Question about GE DBLR333GE Gas Dryer
Cord set or cord clip
I had a faulty outlet and my plug burned up in the socket. I am trying to replace it and when I look at the picture diagram for the replacement part I find two items pointing to the same item they are: CORD SET 120V (CORDSET PS267615 Price: $23.76 and a CORD CLIP (CLIP CORDSET) PS266821 26.58 Which one do I need? Thank you
  • 164 Answers
Just go tho the local hardware stor and buy a plug. You don't need the whole wire. just cut the old one of and wire the new one in place, much simpler
Posted on Jun 23, 2007
  • 5,911 Answers
To alleviate all the confusion, any standard three-prong appliance cord capable of handling 20 amps of current will suffice. Go to your local hardware or appliance repair store and they will have what you need. You need to specify that you have a GAS Dryer, right? That's what it says in the heading. Gas Dryers use 120 VAC, while Electric Dryers use 240 VAC. There's a huge difference in the shape and size of the cords. Hope this helps you.
My Lexmark X5630 does not switch on, what can I do?
1 Press to turn the printer off. 2 Disconnect the power cord from the wall outlet. 3 Gently remove the power supply from the printer. 4 Reconnect the power supply to the printer. 5 Plug the power cord into the wall outlet. 6 Press to turn the printer on.
Make sure the cord on the back of the printer is pushed all the way into the socket, it should only fit one way. If that fails, check that there is power at the outlet you are using.
Sep 08, 2017 | Lexmark Office Equipment & Supplies
I just plugged in my sewing machine into a new apartments socket. This machine has always worked. I smelled a strange odor, and went to get scissors. When I returned the machine was completely dead. Did...
1. Have you tried it in another socket? Check the light bulb to ensure it isn't rubbing against something (smell).
2. After you try the machine in a new socket make sure the on/off switch is set to on. Is the bulb lit? Replace it if not. Also, check the outlet with something else electrical to make sure it is working.
3. Make sure the cord is attached securely to the machine.
4. If these checks hasn't worked your next move is to go to your repair shop.
Mar 20, 2015 | Sewing Machines
RE: Friedrich SL28N30B Has Faulty LCDI cord ( will not set -reset ). When plug in blue power light comes on then goes out. Cut cord and installed standard 3 prong male Plug end. Same results- power...
It could be that the faulty cord burned your built in gfi internal switch must like a gfi breaker that gets burn off and never resets . Replacing the cord as you did is a smart move since I would never place an appliance on a gfi receptacle .
May 26, 2014 | Dryers
Amana ALE643RBW Dry will not start. I checked the thermal fuse and the high limit thermostat both read 0 to 4 back to 0 ohms. It was jumping around back and forth. Checked the heating coil it read 10...
Hello Dale,
Having checked the thermal fuseto be good i will give you a partial list other things that could make the dryer not start
start switch
door switch
timer
circuit breaker, use your meter set to volts ac and check for 240 vac at the outlet,if 240 not at power outlet check for burnt connection inside outlet or bad circuit breaker
if 240vac at outlet check for 240 vac at terminal block on back of dryer where cord connects,if 240 at outlet but not terminal block replace cord , if burnt connection at terminal block,replace cord and block
finally the motor,manufactures do not publish wiring diagrams online and the only way for me to tell you to use jumper cord to check motor is find the wiring diagram inside of control panel and place one wire on the terminal indicated as neutral on wiring diagram and one wire on terminal indicated on diagram as run winding
firstly though check door switch to have contunity (0 ohms) and the start switch to have (0 ohms)WHILE PUSHING IT IN(the start switch isa momentary contact switch and will only have contunity while its pushed in)
to check timer again use wiring diagram and find chart that shows various cycles and with timer set to a cycle the two wires is says will have contunity will be indicated by a solid black line on the diagram
Good luck, Gene
Jul 26, 2011 | Dryers
When I installed my haier hwr08xc7 air conditioner this season I plugged it in and the plug light lit but the air conditioner would not come on no matter what i did on the unit or the remote. I then...
Hi, I would say you have a problem in the cord its self. Even though it lights up, its not getting power to the controls. I would go to a hardware store and get a new cord and take care of the problem. When you replaced the socket in the wall and the fan came on, you just got lucky and the cord moved in the right position to start the fan. I am sure the cord is either faulty, or the connections where the cord wires in are not very good. Please remember how the cord is wired, even if you have to draw a picture. It will hook to a capacitor if it is a 220 unit. Just draw you a diagram.
