Question about Nordic Track Exercise & Fitness
NOrdic Track C2400 shuts down - Nordic Track Exercise & Fitness
  • 64 Answers
SOURCE: Nordic Track Treadmill will not run
If console lights up but doesnt respond when buttons are pressed, you more than likely have a console problem. Key pad issue would be my best guess.
Posted on Jun 08, 2009
  • 103 Answers
SOURCE: Calibration Mode for nordic track treadmill model
Hello there, The calibration mode for a nordictrack is as follows.
With the safety key out, hold the stop and speed up arrow at the same time while inserting the key. Release the buttons. You will then be in diagnostics.
You then press the stop button one time.
If you are trying to calibrate the incline you just need to hit the incline up button and the machine will do an incline calibration. The unit should go all the way to the top and return to the bottom when completed.
If you need to calibrate the speed you will need to press and hold the speed up button on the console until the display reads 85. The machine should then be running at its maximum speed (either 10 or 12 mph depending on the unit)
The display will show a speed on the console and should be within .3 of the maximum speed.
If it is not then it will need to be adjusted using a potentiometer on the control pwb.
To access the control pwb open the hood cover. Should be 3 screws in the rear of the cover and 2 screws on the bottom of the unit.
Once inside the cover locate the control pwb. On the control pwb there will be a yellow/orange potentiometer. This is the adjusting part.
Use a non-metallic phillips head screw driver to adjust the potentiometer either clockwise for faster or counterclockwise for slower.
Hope this helps!
Good Luck! Tim
Posted on Jan 13, 2010
Testimonial: "Although I haven't attempted this solution, but it makes perfect sense and will attempt it as soon as I get back to the treadmill - Thank you"
Gackmaster
  • 12 Answers
SOURCE: I have a Nordic Track EXP1000i Treadmill. The
I know it's been months, but, if you still have this problem try this: 1. remove the philips screws holding the motor/belt/electronics cover on: you can lay the whole thing on it's side and remove them from the bottom. there's two in the front and two on the sides.
2. Obviously, unplug the unit! before doing anything. lay the unit back on it's feet (normal position)
3. Find the incline motor assembly. it will be int he middle of everything. black tube thingy.
4. take a cordless drill with a flat head screw driver bit, and turn the incline motor CCW. until the bed is flat.
5. what what I have read, you should shop for a new incline sensor. these fail before the motor does.
Posted on Jan 26, 2010
SOURCE: Belt slipping on Nordic Track c1900
My belt is slipping I tighten both alan head screws to the max roughly 7 turns and still have the broblem
Posted on Jul 10, 2010
  • 34 Answers
SOURCE: Nordic Track Ifit Treadmill has power but walking pad not working
If everything on the display console is working correctly then we know it is either a problem with the wires from the console to the controller or the controller itself. In most cases this means you need a new controller. To verify, take off the motor hood and find the green circuit board called the motor controller. With the power on go into manual mode and push the speed up button to a slow speed. If you see an LED light with "spd ctrl" next to it flickering but the belt still does not move then we know the problem is with the controller sending the signal to the walking belt, in which you should check the wires that go to the motor. If they are connected correctly then we know a new controller is in order. If you do not see a flickering light then it means the speed signal never got there and the problem will be with the wires going from the console to the controller. This is called an upright wire harness.
Posted on Aug 18, 2010
I need BC 887 manual
[DOC]Nordic Track Achiever Manual
188.166.107.131/nordic-track-achiever-manual.doc
... owners manual pro achiever etc ebay , nordic track achiever bc 887 manual ...nordictrack treadmill achiever reviews viewpoints , nordic track skier exercise ...
[DOC]Nordic Track Skier Manual
188.166.107.131/nordic-track-skier-manual.doc
... treadmill manual google sites , ntl nordictrack nordic track c manual sears , nordictrack ntl 1 user manual pdf download , nordic track achiever bc 887 manual ...
achiever bc 887 Treadmills Questions & Answers - Fixya
www.fixya.com > Forum > Tags > achiever bc 887
Treadmills achiever bc 887 questions and answers. Ask your ... Where is the ENTER button? please follow the instr.manual if you do not have it download it from ..
Jan 14, 2016 | Exercise & Fitness
When you press start. It starts fast then immdeiately stops. nordictrack c2400.
Seem your controller is faulty...replace it. You can get used parts here.
Dec 25, 2013 | Nordic Track Exercise & Fitness
Nordic track treadmill 5100r shuts off as soon as turned on
please LUBE the deck belt + rollers bearing too. See the video and proceed according. This happen because the lack of maintenance schedule.If after you fixed the problem remain , is TIME to replace the old board deck.
God bless you
Feb 25, 2013 | Nordic Track Exercise & Fitness
CONSOLE BEEPING
Adjust the REED swithc, test for open or faulty, see the diagram. Clean it , and tight the connector very well
2) Replace the batteries by new ones, with the same types such hybrids rayovac, same polarity.
3) clean the contacts batteries.
God bless you
Jan 08, 2013 | Nordic Track Nordictrack C2400 Console For...
Nordic Track X5 belt won't move
1) Lube the deck belt, this happen because the electronic system protect the system and shut down.the cause is deck worn.
2) Lube the rollers bearing too.
3) Measure the input voltage motor, if there are the motor need repair.
4) Measure the output voltage board, for input voltage motor, if there are Not the board is faulty.
God bless you
Jun 12, 2012 | Nordic Track Exercise & Fitness
Nordic Track treadmill A2105 will shut down and trip my HOME breaker while in use, what could be the problem? I have tried lubricating the belt and it worked a little longer than usual, but after abo
1) you must LUBE THE DECK BELT+ ROLLER BEARING.
2) Test the input voltage motor, if there are the MOTOR is faulty need REPAIR.
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
4) SEE THE BLOCK DIAGRAM, whatever component can be faulty.
However you must test the power cord for short circuit between cable, repair, and look inside according the BLOCK, and proceed with logic, see any loose wires, or some wires touching the carcase, some filter, coil, power supply USE the VOM.
God bless you
May 27, 2012 | Nordic Track Exercise & Fitness
My Nordic Track C2200 Treadmill will stop in mid run. The timing when it happens is random. I can pull the safety tab out and put it back in and run for a bit till it stops again. Any suggestions on...
It it completely shuts down ( console shuts down then restarts) it may be a static electricity problem. Check your outlet to be sure it is grounded. Check the plug . The ground pin may have been removed.
Jan 02, 2011 | Nordic Track Exercise & Fitness
Nordic Track C2000 starts and then stops.
Have you lubricated the the running deck? The lack of lubrication can increase friction thus causing the current over load circuit to activate thus shutting down the unit to prevent further damage, Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lift one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process on the other side. If this unit shut down again then you will have replace the running belt and possibly the deck
May 21, 2010 | Exercise & Fitness
Exercise & Fitness Logo
81 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
