Question about Minn Kota Riptide St Saltwater 80 Bow Mount Trolling Motor
Minn Kota Riptide won't turn
When I push the remote to change directions, it makes a small buzz but does not turn. It feels like it does not have enough power but that is not the problem since it has full thrust power. Any thoughts?
SOURCE: what size battery does a minn kota 565 5 speed
12 Volt
Posted on Jul 17, 2009
  • 122 Answers
SOURCE: How many amps does a minn kota 80lb thrust motor draw ?
max is 56amps on 24v system
Posted on Jan 31, 2010
snowghost1
  • 784 Answers
SOURCE: I have the Minn Kota
if it is not steering with the remote - then the problem could be something as simple as the switching relay,, or a bad pin / wire in the plug,, or it could be a bad servo motor.
the best way to trouble shoot the unit would be to open the case and use volt meter to trace the voltage flow. also make sure you are getting power to and thru the remote as I have seen the control buttons go bad.
if you are still having troubles and have more questions - please feel free to write me back here and I will do my best to walk you through the steps needed to fix or trouble shoot more.
have a great night,
c...
Posted on Feb 21, 2011
dcramer531
  • 1654 Answers
SOURCE: The autopilot for my 2006 Minn Kota Riptide 55lb
Some common issue with these are as follows.
The polarity some how got reversed, either when changing batteries or chaging them. A ligning strike can cause an issue like this as well, it doesn't need to hit the boat cause a problem just close by is enough.
There is a magneto that can short out as well, minn kota can supply a replacement if yours is arcing.
Can also be something as simple as the switching relay,, or a bad pin / wire in the plug,, or it could be a bad servo motor.
Take the side panel off the part of the trolling motor that actually is bolted to the bow of the boat--this panel contains a sealed circuit board with a small antenna attached; see if anything looks burnt or otherwise not normal.
Last but not least, are the batteries in the co-pilot good?
Posted on Mar 07, 2011
  • 823 Answers
SOURCE: I have a minn kota
Ok, I have done this quite a few times so take heed, I am not familiar with the MK65 but I am sure the principal is the same on all of these motors..
Take off the top half of the plastic head and look on the center shaft. Your two foot control wires wrap around a plastic spool which sits on the shaft with a spline fit. If you have not done this before, get a pad and pencil and draw the way the wires come in, lay and attach in that plastic spool - because when you pull it off, if they come off you will be scratching your head wondering what the hell you did. You can figure it out but why think if you don't have to, its not as simple as it sounds because spool rotates, the wires wrap round and round etc.. Slack your cable tension adjustment screw in the footpedal all the way off, then what you have to do is slide that plastic spool off, and rotate it until you have the right position. The object of this, is to have the motor set pointing straight ahead, with your footpedal in the middle incline position, so you have full travel in each direction up and down. When you do this, you have to be aware that with the cables loose, they can come off the cams in the footpedal if you don't keep tension on them. Good luck.
Posted on Jun 20, 2011
Minn kota
I have a terrova with i pilot same thing happened found out it was the remote, if thats not it then you will more than likely have to send it in for repair.
May 13, 2014 | Minn Kota Riptide Sp Saltwater 70 Bow...
Minn kota riptide trolling motor
2 things can be wrong here the mother board is burned up or the speed switch is out
Aug 23, 2013 | Boating
What sizebattery is recommended for a Minn Kota RT40/s riptide motor
Hi, you can get away with a 70 amp hour deep cycle battery but I generally fit a 100 amp hour deep cycle battery. Hope this helps, regards Phil.
Jun 29, 2011 | Minn Kota Riptide 40 Transom Mount...
Have a minn kota riptide sf 101 thrust 62" shaft.
There is more than the shaft, there is the housing and then everything needs to fit and have correct clearances.....I suggest sell the old one and get a 52 inch new one...
Mar 01, 2011 | Minn Kota Riptide SF 101 Saltwater...
Minn kota will turn on and off with remote, but will only turn 1" to each side.
take off the top cover on the head of the motor and see if there are any restrictions to the movement of the cable. it may be the cable itself is rusted internally and may need replacement. call min kota on the 800 number on the motor for prices for any patrs you may need.
May 28, 2010 | Minn Kota Riptide Sp Saltwater 70 Bow...
Looking for parts.
You nearest Minn Kota service centre is
G/M Industries
9502w 800s
Swayzee
, IN
46986
Phone: 765-922-4816
8am-10pm Monday - Sunday
Jul 11, 2009 | Minn Kota Riptide St Saltwater 80 Bow...
Minn Kota Riptide St Saltwater 80 Bow Mount Trolling Motor Logo
546 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
