Kenmore ac heat window unit heater wont work model 58075124500
T blows fine the heatr just wont blow hot air
  • 49 Answers
SOURCE: reverse unit. Heater only blows air, not warm air
If you have a reverse cycle unit (heat pump) your compressor and your fan should be running. You need to determine if your compressor is running.
Posted on Nov 08, 2007
  • 7 Answers
SOURCE: my ac works fine but when i turn to heat no hot air
take contuity tester to test heat protecters and inline fuse in coil area /could be that you might have to change main board
Posted on Dec 16, 2008
  • 46 Answers
SOURCE: My heater is blowing just air, but no hot air?
Check to make sure that hot water is making it to and from your heater core. There are usually two lines that direct water (coolant) to and from the firewall from the engine (not the A/C) system. These lines are usually heater hoses.
If both of the lines are hot, there's a problem with the blend door, or an electrical fault in the controls or wiring. If one line is hot and the other one cool, your heater core is either plugged or had an air pocket. The latter will require bleeding the cooling system and the former will require replacing the heater core, (not a job for the faint of heart). Also, check the thermostat to make sure it didn't fail in the open position.
Posted on Dec 28, 2008
  • 4 Answers
SOURCE: Central Electric heat not blowing hot or warm air
Make sure you are in the heat mode. Do you hear the wall thermostat click when you raise and lower the set temp. If not replace thermostst. Clean all filters to start. Does your heat source have a pilot light to start or is the unit located out side. If apilot light make sure itis lit. let's go from there
ddr_2u@charter.ner
Posted on Jan 13, 2009
onyeredson
  • 404 Answers
SOURCE: heater only blows cold air but hoses are hot
Hi!
It appears we have an Air lock scenario and you will need to perform a system Bleed.
Park the vehicle on level ground, when cold remove coolant filler cap, start engine and leave to idle, turn heater on full and blower to max. When engine reaches operating temperature watch and listen near coolant filler, keep clear as gurgling and hopefully a boil over should occur. Top up with very warm coolant and wait as it may do it again.
Check for heat inside vehicle if warm replace coolant cap but keep an eye on temperature gauge as the ~Air lock may have moved on from heater matrix/core so proceedure needs to be carried out again from COLD.
If persistent boil ups/over attention must made in the cylinder head
or gasket area, or possibly water pump?
Please press the Blue button to appraise my FREE Efforts, Thank You!
Paul 'W' U.K
Posted on Mar 01, 2009
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Jan 27, 2016 | 2000 Chrysler 300M
Heater only blows hot air intermittently.
Jeep Liberty heater not blowing hot air Questions & Answers ...
www.fixya.com > ... > heater not blowing hot air > Cars & Trucks > Jeep
Jeep Liberty cars & trucks heater not blowing hot air questions and answers. Ask your Jeep heater ... My 2005 Jeep Liberty will not blow heat through ... properly.
jeep liberty 2002 heat problem/hvac box issue - YouTube
? 3:12
https://www.youtube.com/watch?v=xf22fvcN1hU
May 28, 2013 - Uploaded by Joffre richer-desroches
Joffre richer-desroches. ... How To Install Replace Engine Coolant Thermostat and Housing 3.7L 2002 ...
Nov 01, 2015 | 2005 Jeep Liberty Sport
Passenger side blows cold air--what part could it be
2001 Chevy Tahoe Heat Problem - Tahoe Forum
www.tahoeforum.com > ... > Technical Discussions
Dec 5, 2008 - 10 posts - ‎7 authors 2001 Tahoe, the front heater blows a little hot air when the car warms up and then blows cold air. The rear heat seems to work fine. I changed ...
Rear AC blows hot air - Tahoe Forum - Chevy Tahoe Forum
Jul 14, 2008 - 10 posts - ‎5 authors
On my wifes 03' Yukon the rear air conditioning blows hot air no .... Pull the panel off and look at the hot/cold actuator shown in the picture.
Oct 30, 2015 | 2001 Chevrolet Tahoe
Have Goldstar Model R1804h ac/heater window unit when turned to heat blows only cold air what is easiest thing to check and purchase first.
If your thermostat is working on the Heat cycle (listen for "click" when turned up and down on Heat), then your heating coil assembly is probably bad. The heating coil is in series with a Fusible Link and a Bi-metal thermostat, if any of these three fails, there will be no heat from the coils.The Link and Bi-metal Thermostat are made up as part of the heater coil assembly.
Jan 18, 2013 | Goldstar Heating & Cooling
Heater doesnt work
To troubleshoot this types of problem,click the link below :---
Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Heat blows cold on drivers side and hot on passenger side?
http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html
No heat on car? http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows intermittently and temp gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html
Heater blows cold?
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
Heater/AC blower motor not working?
http://technoanswers.blogspot.in/2012/02/heaterac-blower-motor-not-working-on.html
A/C, heater, defroster fan, not working? http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html Heater problem?
http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
This will help.Thanks.
Mar 27, 2012 | 1994 Volvo 960
My heater is not working except on one side in my 2007 impala driver side it blows warm passenger cold
To troubleshoot this types of problem,click the link below :----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the issue.
Heater blows intermittently and temp gauge goes erratic? http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html------------Heater blows cold? http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
---------Car heater blowing warm, but not hot air? http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html-------- Heater/AC blower motor not working?
A/C, heater, defroster fan, not working? http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html Heater problem? http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html---------
Feb 27, 2012 | 2007 Chevrolet Impala LS Sedan New Cars
Air works great but no heat just blows cold air
For this types of problem,i suggest you to check this help links:----Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
---------A/C, heater, defroster fan, not working?http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
--------Heater problem?http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html
---------Engine Overheats and heater blowing cold?http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
-----------Heat blows cold on drivers side and hot on passenger side?http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html----------------This will help.Thanks.
Sep 05, 2011 | 2007 Suzuki SX4
Hello, I have a Kenmore 580.75124500 ac/heater
It is probably the compressor. You will need to check if the compressor is being called to come on. Do you hear the compressor running? If you do, I would remove the unit from the wall or window, and wash it down real good with a hose being careful not to get the electronics wet. If not and the unit sound different than it did before, it's probably time to buy a new one.
Mar 31, 2009 | Frigidaire FAC125P1A Window Air...
Heater
Try spinning the knob real fast in either direction. Sounds stupid but it worked for me.
Sep 27, 2008 | 2005 Chevrolet Malibu
Reverse unit. Heater only blows air, not warm air
Nov 07, 2007 | Kenmore 71121 Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
