Question about Dell Latitude D600 Notebook
Dell D600 wifi
My wi-fi radar isn't detecting any wireless connection. But other computers in my house are. What's going on and how can I fix it ?.
  • cuto2010 Jan 18, 2009
    my computer is running on windows vista
  • Anonymous Mar 13, 2014
    I dropped the computer and when i tried to connect to the internet its not picking up any wi-fi
    Problem Solver:
  • 6 Answers
It might be that your adapter isn't operating at a high enough power. To fix this Click start>right click my computer>properties>hardware>device manager>double click your wireless adapter. In the advanced tab set the power management and transmit power all the way up (but be warned: KILLS battery life). Or your adapter isn't set to the right mode (like if your access point or whatever is 802.11g and the adapter's settings are set to 802.11b only).
Posted on Jan 18, 2009
    Novelist:
  • 176 Answers
Do the Basics First;
  1. Make sure you turn it on or switch it on
  2. Reboot your PC
  3. Make sure your router is set to broadcast your SSID
  4. Right click your wireless connection and select "repair"
If still doesnt work;
  1. Select and double click your wireless connection
  2. Click on properties
  3. In the middle of the box find, select and highlight Internet Protocol (TCP/IP)
  4. Click on Properties
  5. Make sure "Obtain IP address automatically" and "Obtain DNS server address automatically" are the only ones selected
  6. Click on the "Wireless Network" tab
  7. On "Preferred networks" make sure your wireless is there ( your SSID) if not Add it, move it up or remove the others
  8. Once its added highlight it and click the "Advanced" button and make sure to select "Access point (infrastructure) networks only
  9. Make sure this is NOT checked "Automatically connect to non-preferred networks" then click "Close"
  10. Highlight again and this time click "Properties"button
  11. Check "Connect even if this network is not broadcasting"
  12. Check authentication configuration
DELL Latitude E6510, wifi button was OFF, now it is not working.Wifi is showing red cross. Please help how t0 turn it ON? I think it is Hardware issue. Can I fix it through Windows? Windows 7
Information Technologies
Share
Enable / Disable an Enterprise Laptop's Wi-Fi
Wi-Fi, short for Wireless Fidelity, is networking technology that allows you to connect to the Internet. If you have a wireless-enabled Latitude computer you can connect to the Internet when in range of an access point called a hotspot.
When not in use your Latitude's wireless card should be disabled. By disabling Wi-Fi, you will receive two benefits:
Start-up times will be much faster.
If the wireless card is ON and you are out of the office (not connected to your normal, wired connection), the laptop will try to use the Wi-Fi network during the login process to run the various start-up scripts, etc. It will eventually time-out (fail). By having the wireless card turned OFF, the start-up process will be much faster.
Computer will not continually search for a wireless network (and waste battery life).
If you are in the office (connected to your normal, wired connection) or in a location where there is no wireless hotspot, you don't need to have the computer waste processing power by looking and looking for a wireless hotspot. By disabling Wi-Fi, you will gain a little more power for your other tasks. In addition, you will maximize your battery operating time by disabling wireless activity.
NOTE: After your Latitude has started up completely, you can ENABLE the wireless card and connect to a wireless hotspot. For example, a wireless router at your home or at a local coffee shop. If you have connected to this hotspot previously, the wireless card should connect automatically for you.
NOTE: Once you have the wireless card enabled, before you shut down the computer, you should again DISABLE the card. The computer will then be ready for the next time you turn it on with wireless turned off.
Enable / Disable with Hardware Switch
The more recent Latitude models have a wireless switch to enable or disable wireless network devices and the
Wi-Fi Catcher Network Locator.
Dell Latitude E6420 and E6520 Series
These laptops have a small switch on the RIGHT side of the keyboard. The switch is toward the front of the laptop. The Wi-Fi Catcher™ icon will is above the keyboard. You will see a lit radio tower if the wireless switch is enable
Oct 17, 2016 | Dell Latitude E6510 Notebook
How do i set up wifi
To set up Wifi connection on HTC Smartphone:
  1. Press HOME
  2. Press MENU
  3. Tap Settings then Wireless controls
  4. Select the Wi-Fi check box to turn Wi-Fi on. The phone will scan for available wireless networks.
  5. Tap Wi-Fi settings.
  6. Select from the displayed network detected.
  7. Tap a Wi-Fi network to connect. If you select an open network, you will be automatically connected to the network. If you select a secure network, enter the key and then tap Connect.
Jul 02, 2011 | HTC F3188 Smartphone
WiFi just scans but does not find any available networks to connect to??;le
Hello Derek,
Connecting Wi-Fi in HTC Desire Cell Phone
From the Home screen, press , and then tap Settings > Wireless & networks.Select the Wi-Fi check box to turn Wi-Fi on. The phone then scans for available wireless networks.Tap Wi-Fi settings. The network names and security settings of detected Wi-Fi networks are displayed in the Wi-Fi networks section.If the wireless network you want to connect to is not in the list of detected networks, scroll down the screen, and then tap Add Wi-Fi network. Enter the wireless network settings, and then tap Save.Tap the Wi-Fi network you want to connect to. If you selected an open network, you will be automatically connected to the network. If you selected a network that is secured with WEP, enter the key and then tap Connect.
Jun 02, 2011 | HTC Desire Cell Phone
My WiFi light is not lit up on my Inspiron 1520. I cannot detect any wireless networks.
In Dell Inspiron 1520 Notebook, there is a switch on the left hand side of the laptop to enable/ disable Wifi. Make sure that it is on and with wireless light activated - Press and hold Fn and press F2 (Fn+F2). This will enable the wi-fi and you will be able to detect and connect to a wi-fi network
Let me know if any further clarification/ assistance is required.
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 10, 2010 | Dell Inspiron 1520 Motherboard
Wi Fi Connection
Have you tried this: go to bottom task bar and right click on the PC icon. Select "View Available Wireless Networks". Find and select the wireless system you have, i.e., linksys, etc., and click on "connect".
If that doesn't work, use the same method to open the connection options, and click on "repair".
Lastly, if neither of the above works, try rebooting your linksys or whatever wireless system you have, and start over.
Jan 01, 2009 | Dell Latitude D600 Notebook
Wireless connection
by default, dell systems' switch for wireless can be done by pressing Fn and tap F2. The wifi light should lit up. Your modem is integrated to the motherboard. If you were able to lit up the wifi light, this should be able to detect wireless signals for you to connect to.
Sep 19, 2008 | Dell Inspiron 2200 Notebook
Dell Latitude D600 Notebook Logo
652 people viewed this question
Alun Cox
