the router prior to this, I recommend pressing and holding the RESET button for at least 10 seconds to give you a fresh configuration state to start with.)
10.) Plug in the power adapter to the Linksys PAP2 VOIP Phone Adapter.
11.) Power on your PC. You should have an internet connection with it.
You see... As I read the configuration you described, I don't think that you're using a PAP2 phone adapter. You said that you connected the "vonage device" to both your modem and your PC. This is not possible with the PAP2 adapter as it only has ONE ethernet port.
I am led to believe that you are actually using the Linksys WRTP54G which is essentially the same thing as the WRT54G, but with Vonage support built-in.
If that is the case, then you will not need to use the WRT54G router. Instead, follow the instructions that I gave you assuming that the router and the phone device are combined into one device. (The ports will still be labeled the same.)
Download the installation guide for the WRTP54G from the product page link I just gave you. You'll find the link to the User Guide on the right-side panel. This will make everything clearer for you if you do indeed have that router instead of the PAP2 phone adapter.
If you continue to be confused, please let me know. DO NOT just give me a poor rating without asking more questions. I am here to help you solve your issue. Not have my rating decreased just because someone is too confused or lazy to ask more questions.
I'm happy to help you. :)
Good luck and let me know what the outcome is. (And please be sure to list your exact model numbers in the future!)
Cyryl
Nov 11, 2007 | Linksys Wireless-G Broadband Router
Linksys E3000 Wireless Router Logo
56 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