Shastalaker7
A/C Contractor
Jun 10, 2011 | Haier Heating & Cooling
Power light falshes on and off and tv will not power on. any advice on how to fix this
Unplug the tv for 5 minutes, then try this. Keep holding the VOL+ and CH- buttons down while you plug the tv cord back into the wall ac outlet till you get sound and picture for a second or two. You should be able to turn the tv on and off with the power button now. Next turn the power button off and unplug the tv for a few seconds and then plug it back in and turn the power button back on. Watch the screen and see if the sound and picture comes on, best to check in a dark room to see better, if sound stays on and picture comes on a few seconds and back off you have a bad CCFL backlight lamp in the LCD panel. This tv hads (10) CCFL lamps part # RLMPLA029WJN1 cost $15.93 at www.partstore.com or $19.49 at www.encompassparts.com in it and if one is burned out it will not let the tv picture be powered on till it is replaced. To check and replace the CCFL lamp you will have to unplug the ac cord from the tv back and remove 10 screws holding the back on. With back removed unplug the wire plug on the power button circuit at top left side of the black LCD screen trim, remove 4 screws holding the top of black trim, lay speakers off it, and release trim clips, (4) at top and (2) at bottom with a flat screw driver, and lower the trim to unclip the LED circuit board at bottom left side on the trim. With trim removed, at top of LCD panel remove the PC ribbon wire clip with thumb nail by lifting up on it to release the flat PC ribbon wire. Lay the tv back on a soft pillow with screen up, and look on the LCD panel front for and remove the (10) silver screws 1/2" long with an arrow mark beside them. Do not remove any gold colored screws or any without marks. The LCD panel screen can now be lifted off, lift the backlight plastic thin sheeting and thick sheet off to see the CCFL lamps. Plug the ac cord back into the power supply inverter circuit board and plug the power button plug wire back in its circuit board on the LCD black trim panel, and power the tv on while looking at the CCFL lamps. If the lamp is dim or burned out, take the (2) white plastic covers off the ends of the lamps with a flat screw driver and unclip the lamp to replace it, Check the lamp socket part # QSOCFA003WJZZ by putting a good lamp in it and if it lights up the sockets are good and the bad lamp was the problem. If all the CCFL lamps do not light up, unclip the top lamps and move them to differant sockets to the center and the center lamps to the top, if the lamps do not light up, then it is a bad power supply inverter circuit board the ac cord plugs into, part # RUNTKA448WJQZ , cost about $160.00 for new one or less if you buy a used one on www.ebay.com , replace it and the tv should work ok then.
Feb 12, 2011 | Sharp LC-32SB23U 32 in. LCD TV
The tv came on then the screen went black but there was still sound for a sec. Now the green light keeps blinking and the tv won't turn
Unplug the tv for 5 minutes, then try this. Keep holding the VOL+ and CH- buttons down while you plug the tv cord back into the wall ac outlet till you get sound and picture for a second or two. You should be able to turn the tv on and off with the power button now. Next turn the power button off and unplug the tv for a few seconds and then plug it back in and turn the power button back on. Watch the screen and see if the sound and picture comes on, best to check in a dark room to see better, if sound stays on and picture comes on a few seconds and back off you have a bad CCFL backlight lamp in the LCD panel. This tv hads (10) CCFL lamps part # RLMPLA029WJN1 cost $15.93 at www.partstore.com or $19.49 at www.encompassparts.com in it and if one is burned out it will not let the tv picture be powered on till it is replaced. To check and replace the CCFL lamp you will have to unplug the ac cord from the tv back and remove 10 screws holding the back on. With back removed unplug the wire plug on the power button circuit at top left side of the black LCD screen trim, remove 4 screws holding the top of black trim, lay speakers off it, and release trim clips, (4) at top and (2) at bottom with a flat screw driver, and lower the trim to unclip the LED circuit board at bottom left side on the trim. With trim removed, at top of LCD panel remove the (2) PC ribbon wire clips with thumb nail by lifting up on it to release the flat PC ribbon wire. Lay the tv back on a soft pillow with screen up, and look on the LCD panel front for and remove the (10) silver screws 1/2" long with an arrow mark beside them. Do not remove any gold colored screws or any without marks. The LCD panel screen can now be lifted off, lift the backlight plastic thin sheeting and thick sheet off to see the CCFL lamps. Plug the ac cord back into the power supply inverter circuit board and plug the power button plug wire back in its circuit board on the LCD black trim panel, and power the tv on while looking at the CCFL lamps. If the lamp is dim or burned out, take the (2) white plastic covers off the ends of the lamps with a flat screw driver and unclip the lamp to replace it, Check the lamp socket part # QSOCFA003WJZZ by putting a good lamp in it and if it lights up the sockets are good and the bad lamp was the problem. If all the CCFL lamps do not light up, unclip the top lamps and move them to differant sockets to the center and the center lamps to the top, if the lamps do not light up, then it is a bad power supply inverter circuit board the ac cord plugs into, part # RUNTKA448WJQZ , cost about $160.00 for new one or less if you buy a used one on www.ebay.com , replace it and the tv should work ok then.
Dec 06, 2010 | Sharp LC-32SB23U 32 in. LCD TV
My Dell MFP 1125 was out of toner and before I could replace it, it powered down one day while I was away. I have tried unplugging it from the outlet and even removing the power cord, but it will not power...
On mine, after some trial and error, I found that if you DISCONNECT the unit completely from the AC outlet for 5 or 10 minutes, then plug it back in again it works.
However please check these things:
1)the power cord wire must be faulty.try replacing that power wire. 2)the power cord wire must not be connected properly either to the electric outlet or to the back of the printer.
3)the electric socket in which u r trying to connect the power wire must be faulty.check out in any other socket.
4)or it could be the short circuit in the main board of printer.if that is the case then it will be very much costly to get it repaired.
Sep 02, 2010 | Dell 1125 All-In-One Laser Printer
I push my power switch and nothing happens. the
Jun 02, 2010 | Sharp LC-32SB23U 32 in. LCD TV
GE DBLR333GE Gas Dryer Logo
65 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
vince
Marc Taylor
Are you a GE Dryer Expert? Answer questions, earn points and help others
