Question about Garden
Trying to change the oil on my snow thrower & can't remove the drain plug
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 30 Answers
Use a wrench to twist it off or it it pries of then use pliers to pull it off.
Posted on Dec 31, 2012
3 Suggested Answers
huffman49
  • 235 Answers
SOURCE: Snow thrower is self propelled. was working fine then stalled
check the bearings in the auger sounds like the froze up and now they need to be replaced (the smoking you saw was from the belts slipping on the pullies)..good luck
Posted on Apr 14, 2010
  • 144 Answers
SOURCE: i have an old (late
No they don't have an oil filter.If you look at the bottom of your engine where it sits on the body of the blower you should see a small pipe with a cap to stop oil from coming out. This pipe goes just past the base of engine so you can put a container to catch the oil coming out. Sometimes there is no short piece of pipe just a plug, so it is much more difficult to contain the oil coming out. I hope this helps you out. Best regards and good luck.
Posted on Dec 26, 2010
Can I use 0w 20 Mobil 1 oil in my snow blower
It can be used, although the manufacturer recommends;
Super S 5W-30 Snow Thrower Engine Oil - Sears
www.sears.com/explorer-5w...snow-thrower...oil/p-07188298000P
Sears Rating: 4.5 - ‎5 votes
Oct 21, 2010 - Explorer 5W-30 snow thrower engine oil is a premium formulation for use in all four cycle engines when temperatures are below 32 deg. F. Explorer 5W-30 snow thrower engine oil protects the engine by lubrication, cooling, cleaning and sealing internal moving parts.
Aug 23, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Where is the throttle on a craftsman 536.881800 snow thrower?
Manual is available at http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Snow-removal-equipment-Parts/user-manuals/manual-downloads/Model-536881800/0247/1507200?modelNumber=536881800&diagramPageId=&documentId=
Dec 14, 2013 | Craftsman Sears Snow Thrower Manual Model...
Need manual for Noma snow thrower D2045010
I would suggest taking a look at this Noma Snow Thrower Manual. Well I just noticed it isn't quite the right one, but maybe it will work?
Feb 03, 2013 | Garden
Toro snowthrower 38180 won't start
You have probably fouled the spark plug (got a heap of black carbon on it) remove the spark plug wash in some petrol then use a wire brush vigorously brush between the contact points on the plug then reinstall. & lastly don't forget to push in the choke when you get it fired up next time.??
Mar 14, 2017 | Garden
I need to know what spark plug to use for my snow thrower. My son lost the one I had taken out to be replaced.
If snow thrower uses ordinary gasoline, then go to hardware store and get spark plug for lawn mower.
If snow blower uses 2-cycle engine oil mixed with gas, then get spark plug for weed eater.
Or buy both and try them out.
Hardware store is more likely to have someone familiar with which spark plug you need than box-size home center.
http://www.toro.com/home/customercare/interactivemanuals.html
Dec 26, 2010 | Garden
My snow thrower has been sitting for 4 years and i tried to start it last night and it would not turn over. any suggestions on how to get this started?
Drain and change the oil. Gasoline starts to deteriorate after 30 days and by 4 years it is unusable. Purchase a new spark plug, can of Seafoam Motor Tune and a can of starter fluid. Remove all the gasoline from the fuel tank. Remove the float bowl and clean it out. Replace the float bowl & turn the fuel supply on. Fill the tank with fresh fuel. Pour the proper amount of Seafoam in the tank as listed on the directions on the can. Remove the spark plug and spray inside the cylinder with a small amount of starter fluid. Install the new spark plug. Now start the engine. You may have to remove the spark plug and do this again. eventually it will start and run. If it does not, you may have to dissemble the carburetor and clean it out.
Dec 31, 2009 | Agri-Fab Agri - Fab Snow Blower - 42"
Simplicity Sno Away Snow Thrower Briggs 6hp engine No Spark
Check engine oil.
Remove wire from low oil sensor and the start.
Replace low oil sensor.
Hope this tip help solve your problem.
r/David
Dec 28, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
I have a craftman snow thrower, model#536.886122, serial#632722946 and I'm in need of a manuel.
Manuals of Sears products are available through their 'Parts Direct' system and have been resonable in price. The last one for a riding mower cost ~$7.00
Sep 21, 2009 | Tools & Hardware - Others
Toro powerlite snowblower sputters out after 10-15 minutes
I would change the spark plug and be sure to gap it as per your owner's manual. I would also clean or change the air filter. I would also use only high test gas and the oil recommended by the manufacturer. good luck.
Jan 14, 2009 | Mowtownusa Snow Thrower Starter Switch for...
My snow thrower wont start
Change the spark plug being sure to set the spark plug gap as recommended in the owner's manual. Then clean or change the air filter. Finally use new high test gasoline. good luck.
Jan 12, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
