Question about Seiko Watches Seiko Sportura Alarm Chronograph Pilot Watch SNAE97P1 SNAE97P SNAE97
Cant set alarm on seiko snae97p1
Following instructions in manual. it says pull out crown to first click, push button B to set time and push crown back in. doesnt work.
Coutura Chronograph Watch: set the alarm on a coutura chronograph...
pull the crown out 2 clicks.... set the alarm the same as your current time on your watch..... push the crown in 2 clicks..... than pull the crown out 1 click ..... set the alarm at the desired time with the lower button..... than push the crown in 1 click .... the alarm is ON
or go to this address http://caliber.seikowatches.com/ select the desired language than - alarm chronograph and play the alarm option on your right
May 17, 2010 | Seiko Coutura Chronograph Watch
How to use seiko coutura chronograph alarm?
May 19, 2010 | Watches
How do i set the alarm on my sieko contura
May 15, 2010 | Seiko Coutura Chronograph Watch
How to set alarm
Seiko chronograph
May 15, 2010 | Watches
Looking for instructions for a Seiko digital alarm chronograph solar powered back has 8n1913 the 8 could be a B. Thanks
seiko chronograph set the alarm etc pull the crown out 2 clicks.... set the alarm the same as your current time on your watch..... push the crown in 2 clicks..... than pull the crown out 1 click ..... set the alarm at the desired time with the lower button..... than push the crown in 1 click .... the alarm is ON
May 14, 2010 | Watches
Seiko 7t62 Coutura Black Ion; alarm resets NOT to current time but to about 3 hours later?! Yes, I have RTFM ;-)
Click on my profile, then click on TIPS AND TRICKS. There you will find link for all Seiko watch manuals. Download yours and learn how to reset the alarm. Rate me, plz.
Feb 20, 2010 | Seiko Coutura Chronograph Watch
How to set alarm on seiko chronograph sports 100
pull the crown out to the first click press the reset chronograph button until the hands on the small alarm dial start to move.set the alarm time press the crown back!
Jan 15, 2010 | Watches
How to adjust alarms
moz-screenshot.jpgSetting the alarm:
1. Pull the crown to the 2nd "click" (the possition you adjust the time) (Carefull: The seconds hand has to be on "12")
2. Press repeatedly button "B" to set ALARM hands to the time indicated by the main time hands (The ALARM hands move quickly if button B is kept pressed)
3. Push the crown to normal possition
4. Pull the crown to the 1st "click".
5. Press repeatedly button "B" to set the desired alarm time. (The ALARM hands move quickly if button B is kept pressed)
6. Push back the crown in to normal position.
At the designated time the alarm rings for 20 seconds, and it is automatically disengaged as it stops. To stop it manually, press button A or B.
Oct 15, 2008 | Seiko Le Grand Sport SDWF73 Wrist Watch
Seiko chronograph alarm
Solution #3 (Posted by Guest on 5 Mar 08) is spot on. Quick and easy method to reset the chrono hands (it was not in my Seiko manual).
Interestingly, this can also be used to set the chrono ahead (or behind--with a little math) for offset timing measurements.
Jan 13, 2008 | Seiko SNA553 Alarm Chronograph
How to Set Alarm
This is the movement used in the following Seiko watches..
SNAC74 SNAC75 SNA548 SNA694 SNAC40
SNAC41 SNAC42 SNA749 SNAC03 SNA411
SNA414 SNA765 SNAA03 SNAA05 SNAA01
SNAA02 SNAA61 SNAB61 SNAB62 SNAB64
SNAB65 SNAC25 SNAC29 SNAC35 SNAC36
SNAA61 SNAC38 SNA283 SNA695 SNAA30
HOW TO SET ALARM TIME
1. Pull the crown out to the second click position.
2. Press button “B” to set the alarm hour and minute hands to
current time.
3. Push the crown back to normal position.
4. Pull the crown to the first click position.
5. Press button “B” to set the alarm hour and minute hands to
desired alarm time.
6. Push the crown back to normal position.
Note:
Alarm setting on a 12-hour basis only. Alarm will ring at the
designated time for 20 seconds; one time alarm only. The alarm
needs to be reset in order to re-engage the alarm function.
HOW TO USE CHRONOGRAPH
1. Set crown at normal position.
2. Press button “A” to Start/Stop/Restart.
3. Press button “B” to Split/Split release/Reset.
HOW TO USE ALARM DIAL
AS DUAL TIME DISPLAY
2. Pres the button “B” to set the hour and minute hands to time of
a different time zone.
Nov 27, 2006 | Seiko Coutura SNA341 Wrist Watch
Seiko Watches Seiko Sportura Alarm Chronograph Pilot Watch SNAE97P1 SNAE97P SNAE97 Logo
131 people viewed this question
Top Seiko Watches Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Seiko Watches Watch Expert? Answer questions, earn points and help others
