Reset all settings CO21JWU350BL - Televison & Video
How do I reset my iPhone 4
Just to be clear a "hard reset" will remove everything and restore your iPhone to its factory settings.
Settings - General - Reset
Here you will have various options, the main ones being:
  • Reset All Settings
  • Reset Network Settings
  • Erase All content and Settings
    • Selecting "Erase All Content and Settings" is what constitutes a Hard Reset. Your phone will ask you to enter your passcode, and will then ask to confirm.
Jul 14, 2014 | Apple iPhone 4 Black Smartphone
Tip
Restarting and Resetting iPad
Restart iPad: Press and hold the Sleep/Wake button until the red slider appears.
If you can't turn off iPad or if the problem continues, you may need to reset iPad. This should be done only if turning iPad off and on doesn't resolve the problem.
if the problems still not resolved Reset iPad settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but your data and media aren't deleted.
Reset all settings: Choose General > Reset, then tap Reset All Settings.
Reset network settings: Choose General > Reset, then tap Reset Network Settings.
Reset the keyboard dictionary: Choose General > Reset, then tap Reset Keyboard Dictionary.
Reset the Home screen layout: Choose General > Reset, then tap Reset Home Screen Layout.
Reset the location warnings: Choose General > Reset, then tap Reset Location Warnings.
on Sep 27, 2010 | Apple iPad (16 GB) WiFi Tablet PC
Message: HTML Parsing Error: Unable to modify the parent container element before the child element is closed (KB927917)
From MS site:
Method 1: Follow the provided article.
http://support.microsoft.com/kb/308260/
Method 2: Reset internet explorer and check, whether the issue persists. Follow the steps mentioned in the article given below.
Reset Internet Explorer settings
http://windows.microsoft.com/en-US/windows-vista/Reset-Internet-Explorer-7-settings
Note: The Reset Internet Explorer Settings feature might reset security settings or privacy settings that you added to the list of Trusted Sites. The Reset Internet Explorer Settings feature might also reset parental control settings. We recommend that you note these sites before you use the Reset Internet Explorer Settings feature.
Feb 26, 2013 | Microsoft Internet Explorer 8
Need to reset handset
IP Reset
IP Reset returns the basic network settings to their factory defaults. You can perform this operation from the
base unit or one of the handsets.
The following settings will be reset to their factory defaults:
DHCP setting (restored to DHCP on
• Settings related to static IP addressing (the values for static IP address, subnet mask, default gateway,
DNS1, and DNS2 are cleared)
• DNS settings for DHCP connection cleared
1.2 Reset and Firmware Update
1.2.1 Reset
1.2.1.1 Resetting the Network Settings IP Reset
Performing IP Reset from the phone user interface see 2.1.4 IP Reset restores the basic network settings
made through phone user interface programming or Web user interface programming to their factory defaults.
If the unit is unable to connect to the network after changing network settings, you can restore the network
settings to their factory defaults by performing IP Reset, and then try configuring the settings again. Settings
such as the phonebook data, are not cleared by this feature.
• DHCP setting restored to DHCP on
• DNS settings for DHCP connection (cleared)
• PHY settings (speed and duplex mode of the either LAN or PC port are restored to "automatic")
• VLAN (Virtual Local Area Network) settings (disabled)
• Terminal number settings (restored to "automatic")
Notice
After performing IP Reset, the unit will restart automatically. To avoid problems, it is recommended that
you save your settings before performing IP Reset.
Note
If these settings (with the exception of PHY settings and terminal number settings) were made through
Web user interface programming, the set values made through Web user interface programming
remain effective, even if you perform IP Reset. To reset these settings to their factory defaults, perform
Reset Web Settings from the Web user interface again.
Document Version
2010-08
Administrator Guide
www.InternetVoipPhone.co.uk ' sales@internetvoipphone.co.uk ' 0800 088 4846
Firmware Update
configuration file programming, the set values made through configuration file programming remain
effective, even if you perform Reset Web Settings.
Resetting the Settings Made through the Web User Interface
(Reset Web Settings)
Performing Reset Web Settings from the Web user interface see Reset to Defaults) resets the
settings made through the Web user interface to their default values.
When you use this feature, the unit will return to the status just after performing the most recent provisioning
or pre-provisioning.
Notice
After performing Reset Web Settings, the base unit will restart automatically. To avoid problems, it is
recommended that you save your settings before performing Reset Web Settings.
