Question about Bosch Vw/audi Ve Diesel Fuel Injection Pump Indicator Adapter Holder Timing Tool
Mb140 diesel fuel pump timing - Bosch Vw/audi Ve Diesel Fuel Injection Pump Indicator Adapter Holder Timing Tool
How do you bleed the diesel fuel filter on a 1986 Toyota diesel Land Crusier?
I don't know a lot about these trucks but I can tell you that somewhere between the spin-on fuel filter and the I.P. (injection pump) is a 1.5" dia X 4" long steel primer. Just under the top of it is a spring. You will need to loosen or open the "Fuel supply line", at the I.P. (going from the filter, to the pump) and manually pump the fuel primer. Continue pumping the fuel primer until diesel flow from the opening. Quickly close off the drain-port or fuel-line, pump the primer a few more times (to increase line pressure and try to start your vehicle. After it starts, check for leaks. Let me know if I can help anymore. Good luck.
Mar 06, 2014 | Cars & Trucks
SYSTEM WONT BLEED
diesel engines high pressure pumps not suppose run dry.diesel fuel keep high pressure pump cool and lubricated.problem could be fuel pressure regulator in the fuel filter water separator housing.replace fuel filter see if it helps problem could be fuel pressure regulator in fuel filter housing, the fuel pressure regulator has a air bleed orifice that allows vent to the fuel tank.make sure fuel pump fuse okay pump getting power. i would let garage or dealership check it out if all fails because your diesel engine fuel timing is pcm controlled if let fuel system go dry you probably have to have fuel injection timing reset or could have damage high pressure pump letting it run dry i hope thats not the case because high pressure pump not cheap part i hope it not that.
Sep 17, 2012 | 2008 Ford F-350 Super Duty
Put diesel fuel in on accident pumped fuel out from fuel line in front of filter, filled up truck with regular fuel now runs bad and fuel pump is on continuous when running and pump ismaking loud noise
The diesel fuel is not a good lubricant for the pump and plugged the sock inside the tank replace the fuel pump and sock also pull spark plugs and clean I am sure it is running like ******* the diesel coats the plugs so they won't fire without being cleaned. Gas is much thinner than diesel and the gas lubricates the pump once the diesel washed off the bearings in the pump if most likely finished off a pump about to go anyway.17 years is a long time for new pump to last and in 92 they were not putting in the junk they are now in our fuels. If you need more help or want a price on the pump let me know.
Jul 31, 2009 | 1992 Nissan Pickup
(TOYOTA SURF 1990 TURBO DIESEL) No diesel coming out of fuel pump
If it has glow plugs or an intake heater you will need to disable the circuit. Then you can use a small amount of ether to spray into the air cleaner.!!! If you spray too much and/or Dont disable the circuits you can damage the motor!!! When you spray the ether, if the engine starts and stalls then its not getting fuel. This could be related to the fuel pump, injection pump, the fuel system loosing its prime(fuel line leak), fuel shut-off valve or solenoid. If it doesn't start then it could be related to your timing, valves or maybe compression.
Feb 10, 2009 | 1987 Toyota Cressida
Fill your fuel filter all the way up and take precaution not to get any air into pump. Try this several times. Once you get air into some pumps it can be very hard to bleed it off. There should be some way to bleed. Look on pump for bleeder.
Jan 25, 2009 | 1990 Toyota Pickup
Bosch Vw/audi Ve Diesel Fuel Injection Pump Indicator Adapter Holder Timing Tool Logo
75 people viewed this question
Top Bosch Kitchen Ranges Experts
William Miller
William Miller
ashburton
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