Note
The settings configured through the phone user interface only will not be reset. However, settings that
can be configured through both the phone user interface and Web user interface will be reset.
1.2.2 Firmware Update
You can update the unit's firmware to improve the unit's operation. You can configure the unit so that it
automatically downloads the new firmware file from a specified location. The firmware update will be executed
when the unit is restarted.
For details, see Section 6 Firmware Update.
Provisioning server
Firmware server
Configuration
file
A
Firmware
C
B
A Download
B Check for update
C Firmware download and update
34
Administrator Guide
Docume
Jan 16, 2013 | Panasonic KXTPA50 Phone
I forgot the lock code to my rumor touch and can still access the phone but cannot lock it because i forgot the code... what do i do?
hi dear.. please help me.. i forgot my NOKIA E63 restore factory settings lock code. please send the how to reset my lock code to manikanta.art@gmail.com
May 24, 2011 | LG Rumor Touch
My Samsung sgh-a867 keeps rebooting after about 30 sec - 1 min. What do I need to do to get this fixed.
Try resetting the phone.
Steps to reset Settings
  1. From Idle mode, touch Menu >Settings >Reset Settings.
  2. Place a checkmark next to those settings ( All, Sound Profiles, Display and Light, Phone, Alarms ) you wish reset.
  3. Touch Reset.
  4. Enter your phone password, if prompted and touch Confirm. The default password is 0000.
  5. At the Reset Settings ? prompt, touch Yes to reset, or No to cancel. Once your phone has been reset to its default settings for those selected options, it will restart itself in order to incorporate the new settings.
Apr 01, 2011 | Samsung Eternity Cell Phone
Sim not working
First, I tried reset the Network settings. This is what I did:
  1. From the main screen, tap Settings.
  2. Tap General.
  3. Scroll down and tap Reset.
  4. Tap Reset Network Settings.
After resetting Network Settings, my phone wass still not working. I then tried to reset all settings.
  2. Tap General.
  4. Tap Reset All Settings.
May 09, 2010 | Apple iPhone 3GS Black (16 GB)
MY PHONE IS LOCK AND I CANNOT UNLOCK IT. WHAT CAN I DO?
Check out this link below to download a PDF manual, software, and more for your phone. Just copy and paste into your browser.
http://www.samsung.com/us/consumer/mobile/mobile-phones/t-mobile-phones/SGH-T929ZKATMB/index.idx?pagetype=prd_detail&tab=support
Page 165 from your manual:
Reset Settings
From this menu you can reset your phone and sound settings to the default settings or perform a Master reset.
Reset settings
1. From Idle mode, touch Menu ➔ Settings ➔Reset settings ➔Reset settings.
2. Touch the check box next to each of the following that you want to reset
• All: Phone, Display, and Sound settings are returned to default values.
• Sound profiles: only sound settings are returned to default values.
• Display settings: only display settings are returned to default values.
• Phone settings: only phone settings are returned to default values.
3. Touch Reset.
Master reset
From this menu you can reset your phone and sound settings to the factory default settings.
1. From Idle mode, touch Menu ➔ Settings ➔ Reset settings.
2. Touch Master reset, enter your password, then select Yes to confirm.
The phone resets to the factory default settings automatically and when finished displays the Main menu.
Hope this helps, let me know if I can do anything else for you.
JimmyC
Oct 13, 2009 | Samsung Memoir SGH-T929 Cell Phone
Reset motorola razor pink manually
all the info i can give you. you cant manually reset it
reset settings
Reset default settings for all options except the
unlock code, security code, and lifetime timer:
settings> phone settings>Reset>Reset All Settings
delete data
Caution:
This option erases all information you
have entered
(including contacts and calendar
entries) and content you have downloaded
(including photos and sounds) stored in your
phone’s memory. After you erase the information,
you can’t recover it.
This option does not delete SIM card information:
s >u Settings > Phone Settings > Reset > Delete All Data
Caution:
have entered
(including photos and sounds) stored on your SIM
card. After you erase the information, you can’t
recover it.
> Delete Memory Cards
Jan 16, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Problem in iphone
Tap Settings > General > Reset > Reset All Settings
Note: This will reset all settings. No data or media will be deleted.
If that does not resolve your issue, try erasing all settings.
Tap Settings > General > Reset > Erase All Contents and Settings
Note: This will delete all media and data. All settings will be reset as well.
I had this problem too, i reset the setting and eureka all is well.
Jan 21, 2008 | Apple iPod MA446LL/A MP3 Player
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
